Poll: Chain brand?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 28 of 28
    Time flies...
    Reputation: xjbebop's Avatar
    New question here. Which Chain do you prefer: Sram or Shimano?
    I've been seeing lots of posts concerning shifting problems, and recently have been having some myself. I'm aware of the importance of proper initial setup and usually don't have any problem with it. While narrowing down the possible causes I started wondering how much chain make/model has to do with it. I think the last one or two chains I used were Sram PC971, which I saw many negative reviews of when I checked a few minutes ago.
    So, to ask those who know ( the homer nation...), are there any "clear" winners and losers as far as the current crop of available chains goes??
    ...every day sends future to past...
    \|/Home of the Braves\|/
    Reputation: RedRocker's Avatar
    SRAM shifts fine and they're just so easy to take on and off. I haven't owned a Shimano chain in years and don't feel the need to.
    Big hoopy.
    Turner Sultan / On One Inbred
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    I've used both brands, and sometimes you just get one that was stamped on a monday.....it's really a crapshoot.....
    Remember, SRAM chains are really Sachs chains which is a german company that has it's chains made in taiwan or china or who knows were.....Shimano chains are made in a small mountain top village in Shimanostan, east of the Rangorogor range west asia....KMC, I actually like those spunky North Korean chains - have had the same one on my cyclocrosser for 4 years! Amazing North Korean stubborn durability! And very expensive, if you are a North Korean!
    Constant: you will eventually break a chain, no matter the brand....and, it will wear out faster than you expect, so stop fretting and just get one that is under 20 bux w/ free shipping!
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    ive been runnin sram/sachs chins since 1993 and dig em. im a 990 man myself. shimano tends to shift better and wear out faster in my experience. however squish told me about a test someone at barnetts did with a sram pc-99hollow pin, a shimano xtr and a whipperman lightweight. the sram wore out 1st quickly followed by the shimano (close enough not to matter) and the wipperman outlasted both in mileage by 3 times. its interrestin to note the whipperman is roughly 3 times the price and 20 to 40g lighter. you decide but ill stick with the srams for now.
    No, I'm NOT back!
    ride
    Reputation: ignazjr's Avatar
    I've typically run 971 chains, but I've got a 951 right now that's been great. I'd be happy running either Shimano or SRAM with regard to durability andshifting. I can't stand that Shimano pin, though. The masterlink is where it's at for me.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    so true. that friggin pin is a royal pain in the ass and way too expensive. give me a power link any day on any chain.
    No, I'm NOT back!
    Just Grin and HUCK it...
    Reputation: SilverSpot's Avatar
    Been using the sram PC99 - PC971 chains for many years with no problems whatsoever. Always had crisp shifts and usually get pretty good life out of them. I heart the powerlink too.
    MCM# 2007.1
    RaD
    RaD is offline
    Trampelpfadbenutzer
    Reputation: RaD's Avatar
    I have been running both in the past- SRAM and Shimano and I think the Shimano chains shifts a touch better on Shimano sprokets.I also do not need a powerlink because the only time I take off the chain is when I replace it.The last broken chain I have seen was about 10 years ago but I am not sure if it was Shimano or Sachs.
    Later
    RaD
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Sram. Those one-use Shimano pins suck butt. I have used Sram chains back in the day of 8 speeds and now in the brave new world of 9 speeds. Every level of quality. I wish chains lasted longer in general, but I have had so few problems with the Srams that I stick with them. They play nice with Shimano and RF rings.
    My video techniques can be found in this thread.
    Captain Underpants
    Reputation: Random Drivel's Avatar
    I ram dura-ace for awhile (smooth, quiet) but have switched over to SRAM. Nice shifting, and much eaiser to clean, just remove the link, drop it in a small parts container--you don't need one of those lame chain cleaners.
    Quote Originally Posted by cactuscorn
    I'm holdiing out for the day that Performance has some of these mismarked as a sale item . . .
    Mar 2005
    whipperman!
    I will admit that the older sedis/sachs chains were great, but I have had several major failures of newer SRAM chains, including a side plate torn in half and a issues with their quick link. I am not impressed with SRAM quality in any way...buy a product, produce it cheap in asia, and sell it for more $.... The new xtr/durace chain is great except for the lack of a link. In the PNW muck, the ability to remove a chain to clean it every week or so is paramount.
    the wippermans give you the only (IMO) benefit to the sram chains with the quality of a high quality german made chain.
    trail fairy
    there can be only ONE Sram for me!
    for me most of these issues are caused by cross over or mixing of Shimano and Sram, I run an all Sram DT and the only times I get shifting probs is when Ive worn out a middle ring or chain normally this gets highlighted in wet conditions, I run a park tool chain scrubber over my chain regulary and I get allot more wear outa my drive chain than most.
