Results 1 to 17 of 17
    I just wanna go fast!
    Reputation: bdamschen's Avatar
    Boneheaded older RFX questions
    This may have been covered at length a couple years back, but for one reason or another I can never seem to get results when I use the search function.
    I've got an 07, or maybe 06 RFX that I set my dad up with when he got too old for his hard core XC bike. I've heard of people swapping in some 5 spot parts to get slacker geometry, but I don't know enough about turners to know which parts and where the heck to get them.
    I'm guessing the rockers for sure, but do I also need to swap in a 5 spot rear triangle? Can I use the same length and stroke shock or will I need a new one? And last but not least, where the heck can I get these parts? Do I need to just keep watching forum classifieds to see if anyone is selling them or can I order the parts from turner still?
    Thanks for putting up with a Turner noob
    Reputation: wilks's Avatar
    if it's an 07 all bets are off - 06 you can frankenbike...post a pic of the bike
    Quote Originally Posted by wilks
    It's down at my dad's house in so cal. I'm visiting them for easter, so I figured I'd try to get some of the parts together and set it up when I'm down there.
    I think it might be older than I originally thought- the rockers are solid with no holes machined in them, so I'm guessing an 06 or older? It's not a horst-link, if that helps too...
    *EDIT*
    Just dug through a bunch of pics. It's definitely an 06
    Reputation: airwreck's Avatar
    why's that?
    the 07 can be fit with a custom shock with a slightly reduced eye to eye.
    Saw the 5.5 rockers on turner's store. Can I just get those and swap out the old rockers? Or do I need to do something else as well?
    Quote Originally Posted by bdamschen
    yes. if you want lower and slacker still then get a spot seat stay.
    Quote Originally Posted by airwreck
    Does Turner still stock older spot seat stays?
    why's that?
    good point - I was responding in terms of swapping stays etc...but you are obviously quite correct - an Avy 7.775 X 2.25 would slacken and lower a 07/08 RFX.
    Reputation: nybike1971's Avatar
    They may or may not but they are most likely not for sale and reserved for crash replacements.
    Here is a summary of the mods on a '06 RFX:
    - Both the RFX and 5 Spot have the same shock length so no change in shock is required. If you do replace the original rockers with 5.5in rockers, you will most likely drop ~50lbs/in in spring rate.
    - The '06 Spot seatstay is the most effective way to lower the bike and slacken the front end a bit. The 5.5in rockers do not change geometry appreciably but give more progressive travel than the RFX rockers. Pedaling performance is better with the 5.5in rockers, but the ride is plusher with RFX rockers.
    - You can run either the RFX or Spot chainstay with the Spot seatstay. The RFX chainstay (longer) gives a more stable ride at high speed or in chunky terrain and has more tire clearance. The shorter Spot chainstay gives snappier handling.
    Quote Originally Posted by nybike1971
    Nice, you rock.
    so... who wants to sell me some spot seatstays?
    Bite Me.
    Reputation: cutthroat's Avatar
    ??? I ran Spot stays and 5.5 rockers on my '07 w/o problems. I swapped back to the stock rockers but it was fine
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    Quote Originally Posted by cutthroat
    If that achieved lower and slacker over stock geometry I'll get my coat and promise to never answer a lower and slacker RFX question again!
    Cutthroat- Sounds like spot stays on a 07 are a bad idea, sell me yours.
    Bite Me.
    The RFX now resides in Arizona regrettably. I realize now it was a mistake to part with it. Greg at Turner actually sold me the stays - I assume they came off a trade-in. Give him a shout, maybe he can find some for you. They also show up on Ebay, but rarely.
    Flyin Canine
    Reputation: shanedawg's Avatar
    Brian, check out this thread. Looks like you might have a lead. btw, nice job getting your dad on a turner. Your next! DHR here we come.
    Devil Mtn
    Reputation: reklar's Avatar
    Anybody happen to know the geometry changes (angles) for the 06 RFX with:
    a) 5.5 rockers
    b) spot seatstays
    c) both
    Quote Originally Posted by reklar
    a) 5.5 rockers
    b) spot seatstays
    c) both
    06 RFX/5 pack leverage curves and geometry measurements
