    Reputation: Vikingbiker's Avatar
    New question here. Brake line length for XXL Sultan
    Here is my set up, Reba 120, 90mm stem w/ 100 degree rise. 19mm rise on my bar. Most likely I will run the uncut steerer.
    My question is what lengths do I need. Formula K-24s comes pre-bled. I am assuming that I need the 100cm front and the 165cm rear. This is my ADD engineering calculation. http://forums.mtbr.com/images/smilies/mad2.gifAlso, is it worth it to have them cut to length? http://forums.mtbr.com/images/smilies/confused.gif If so, has anyone done it, and what lengths did they use?
    Az HS Cycling League
    Reputation: stew's Avatar
    I am...
    using Shimano XT's on my XXL. I used them uncut. I believe they were 1500 in the rear. They are the perfect length for me. I believe the front are 900. I am using a Reba 120 in the front with maybe 1" trimmed from the steerer. Hopefully that helps.
    Support Arizona High School Cycling League
    www.arizonamtb.org
    keholio
    Thanks for the measurement Stew. Good info, I have an XXL coming in a few weeks.
    Reputation: Tom93R1's Avatar
    Jan 2005
    I have one coming in a couple weeks too, thanks!
