Results 1 to 12 of 12
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Burner Fork Set-up/Fluid level
    Its a 13' 160 CTD 34 set @ 150mm and using a 14' FIT damper. Using the Fox recommended 25% of sag 150 x 25% or 37.5mm which equates to 175 psi in descent mode. I have the rebound set @ 8 clicks of 14 and ride the fork in trail mode. The forks performs really well but it felt like it was riding kinda low in its travel. It wasnt diving or skipping but the O-ring looked like i was closer to a possibly 30% + sag. The only causality i can think of is that when Fox replaced the 13' OB damper with the 14' FIT damper they either recycled the old fluid or underfilled the fluid when they replaced it. Fox recommends only 30mm of fluid in each leg whereas i've read time and time again about people adding as much as 20mm more fluid in each legs resulting in improved performance. So, my next step is going to perform a oil change but i'd like to survey other burner/35 150 CTD owners to ask if theyve made any changes to their forks oil levels with good results. TIA
    No Clue Crew
    Apr 2005
    The fluid in the lowers is lube oil only.
    jrm
    jrm is offline
    According to this the oil is in the lowers.
    <iframe width="560" height="315" src="//www.youtube.com/embed/eh-sIrnC8xs" frameborder="0" allowfullscreen></iframe>
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    You can't change the fork's riding characteristics by adding more oil to the lowers. Well..I suppose if you add enough oil, you can get the fork to hydraulically lock and shoot the seals out of the lowers..that might be a fun thing to try.
    FIT damper's oil is contained in a cartridge/bladder combo and has nothing to do with the splash lube oil in the lowers.
    www.msmtb.org - Mississippi Mountain Biking
    No Clue Crew
    Apr 2005
    Possum just explained it much better than my pathetic initial sentence.
    jrm
    jrm is offline
    well, allrighty then, found this. Still need to find out if that external compression cap that replaces the CTD cap is available ala carte
    Push Industries - FOX FLOAT 34mm 150/160mm Travel Air Cap
    Reputation: freebiker's Avatar
    Mar 2006
    try running your fork at 3-4 clicks from full fast rebound
    Reputation: ctopher63's Avatar
    Quote Originally Posted by jrm View Post
    I had my '13 CTD pushed this week and it's shipping back to me now. I'll let you know how it feels after I get a few rides on it.
    No Clue Crew
    Apr 2005
    After closer reading, are you running 175 psi in the fork?
    Before I sold it, I ran a 34 Float CTD 150. Proper sag for me was roughly 75 psi and I weigh about 200 in gear.
    jrm
    jrm is offline
    Yeah its 75. how much rebound did you run? Looking forward to giving it another go this weekend.
    No Clue Crew
    Apr 2005
    Rebound is a super-individual setting. I tend to run full-fast minus 3-4 clicks.
    Ctopher, can't wait for your input when getting your Pushed forks back. Did you upgrade to the travel air caps? I was wondering if it's worth the $80 upgrade?
  1. Burner Fork Set-up/Fluid level
    By jrm in forum Turner
    Last Post: 10-14-2013, 02:56 PM
  2. Qubo Power fluid trainer noise level ?
    By NRS_Comp1 in forum XC Racing and Training
    Last Post: 09-19-2013, 11:44 AM
  3. Burner - Float 34 Oil Level
    Last Post: 06-25-2013, 05:35 AM
  4. Replies: 1
    Last Post: 05-11-2013, 06:28 PM
  5. Fox Fork Fluid - Ahwatukee Area
    By FrankAZ in forum Arizona
    Last Post: 05-11-2011, 07:34 AM