    I only run 991 chains and 990 cassettes this may help possibly Ive also found that 11/32 reduces stress on the chain over time comparded to 11/34, this works well for the Spot, Im changing out my standard setup on the RFX though to an 11/34 rear cluster with a 24/36t front ring combo, which is a better balance on a dual ring setup so Ive found on my buddies bike and now mine.
    Also I don't rate Shimano crank rings (or cranks except Saint) I use Race Face Atals & Deus and there rings last me 3 times longer and imo help the wear of my chains and cluster, Ive finally converted my buddies to Race Face as well after running RF rings on the XT and Saint cranksets, they realised in there own time the quality and my experiences with RF, this has taken me years of research and many tantrums with Shimano I haven't suffered fom Shimano for 3 years now and its heaven, I can only hope Sram keep doin what theyre doin and improving it not cutting budgets and the same goes with Race Face, I will use what works and is proven for me first not by the name of the product, LOL Im waiting for Ts coments on Diety I can here him now one more thing a moron can tune Sram and that helps 2
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    DGC
    DGC is offline
    Reputation: DGC's Avatar
    SRAMano
    Mix em, get the best of both worlds........in terms of the pin hassle. I have been running the SRAM master link for a few years now on my Shimano chains, never a problem with that mix.
    For the last 2 years or so, I have been switching back and forth each time on chains. SRAM, then Shimano on the following chain change out. This last time I put on all new rings and cassette, ran the PC-991. It was loud-shifted slow. After 1 week, I put a Shimano on and it all went back to smooth, quiet, crisp. We have also seen quite a few broken SRAM PC 971 chains for some reason. A few of the same riders who broke those and a few PC-991's were running Shimano forever and no problems. It always used to be the other way around. Go figure. Try both SRAM and Shimano chains and see what works best for you.
    OUCH...!!!!!!
    Cheap and Often !!!
    I use SRAM's because they are cheaper than Shimano's. I have had less problems with Shimano's. The SRAM pins have broken twice in five years, but Thank God I carry a spare link in my patch kit. The Shimano chains shifted better, the pin was a pain, I never had to connect the chain on the trail, but that would suck; in those days I cleaned my chain after every ride.
    Now, I use Pro-link lube and I wipe my chain, but I never clean it. I use a chain stretch tool and I change the chain long before it gets to .6 % stretch, ie. when the chain tool drops in the space and it is snug on both sides against the chain.
    The more expensive chains have a better finish or hollow pins, but I don't think they are much better. I also change my chain when the bike does shift well and I buy chains on sale at my local Performance store, because they are frequently on sale.
    Cheers,
    Kane
    P.S. I'm glad you showed the picture or I wouldn't have believe you, because I have not previously, read your writings. I used the SRAM link on my Campy 9 speed road chain with no-problems. Glad to meet you.
    Quote Originally Posted by DGC
    Reputation: rick rocket's Avatar
    May 2005
    all the sram chains are the same linkage only the finish is different or as on the high end it is drilled out for weight saving. so ur cheap pc51 is the same as your pc71 only its dark grey and not chrome finish etc.
    and that came from sram chief president in an english cycle touring magazine!!
    they just know how to have us all over!!
    my vote .....go for the cheap one for winter......ride a lighter weight one for summer!!
    God....whatever i feel like doing!!!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by zkampyman
    Shimano's top end chain is usually $30-35, SRAM's top end chain is usually $50, and I've seen it more in places. The funny part is that the sram uses hollow pins, but weighs almost exactly the same as the dura-ace/xtr chain. Most people that I've ran into that are "scared" of shimano chains used them many years ago before they switched to the "mushroom" shaped pins, and I must say I have not found a stronger chain, and I've broken pretty much everything. The pins are easy to insert if you have a chain tool, but I just keep a few power-links in my camelback for quick repairs on the trail, even though I use a shimano chain.
    I change my chains every 4 months or so, if I let it go any longer then it screws up the rest of my drivetrain. I put a ton of stress on my drivetrain, but I also never use the granny and it seems to give me a little more life out of my components.
