Results 1 to 9 of 9
    Reputation: erguy's Avatar
    Smile chainguide for 08 rfx
    just a noob question... any suggestion on which chainguide would fit best on rfx 08
    i was looking at e 13 drs but not sure if it will fit. thanks
    Making fat cool since '71
    Reputation: ImaKlyde's Avatar
    Sep 2004
    Just went through this...if you have Race Face cranks: good freakin' luck with it being easy. BlackSpire Stinger can happen. With RaceFace cranks you'll have to grind down your chainring bolts or spring for low-profile and then maybe still have to grind them down as well.
    Short answer: the Stinger works really well so far for me (and it's cheap).
    Brock...
    Are the wheels roundish? Ride it.
    Disciples Of Dirt, come ride with us.
    i have a shimano xt 08.
    Sep 2004
    You will be groovy with the bottom bracket mounted chainguides then with XT's. The Stinger will set-up easy for you.
    Brock...
    Reputation: airwreck's Avatar
    get one that no one has tried yet and let us know how it works
    http://www.e13components.com/product_ds.html
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    beg cheesey for 1 of his spare heim 3/mrp lrp setups. there is none higher. or wait till e-13 redesigns it now that they bought heim. should be this spring.
    No, I'm NOT back!
    Former Ninja
    erguy,
    If you want somthing cheap that will still give you top performance, then the DS is what you want. Airwreck posted the picture above of the BB mount version that you would need. It should be available right now from your LBS (or any bike shop that can order from BTI...they've currently got 12 in stock without bashguard).
    Everything should work out, and there is 1mm of adjustment in the BB mount setup as well.
    Cheers,
    philip @ e*thirteen
    sounds like CC's shop doesn't have a BTI account
    thanks for the heads up Philip!
    yeah we do. i just prefer the simplistic beauty and absolutely perfect performance of the heim/lrp. then again, i havent used a drs so who knows. tons cheaper, thats for sure. if it works anything like as well as the srs, id be game. now theres a fine part. whats cool is in another thread, philip posted you can swap guide parts for the newer lg-1 as it shares the same plate. very cool news.
    hey philip: whats the word on the new heim? got some design details and a release date yet? just curious. thanx man.
    No, I'm NOT back!
