    Lay off the Levers
    Reputation: Bikezilla's Avatar
    New question here. Can You Spell Banjo without the "O"?
    Interesting.
    I just received these brake lines from Galfer. Decent looking stuff. Lightly coated with clear plastic. The price seemed better that Goodyear and I heard they do color coatings so I gave them a shot. It turns out colors are only avalilable only on motorcycle hoses.
    Anyway the thing is, these are for Shimano calipers and my orig hose has a recess/groove near the ID of the banjo for a tiny O-ring seal. This doesn't. It does come with metal washers but I wonder if this will work?
    I'll call the Galfer but I'd thought I'd share the question here too.
    Faster is better, even when it's not.
    Outcast
    Reputation: Renegade's Avatar
    'Zilla, are you starting another thread that's just gonna end up a whole lot of trouble?
    not so super...
    Reputation: SSINGA's Avatar
    First of all...it is GoodRIDGE not goodyear - get your bling straight Second - nice looking lines!
    Mount 'em up and give the lever a squeeze. That should be a good indicator of how well they seal. Maybe O-Ring not needed on their version???
    FWIW - the Juicy 7 uses O-rings around the Banjo in a recess like you discribed and the Goodridge replacement lines also had them.
    PS...the Goodridge is available with colored Ano fittings
    Nothing to see here.
    Lay off the Levers
    You mean like the GoodRIDGE blimp?
    I like your test idea. Let's try it on your bike, at the top of a hill Mmmkay?
    Ano fittings...NOW you tell me?
