Results 1 to 8 of 8
Thread: Burner and Tnt
    Feb 2005
    Burner and Tnt
    Hi all,
    I'm assuming that there are HL rear ends for the Burner in case of warranty, but does anyone know if the TNT rear will be compatible (just bolt right on)?
    Thanks.
    Burning Burner
    Reputation: skritikos's Avatar
    Isn't the rear of the Burner the same with the 5-spot one? I think that we will not have any problems.
    Anyone that can confirm the above?
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Yeah, the burner rear, meaning the chain and seatstays are identical to the Spot. I got this confirmation from Casey, when I first bought my Spot and was contemplating putting the black rear from my Burner on it.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Feb 2005
    Thanks guys, I didn't know the Burner rear was the same as the Spot. I feel better already
    Team Blindspot
    Reputation: S-Works's Avatar
    Quote Originally Posted by esenkay
    Does than mean your could 5-spot rockers on a Burner and get 5" of travel?
    Astigmatic Visionary
    Burning Burner
    Quote Originally Posted by S-Works
    Different front triangle, so probably not
    Can Tree Member
    Reputation: Dad Man Walking's Avatar
    Sep 2004
    Might just get 5" of nothng...
    Quote Originally Posted by skritikos
    I suspect that the 5" frankenburner would not live...the seat tube pivot location looks like it is much lower on the old-school HL bikes (XCE, Burner), in addition to being behind the tube vs. in front of it. On the ICT/TNT bikes, the rockers are much shallower (less triangulated). If there was even clearance for the shock in front of the seat tube, you might find yourself looking for a 5" i2i shock to put in there.
    Your question begs a different one, though. If the rear trrangles are identical, and if the Burner/XCE design does not create patent infringement issues, would you still be able to get a new HL triangle for your bike if you needed one, or would you have to settle for the TNT triangle?
    And...we have heard (and some people have now personally experienced) that the TNT bikes ride nearly identical to the ICT/HL bikes. But, what happens if you bolt the TNT triangle on to the XCE/Burner?
    Dad is sad.
    Very, very sad.
    He had a bad day.
    What a day Dad had!
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    i had this same discussion with david and he says no way. cant swap rockers between fwd pivot spots and rear pivot burners. 4" is as much as a burner will ever see.
    from now on its tnt folks. they will bolt onto a burner just fine. off to work i go!
    No, I'm NOT back!
