Results 1 to 2 of 2
    got the dhr...
    Reputation: luseboy's Avatar
    DT i need your help...
    I have an 08 dhr, and i for some reason, keep snapping the bolts in the rear end, the smaller ones in the upper parts of the suspension at the rear-side of the shock. My local hardware stores only had bolts that were fully threaded through, to replace it with. Im wondering if this would be a problem? Also, my rear end is loose, i checked all the bolts, my hub, my through axle, my derailer hanger, is it possible that i dont haveenough grease packed into the pivots? would this even affect the tightnessof the rear end? I'll be at sea otter, so if i cant figure it out, i plan on just bringing it by the turner booth and having you or someone there look at it. Also, i want to put decals on my bike, where can i get them?
    Thanks a bunch in advance,
    you make one hell of a bike,
    Austin
    Greg
    greg@turnerbikes.com
    If you need a bolt quick, get a 55mm and cut off the extra thread, that way you get the extra long shank.
    DT
