DHR / Dorado Headset Setup
So I've got a medium 2012 DHR frame and I have a current model Dorado fork on order. I remember that the Fox 40 needed an lower external headset cup to avoid contact between the lower crown and the downtube. Does anyone know if the Dorado has the same issue?
No idea
what the Dorado lower crown clearance looks like.... But I do know that the frame was designed around a external lower bearing, this effects both the geometry and crown clearance. Just make sure you get one with at least 15mm of insertion, some of the big headsets, in the pursuit of weight savings I guess, have dropped their skirt lengths and they just don't grip well enough under hard use.
 Originally Posted by turnerbikes
No idea what the Dorado lower crown clearance looks like.... But I do know that the frame was designed around a external lower bearing, this effects both the geometry and crown clearance. Just make sure you get one with at least 15mm of insertion, some of the big headsets, in the pursuit of weight savings I guess, have dropped their skirt lengths and they just don't grip well enough under hard use.
It doesn't look like there are many examples of the DHR/Dorado combination out in the wild. Out of curiosity I went ahead and ordered a Cane Creek 110 with both a zero stack and external cup lower assembly to test how they each affect lower crown clearance. I'll report back what I find.
2011 DHR set-ups
Page 14, Post 3, of the DHR set-up thread has a Dorado equipped DHR. Go through that thread, I remember seeing a few others as well. It looks like it would work... Good luck!
2012 Turner DHR
2013 Turner Burner
Looks like they have external:
Rolling on 29", 650b, 8.3" and 23mm
DHR sure looks like the downhill sled for the 1% in these photos.
_MK
"No man goes before his time -- unless the boss leaves early."
-- Marx, Groucho
Nothing can stop me now
_MK
Isn't MTBing for the 1%? At least the ones on MTBR.
turners are for rich people
RIP Adam Yauch
"M.C. for what I AM and do, the A is for Adam and the lyrics; true"
So I had time this weekend to try fitting the Dorado to my medium DHR frame. The zero-stack lower cup puts the lower crown and the flared clamping area of the upper legs very close to the downtube gusset. Careful placement of the bumpers helps but there is still risk.
The external lower cup provides a safe amount of clearance for the fork. Given the design assumptions of the frame, its probably the best choice for the Dorado.
Well... after the lower headset bearing died on me (the headset got loose, star-nut was slipping so I was unable to tighten it. continued to ride with a loose headset for the rest of the day and killed the bearing) I switched to a zero-stack lower cup as I wanted more weight at the front wheels.
I thought I had checked clearance but Foxbat is making me have second thoughts. Gonna double check that once I return home from my trip.
From your picture, it looks like your running the upper legs pretty high in the lower crown. That is probably giving you an extra margin of clearance even with a zero-stack.
any updates on the fit of the Dorado? Any clearance issues with the lwr crown? With the external cup and the longer ac on the Dorado, does it feel tall up front. Trying to decide between a Dorado and Boxxer for my build.
Clearance between the Dorado's lower crown and the downtube with an external lower cup should be fine. I've been delayed getting my DHR put together but I'll try to get a head angle measurement in the next couple of days.
As for the Dorado vs Boxxer question, I looked for a while at all of the options but the Dorado design has had a few years to mature and prove itself. In particular, the Expert looks like a hell of a deal:
Why is nobody talking about the Manitou Dorado Expert?
Just took a quick measurement of the Dorado axle-to-crown length. With the lower crown set in the lowest (shortest) position, the distance between the center of the axle and the bearing race seat of the lower crown is about 575mm. A Fox 40 is 571mm. I think the quoted 591mm figure for the Dorado is for the lower crown mounted in the highest (longest) position.
Sweet, thanks for checking. Sounds like it should be fine. I just ordered a Dorado and I'm pretty stoked on testing it out.
- You may not post replies
- You may not edit your posts
Forum Rules
