Results 1 to 5 of 5
    Reputation: 5spotfirefighter's Avatar
    DT Swiss 340 hub compatibility for disc brakes
    Can you use the following hubs for avid bb7 disc brakes,
    http://www.dtswiss.com/index.asp?fus...kedetail&id=30
    It has the 6 bolt adaptor but I don't see how the rotor would attach to the hub?
    Help please.
    Thanks.
    Pixie Dust Addict
    I believe that's a centerlock compatible disc hub. This is the standard defined by Shimano where the rotor is placed onto the splined part of the hub and tightened down with a lockring, similar to how a cassette is mounted. There is an adapter that will fit onto the splines that will add the IS compatible bolt holes.
    Reputation: cave dweller's Avatar
    Feb 2005
    Mate, why not just get the 340 with 6 bolt interface.
    http://www.dtswiss.com/index.asp?fus...ikedetail&id=5
    Feb 2005
    If you feel the need to get the center lock hubs, you can get this adaptor to run normal 6 bolt rotors
    yea i had the adaptor but didn't realize how to use it. I finally figured it out. thanks for the heads up guys and the new 5 spot is coming together great!!!!!
