Results 1 to 7 of 7
    CZAR, 2 x XTR m9000 Cranks and XT M8000 crank. Do they fit?
    Hi crew anyone fitted the new XTR M9000 double crank to the CZAR?
    Also the new XT M8000 crank has been released , will this 2 x crank fit on the CZar.
    thanks
    Black and Sticky
    Reputation: Bituman's Avatar
    Bump...also interested in the answers. Thanks.
    Bob
    "Some people follow their dreams, others hunt them down and beat them mercilessly into submission." - Neil Kendall
    M8000 fit fine.
    XTR M9020 fit fine, as these have 168 Q same as XT M8000. up to 36 T big ring fits fine.
    M9000 are 158 Q and crank arms are very close to chainstay so I would say, not a fit.
    Reputation: doll118's Avatar
    will the M980 TRIL(double) CRANK FIT CZAR? not the 985 2x
    The old triple would fit, and for running a 1X XTR, use a 'triple' and put the Wolftooth or other single on that. only reason to buy a new XTR is to run a Stages power meter, otherwise there are too many good choices that either weight less or cost less or in some cases both.
    thanks
    Turner sold the Czar Xtr 2x1 kit, I imagine that will be the M/9020 by the Q factor, but I do not know if the Czar supported the rings 26 / 36T or also mounts the rings 28 / 38T.
    Has anyone tried mount on the Czar the M/9020 2x11, 26/38T with xt front derailleur?
  1. Release of xtr m9000 crank/ring
    By Phread in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2015, 03:20 PM
  2. Czar Build: Anyone Using Sram Cranks?
    By etanc in forum Turner
    Last Post: 12-24-2014, 03:48 PM
  3. Replies: 1
    Last Post: 12-24-2014, 10:41 AM
  4. M9000 Crank Non-Drive Side image?
    By Oni in forum Shimano
    Last Post: 07-24-2014, 11:50 AM
  5. Replies: 8
    Last Post: 04-24-2014, 06:45 AM
Members who have read this thread: 4
