Results 1 to 21 of 21
    Knomer
    Reputation: Dusty Bottoms's Avatar
    Does the Chris King BB grease injector tool work with the cranks on?
    It's kinda hard to tell how that tool works from the pix on their site, but if you have to take the cranks off you might as well just pop off the seal rings and do the job by hand. What is everyone's fav lube for crank & hub bearings? I use rock n' roll super web for headset & pivot bearings, but it seems a little thick for fully rotating bearings like crank & hub.
    And what about their bb cup tool, are the Chris King splines really any different than all the other brands? Does it really necessitate it's own tool? Altho it being a ratchet tool is pretty cool for torque purposes.
    Holla atta playa.
    Reputation: EVERYUSERNAMEISTAKEN's Avatar
    Judging by this video from the Competitive Cyclist I would say no, you cannot use the tool with the cranks on.
    http://www.competitivecyclist.com/za...%26BRAND.ID%3D
    I just use Pedro's Syngrease for lubing the bottom bracket.
    Moosehead
    Reputation: moosehead's Avatar
    Yes, you need to pull cranks and spindle cups for regrease tool. While the tool works well and flushes old grease for new without removing cups, it ain't cheap and I too expected a zerk style no fuss procedure.
    I was able to use typical Park Tool external bb wrench without marring the CK bb's.
    http://chrisking.com/files/pdfs/BB%2...11-08-A%20.pdf
    Your Best Friend
    Reputation: Silentfoe's Avatar
    My experience is that the tool is easy to use but causes other problems. The o-ring held in by a metal retention ring can and will eventually push out causing a slight headache. You then have to remove the retention ring and replace the o-ring. Nothing big, just obnoxious. Maybe someone else has some advice on keeping this from happening.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Dusty Bottoms
    Yep, pretty easy to do, I do it with my XT/LX cranks. Pretty dumb design that requires you to take off the cranks when you can just pop the dust seals. On older bikes that had grease-ports on the BB, you also didn't have to take the cranks off. I don't know what CK was thinking.
    If you ever need new bearings, just buy the enduro-bearings from enduroforkseals, they press in and are bigger than stock, they also get rid of that plastic sleeve. Only $12-15 bucks too. How many bearings can you buy for the cost of a "CK BB"?
    CK: When the best is just too hard to design.
    Knomer
    Quote Originally Posted by Jayem
    Word. I've been rockin' the enduro bearings in my race face cups for a few years now, damn easy to service. Stop trying to talk me out of spending more money!
    In fairness to CK, there's a bit more to it...
    I had the chance to talk Chris himself a couple of years ago at a show. The BB's had only been out a few months and I had the same questions as Dusty. Here's whay CK told me (keep in mind I'm very very stupid on many things, but most of all wrenching) about the design.
    Said they tried different methods (zirks) but couldn't make them work for what they wanted. Said they wanted a design that would do a couple of things; 1) purge ALL the gunk that gets inside the BB and they weren't able to do this with any other desings 2) Let the rider choose the grease of their choice for each application. Point 2 is where things got interesting. He told me they did tests with riders using different "weights" of grease and they could all tell the differnce in resistance. Their theory is that if they used this design, that each individual rider could tweak their ride for their need (ie, the guy riding wet terain and doing water crossings could use a better suited grease than say the weekend racer boy who wants the smoothest spinning stuff available). Like I said, take it for what it's worth, but that was the story the "Legend" gave to me.
    Dusty....just spend those crusty $$'s.
    Reputation: miles e's Avatar
    Quote Originally Posted by Otter
    You'd have to be pretty fanatical to go to all that trouble just to change the grease viscosity based on the ride you were doing. That said, I think I will try Prep-M next time, as the Syn Grease seemed a bit thick. Maybe a thinner grease will be less likely to blow out the o-ring too?
    ''It seems like a bit of a trend, everyone trying to make things longer over the last couple of years" Sam Hill
    locked - time out
    Point two is ridiculous.
    Your Best Friend
    So in regards to the different weights of grease...Where do you get light weight/thin viscosity grease for a standard grease gun that fits zerks?
    My grease gun looks like this...
    I wouldn't disagree with you, but....
    Quote Originally Posted by glitz
    how many people do you see out buying $125 BB's with ceramic bearings?? A crap ton and I believe CK is trying to capture some of that market but with a much more durable product. Just my guess.
    Knomer
    A crap ton
    Is a lot.
    There is a market for it... some people justify $3k on a frame, others drop $100 for ceramic bearings...
    Living the Dream
    Reputation: Alpenglow's Avatar
    Do you need to buy a special tool to press in the enduro
    bearings? Thanks. BTW, Iraq still sucks in case anyone was wondering.
    "And I shout that your all fakes and you should have seen the look on your face"
    Quote Originally Posted by Alpenglow
    Not really, I think I used the old bearings and a tap to get them in there. It's no different than installing any other pressed-in bearing. Be carefull and you'll be fine.
    Code Burr
    Reputation: thebronze's Avatar
    Do you need to buy a special tool to press in the enduro bearings? Thanks. BTW, Iraq still sucks in case anyone was wondering.
    Yeah for shimano i'm pretty sure you need the enduro press. The bearing sit almost flush in the cups. There's not really any room for a screwdriver or tap last time I looked. If you have a fsa mega exo bb they are really easy to replace. I used a small vice to press them in and a star nut tool to remove. You can find them dirt cheap on ebay. I havent tried it on a race face bb.
    edit - jayem, when I tried to remove my shimano bearings I couldnt see a way to drive them out since they sit almost flush. Did you have to fab something up for removal?
    Quote Originally Posted by thebronze
    They were not flush, almost flush is not flush. Just used a tap and a mallet and they came out fine. But yeah, there are other ways to do it.
    Living the Dream
    cool thanks
    Appreciate the help.
    I use one of these to remove old bearings; it's very inelegant, but works well (it does shave a bit off the interior of a Shimano shell). The cup also works very nicely to hold the BB cup while pressing in the new bearing. I use a bench vise... A glue clamp would work well too.
    https://www.universalcycles.com/shop...7&category=215
    Nov 2014
    Where can I buy the enduro seals for this price.
    I can't find a part number or link for it at rwc
    ANGULAR CONTACTENDURO BEARING KIT FOR BOTTOM BRACKETS
    is it the $29 angular ones?
    Quote Originally Posted by ReturnOfTheMTB View Post
    Yep, might want to check your local bearing supply shop first, they might even have these. Mine keeps them in stock. You can find out what the correct bearing size is running searches on ebay and amazon. You can also find cheaper ones there, I ordered 4 8086 bearings for my BB30 setup on my Turner a couple weeks ago, as our extremely muddy early summer washed all the grease out of one of mine and replaced it with mud. I repacked them and they work fine, but the next time it happens I'll change out the bearings. Again, it's relatively easy and cheap.
