Results 1 to 3 of 3
    Reputation: CrashTheDOG's Avatar
    New question here. Czar: Cane Creek 110 Headset Sizing
    From Turners Czar FAQs I gathered that the Czar requires a "Cane Creek ZS44 top and a ZS56 bottom headset combo." Check. So now the only other option I need to select is a 8mm or 15mm stack for the top assembly. Wouldn't I want to keep the stack as low as possible and go with the 8mm? Suggestions?
    Depends on your sizing. Generally speaking, most folks do want the stack as low as possible. For taller people not as much of an issue. But probably best to go with low stack and adjust fit with spacers.
    Thanks chunky.
  1. Cane Creek AER Headset
    By phlegm in forum Weight Weenies
    Last Post: 02-11-2013, 07:59 AM
  2. Air 9 RDO Cane Creek headset Q
    By sand0kan in forum Niner Bikes
    Last Post: 12-27-2012, 10:24 AM
  3. Cane Creek 110 headset?
    By mtnbiker64 in forum Bike and Frame discussion
    Last Post: 08-29-2011, 08:41 PM
  4. Cane Creek AER headset?
    By rc51kid in forum Weight Weenies
    Last Post: 05-27-2011, 08:57 PM
  5. Cane Creek AER headset for XC?
    By Hardtailforever in forum Weight Weenies
    Last Post: 04-25-2011, 07:51 AM
