Poll: Burley Spot or Beefy RFX????
Results 1 to 5 of 5
    locked - time out
    Reputation: TIMBERRR's Avatar
    Feb 2006
    Burly Spot OR Beefy RFX ( aka The Proto )
    Which one.
    Personally I think the current spot can be built Burly already so......WHY!
    We need a Real Mans Bike. DW-RFX!!!!
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    A DW Spot 29er made overseas so it's affordable and please get rid of the ugly elevated erector set rear end.
    150mm Spot. At ~68deg with a 150m fork.
    160mm seems too large a step forward for a trail bike. That is going to be using a 150mm 32mm stanction fork for the majority of cases.
    Hear no evil. See no evil. Speak no evil. (Do it !?!)
    locked - time out
    A tough bike, can take any fork, designed minimum around a Lyrik 170 or Totem. 8-9 Pounds (or more with coil options). 1.5
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Just throw a 1.5 headtube on the Spot. If you want slacker, you can have it slacker with the +/- reducers; same if you want it steeper. Slacking out the HT will help lower the BB a tad as well since the fork won't be as vertical, although, truthfully, I can't imagine it would produce significant difference?
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