    Reputation: Qfactor03's Avatar
    Dec 2005
    I swore by the PC-99 but they went and discontinued it. I am now running a 991 and so far no problems. I have broken numerous shimano Dura Ace chains and have yet to have one of the 9 series SRAMs fail. I'm considering trying the new X9 for rear der and shifting duties, but will not touch a SRAM cassette.
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    Same exact experience here! I've ran a mix of Shimano/SRAM over the past few years. For the past two, I've mostly ran SRAM PC-99 chains, which were great. Then I got a few PC-991's and also experienced some problems. First PC-991 I ran suffered from a nasty seized link – this after only 2 rides. Then the second chain was defective, then the third was loud and didn’t shift like the PC-99’s did.
    So I recently mounted an XTR chain and now my dive train is quiet and the shifting is smooth/crisp. I did try to run a powerlink but for some reason it didn’t want to stay on like on the SRAM chain – it was really loose and easily came undone. DGC – you never had any issues with a powerlink coming off accidentally while riding?
    I've been using the SRAM stuff for closer to 10 years now. I've noted the newer stuff might not last as long as the previous versions. I can't exactly state this because I'm on a different bike with a different riding style. What I might try to do is to get a bottom end shimano chain with the mushroomed pins and carry the missing links on me. I don't know if I'll suffer fewer snapped chains by changing back.
    DGC
    DGC is offline
    glad you asked that
    Quote Originally Posted by Acadian
    No never had one come apart. But the reason I am glad you asked is I did not say that the SRAM link fits loose. The pin length of SRAM 9 speed chains are different in length vs. Shimano, not by much but enough the link fits loose. Still after a few years of running them on a Shimano XTR chain, never has it caused any shifting problems, and it never has come apart.
    The picture wont show any slop or looseness, and once you have a few rides on it mixed with dirt and lube, it fits like it does on the SRAM chains. Still I have never had a problem with this set up.
    OUCH...!!!!!!
    yeah, the 99 was the shiz as far as im concirned. not that i dont like the 990 and 991 but id say they dont last quite as long or run as quiet. still, id take em over the shimanos till im convinced otherwise.
    No, I'm NOT back!
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    I've never skimped out on my chains. Always got top grade from either company. Each Shimano chain I've run broke within a couple of months. I've never had a failure with a SRAM. I've been changing my chains every season on my main ride(sometimes twice, depending on wear) and as necessary on my other bikes.
    I also hate the grease Shimano packs their chains in.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Good deal – next time I replace my chain I’ll give the Power Link a try. I’ve got a full bag of them. I was going to give it a try but was worried it wouldn’t stay on since it was very loose (e.g. I could assemble and break it apart very easily – more so then when ran with a SRAM chain) especially on descents when you’re not really peadalling and the chain is slapping all over the place.
    Reputation: miles e's Avatar
    Good point. They're not exactly easy to get off once there's a bit of grit in there. That said I did have the link go AWOL while bombing down Porc at THC. This was the first time this happened to me in ~8 years of running DuraAce chains w/ the SRAM link, so I'm not too worried about it being a regular occurance.
    ''It seems like a bit of a trend, everyone trying to make things longer over the last couple of years" Sam Hill
    DGC
    DGC is offline
    neon grease
    Quote Originally Posted by MK_
    _MK
    I always have to use a good metal cleaner to get that packaging grease off Shimano chains, what a pain. Possibly (?) that way because they have to float them on a boat on the ocean=rust.
    OUCH...!!!!!!
    Time flies...
    Got some good info and food for thought here now...thanks everyone!
    as for the shipping goo most new chains are coated with, I believe it's some form of cosmoline, which is used to coat many metal products (automotive brake rotors, for one) to keep them from rusting until put into service.
    Just clean that crap off and lube as normal...
    Mar 2005
    .... I did try to run a powerlink but for some reason it didn’t want to stay on like on the SRAM chain – it was really loose and easily came undone....
    Find a whipperman quick link. They seem to close a little more solidly than the SRAM ones IMO and they cannot come undone unless the link is bent ~ 90 degrees, both in front and behind the quick link (make a 'Z' to remove it)
    Nothing here
    Reputation: Unknownrash's Avatar
    Sep 2004
    So yer saying that the Wipperman won't stretch as fast as the other two? Or are we talking about shifting performance?
