Results 1 to 56 of 56
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Big Man Needs Big Gears (1x9 Cassette)
    Hey howdy, Been MIA forever I know...long story...too long.
    Annnnyway, I'm still rocking my '08 TNT XL Spot and I'm still deep in the Clydesdale end of the scale.
    Opinions: Is switching from a 11x34 to an 12x36 9spd cassette going to make a big difference in hard climbs? and if so, would going to a 10spd 36T be even better (due to the ratio spacing)
    Here's the background:
    I the rides around here have tons of short but draining, steep, technical climbs. up,down, up up up, down up... every few mins, not long spinning grinders.
    Late last season I changed my Spot from a 2x9 to a 1x9. I dropped the granny and only have 32t chainring now.
    I like the simplified setup, and the reduction in chain slap that came with adding a guide and a short cage Rder.
    BUT
    It appears my climbing has degraded tremendously. I'm standing where I used to spin, and Burning out much much sooner on the really hard climbs, It also seems my recovery times are taking longer if I recover at all. overall I seem to suffer more than I flow.
    A lot of the climbing is with zero momentum and is inch for inch pedal to ground. This seems to me typical of pushing a ratio too high for me. My knees are noodly all the time, my quads too.
    I've put in a fair bit of training time but it almost seems like I'm suffering from overtraining where the harder I try the less I accomplish.
    Is going to a 36T going to help much or do I need to go back to the Granny?
    Anyone with a single chainring riding 32x34? or do most folks use 36T?
    Now I know being in better shape and personally lighter will help but first I have to get there and I'm not doing so now, I feel like I'm getting weaker, slower and having far less fun. I can hammer my ass off on rolling, DH or even steady grinders but hauling 240lbs up the steeps is sapping me where it did not nearly so much before I tossed the granny. Seems to me I'll be better overall if I'm in a reasonable spin/trundle than the edge of stall and expiration the entire climb.
    Will a 36T do the trick?
    Faster is better, even when it's not.
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Holy Chit, it's the Zilla out of cryostasis (hibernation didn't seem long enough).
    I'm okay with 32 up front and an 11-34 cassette out back. Without changing your whole drivetrain you could try and pickup a Shimano HG61 12-36 cassette to give that a try.
    Rolling on 29", 650b, 8.3" and 23mm
    Lay off the Levers
    Quote Originally Posted by 6thElement View Post
    Heh. While I'm between jobs I'm trying to harden up between interviews.
    I actually bought an HG-61 last fall and forgot I had it till today. I'll put that on with an extra couple of links and see what's-what. Comparing it to a 10-spd the ratio on 3 largest cogs are the same and that's what counts the most for me.
    The tooth count of the 12-36 is +2T on the 3 largest cogs compared to the 11-34 so it should be a help across several gears.
    What suxors is it's a stack not a set so each cog is a single plate spider and all rather than a bunch pinned to a carrier. These tend to dig into softer driveshells. I destroyed a CK alloy shell with one of these once. (different ratios though) Since then I have a HD driveshell on my CK and a steel alloy on my XMXL. so I should be G2G. Just need to add some links I guess... I wonder...How many for 2Tmore?
    What you might be able to do is pickup a wider Ti 36T cog to use behind a decent cassette, so it won't chew the freehub. Then you would just need to juggle the smaller cogs and use a suitable lockring. I think Actiontec used to make a suitable 36T...
    Lay off the Levers
    Thanks.
    I think I'll be alright on a HD or steel freehub. I hope so anyway!
    If I like it enough, maybe I'll get a 10 spd shifter and a proper cassette. (as compared to the HG61 stack)
    I saw a thread about a company that makes 30T chainrings... that might be next if this is not pedally enough.
    I'll stick with my chainguide though.
    Reputation: airwreck's Avatar
    You must be generating some incredible amounts of torque pushing those gears uphill. Wouldn't this lead to failures, bent cogs, exploding chains, etc?
    Anyway, I'm no help, my single front ring solution requires a chairlift or shuttle.
