Results 1 to 3 of 3
    Burner Chainstay Length?
    I just looked at the new (for me) Turner website and noticed that the 5 spot and Burner have 16.9 chainstays. Yet I distinctly remember the old site (about a month ago) saying they had 16.7 chainstays. Which is correct?
    My wife's burner and my XCE have the same length chainstays.
    They appear to be about 16.9". Definitely not 16.7".
    Dave
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Quote Originally Posted by SXSW
    I clipped this from an earlier thread:
    Quote Originally Posted by Bikezilla
    Chainstay max inside width/tire clearance
    RFX: 3.5"
    Burner: 3"
    5 Spot: 3.125" (3-1/8th) hey that's what I got. I'm sure the Burner measurement is just rounded a tad.
    Outside chainstay width at same point:
    "..is same for both" Burner & RFX (you didn't say what that was though)
    5 Spot: 4.25" (eyeballed)
    Stay tubing width:
    RFX and Burner both have 22mmx22mm tubing for stays.
    5 Spot also has 22mmx22mm tubing.
    Seatstay length:
    "measures same." for RFX and Burner (you didn't say what that was though)
    5 Spot: 14.5" (eyeballing rocker pivot to axle)
    Chainstay, main pivot to axle:
    RFX: 400mm
    Burner: 365mm
    5 Spot: 406.4mm (16")
    Main pivot to rear pivot:
    RFX: 330mm
    Burner: 335mm
    5 Spot: 333.375mm (13-1/8")
    BB to rear axle:
    RFX: 430mm
    Burner: 407mm
    5 Spot: 425.45mm (16-3/4")
    Faster is better, even when it's not.
  1. Crank arm length, and benifits of.
    By The Tree in forum Downhill - Freeride
    Last Post: 08-02-2012, 08:06 PM
  2. Pros/Cons of swingarm length?
    By SinglePivot in forum General Discussion
    Last Post: 04-14-2004, 11:56 AM
  3. Calculating chain length for a SS conversion
    By od_the_roadie in forum Singlespeed
    Last Post: 04-02-2004, 03:58 PM
