Thread: Coil to RP23?
    MTP
    MTP is offline
    Nothing to see here
    Coil to RP23?
    I've got an '02 XCE and was looking to switch the coil shock to a Fox RP23. Anyone foresee any problems with this idea? BTW, the frame is a Large.
    Thanks for your infinite wisdom on all things Turner.
    Surfin' da mountain
    Reputation: Cucucachu's Avatar
    Aug 2003
    I don't know if Fox makes the RP23 in the right stroke unless you use XR Rockers.
    Coping with the change? - I went from an '03 XCE with a coil to a Spot with the RP23. I was skeptical about the ride and durability of an air shock but pleasantly surprised.
    MTP
    MTP is offline
    Nothing to see here
    Hmmmm....begs the question: wonder what the correct stroke is? Know the eye-to-eye measurement, but not sure if that's enough info.
    Surfin' da mountain
    Aug 2003
    Quote Originally Posted by MTP
    1.75" with X rockers (very uncommon)
    1.5" with XR rockers
