Results 1 to 6 of 6
    Reputation: Ottoreni's Avatar
    Clunk sound? Help
    Well, here's the problem (if it is one?)
    Everytime I compress the Marz Marathon s fork on my Burner, I hear this kind of deep clunk sound. Not to loud, but it is a noticeable sound. Once compressed, I can push it down repeatedly, and hear no sound. Now if I unweigh the front tire ( by lifting it off the ground) and then push the front end down again, I get the noise.
    I don't know if it is the fork, the headset or what?
    I have retightened my stem, after I preloaded the headset again, so that my spacers do not move (they were starting to move).
    Any opinions?
    I will most likely go sometime this week to my LBS (55 minute drive ), if I can't get rid of the sound.
    Anybody have a theory or suggestions that will save me a trip and money?
    You cannot go against nature, because when you do, its part of nature too.
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    It is often the coil in the fork. It deflects to the side and taps the stanchion wall. Try opening the top cap, compressing the fork a little, and turning the spring 90 degrees. That is sometimes enough.
    My video techniques can be found in this thread.
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    when you do this, is the front brake locked? or not.....and, just curious, but are you running a Thompson stem w/ the cylindrical wedge clamping gizmo?
    If your answer is brake locked w/ Thompson stem....I'd say the stem is the culprit. Put a cheapo on instead and try to recreate the clunk.
    Yes and Yes
    I had a Thomson stem and it always seemed that the spacers under the stem (10mm and 5mm) were tight when I preloaded the headset and tightened the stem bolts according to Thomson's torque #, but after a 1/2 dozen rides the spacers seemed to be looser than when I set everything up.
    Now I have a RF prodigy stem.
    It will make that noise with the front brake too.
    Do you think it has something to do the stem headset interface?
    What I am scared is of my headtube becoming ovalized.
    If you have an old rigid fork lying around [or on another bike], try putting that one on and testing to see if the clunk is coming from the stem/headset area - this way you take the fork out of the equation.
    Curious - how old is your headset, and what kind is it....and are you using carbon spacers.....?
    Longshot - check to see if the bolts securing the disc to the hub are loose....this would cause a brake induced clunk sound also.....
    Lastly, if the big bushings in your marz are shot, you'll notice the fork will clunk slightly w/ the brake on when you rock it forward/backward w/ brake on.
    Eureka! .........Strangest Thing (long)
    Well, I started by removing the fork from the frame. Checked the headset cups. Pulled and tugged on both of them. Tight as can be.
    Then I went to check the crown race, that's when I noticed the clunk sound. I moved the fork around and noticed the sound again. It seemed to be coming from the ETA side leg. I thought that something must be loose inside.
    I removed the bottom nut, drained the oil, and pulled out the ETA side cartridge.
    Everything was intact, except the spring had a lot of play. It moved freely between the top-black spacer and the bottom seat on top of the ETA cartridge (1-2mm play). I can easily see it hitting the inside of the fork. This amount of play cannot be normal, and I did not recall the fork doing this when it was new.
    I removed the top cap, and with a 10mm or 9mm wrench, tried to tighten the red nut at the top. It didn't feel like I was doing anything, but sure enough, I was able to remove the play and the spring had some pressure against it.
    Now I hope it stays put. I would hate to have that sound and play come back in a few months.
