Results 1 to 12 of 12
Thread: Dhr
    ajr
    ajr is offline
    Dhr
    This is built with a Therapy floating caliper kit and a Fox DH shock.
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    wow...nice!!
    1) how do you like the Fox? did you get a chance to ride the Romic to compare? Clearance issues?
    2) Do you notice a big difference with the floater?
    ajr
    ajr is offline
    Quote Originally Posted by Acadian
    wow...nice!!
    Fox shock is superb, super adjustable and the floater has made a noitceable difference to the rear end under braking. No clearance issues. have ridden other DHr's with Romics on and they to are very good.
    Quote Originally Posted by ajr
    thanks...
    but you prefer the Fox over the Romic?
    ajr
    ajr is offline
    thanks...
    The Fox is a better shock,but they both perform really well on this frame.
    Do riverside import Turner?
    I am confused. Are Riverside still the official UK importer for Turner?
    floating brake
    if you don't mind my asking, how much was the floating brake, and what kind of hub are you using?
    Reputation: Soupboy's Avatar
    Love the steed...
    ...wished I lived somewhere that warranted owning such a beauty.
    Sean
    Professional Amateur
    Quote Originally Posted by Soupboy
    Sean
    if you are on planet earth, you should qualify!!
    ajr
    ajr is offline
    Quote Originally Posted by tinystyle
    Itis a Hadley hub,cost of the floating kit is $250.00
    Dec 2005
    how did you atatch the floating brake on the "main frame"
    ajr
    ajr is offline
    Quote Originally Posted by sonnythep
    I drilled a hole in the brace and threaded it. I also fitted a nut on the bolt for added peace of mind.
  1. Replies: 22
    Last Post: 02-18-2005, 10:56 AM
  2. What spring rate 03 Turner DHR w\Romic
    By RickyD in forum Downhill - Freeride
    Last Post: 04-01-2004, 07:33 AM
  3. Does anyone use the DHR grease ports?
    By D.B in forum Downhill - Freeride
    Last Post: 03-14-2004, 08:25 AM
  4. Replies: 6
    Last Post: 03-10-2004, 11:53 PM
  5. ~~Turner DHR brake help!!~~
    By DHRich in forum Downhill - Freeride
    Last Post: 02-20-2004, 08:53 PM