    Reputation: gmats's Avatar
    Apr 2005
    Quote Originally Posted by airwreck View Post
    I guess that's the issues I've been facing for some time. I like climbing everything I can find before descending. Therefore, gears, gears gears..............
    Note: I do not have the 11 or the 36 on my gears, I just left them in the spreadsheet to have numbers.
    Zilla, there isn't much difference between the 34 and 36, I tried that on my bottom end of my cog-stack. Ended up going 38. That 30 front sounds like the ticket. I love the 29 in front on my bike, I can stay middle for a very long time and very rarely need the 20 or the 42.
    Lay off the Levers
    Quote Originally Posted by gmats View Post
    Holy cow, where do you get your components? I'd love to rock a 29 chainring and/ or a 38t cog.
    Do you need special cranks for that? From what I can tell even a XT HT-II needs to be filed down to support a 30T much less a 29.
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Or you could pick up the Widgit: Widgit | Get the MTB chainring that will turn your ride into a lightweight mountain bike.
    You can go as small as 28T on the front chainring.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Moosehead
    Reputation: moosehead's Avatar
    Wazzup Homies?
    Zill, your title says it all. Agree with Gmats. Fuggetabout what the jackrabbits are suggesting, they aint carrying around an extra 75 lbs of hard work like us clydes.
    Beware of turning your back on grannie:
    Therefore recommend:
    For graphing purposes, following gear inches with 26" wheel and meaty rubber:
    32x34= 22.8"
    32x36=21.6"
    24x34=17.2"
    24x36= 16.2"
    The new Shadow RD and others versions are pretty stellar at reducing chainslap.
    Cheers.
    Reputation: wilks's Avatar
    Hey Zilla - 6th is hella fit and strong based on his exploits. I think mere mortals like us need a little extra help. A 36 cassette definitely helps if you're running a 32 up front for the trails we ride and helped me tremendously and to the point that I ditched my granny - But at the end of a 3 or 4 hour ride at say Blue I found myself occasionally wanting one more gear so I got XX1. I rarely use the 42 out back but it's nice to have. Plus the 32 x 11 doesn't spin out on the single track just occasionally on the fire roads.
    Outcast
    Reputation: Renegade's Avatar
    Most old fat guys that I know either buy a motorcycle, or give up altogether, and just settle down in front of the TV and rot. Which choice suits you, "he who posts like once a year?"
    You could try actually working out once in a while. Jeez.
    Shut up and pedal, is what people tell me. Come out here to 9,00 feet of altitude and let my 56 year old corpse kick your butt on some climbs.
    Miss you.
    Apr 2005
    Quote Originally Posted by Bikezilla View Post
    I run a 29 middle by using old school square taper 94mm/58mm cranks. It might be tough to find 29 tooth chainrings these days, I'm starting to run low.
    I saw them at Homebrew (guess they're gone?) and now here:
    5 Bolt 94mm BCD Chainring
    The 38 cog is Action Tec set up with my 9 speed Shimano bar end shifters (thumb shifters on Paul's). I loose the 11 and make it a 13-38 cassette. I've tried a few other "Steel" stuff from ebay but bent them. The Action Tec has lasted me two seasons. My friend's running the 38 Ti with his 10 speed Shimano XT set up.
    Lay off the Levers
    Quote Originally Posted by wilks View Post
    I rode with 6E...I'm pretty sure he's got a couple of midgets stashed in each leg.
    I'll try the 36x11 and look for a 30T chain ring while I research a few of the creative options mentioned above.
    3-4hrs at Blue? Right now 2 will put me near cardiac arrest. WTF? I must be doing something wrong.
    Lay off the Levers
    Quote Originally Posted by Renegade View Post
    Miss you.
    Rennybro!
    9000 ft? Come out here and I'll show you a dozen 450ft climbs that'll make you wish you had a lift pass. And that's just getting out of the parking lot.
    Good to be back.
    My cup runneth over
    Reputation: rmac's Avatar
    Moose, Renny and Zilla all in one recent thread - can't wait to see TS, CC and Aqua (maybe even Smokey) chime in.
    FWIW, I spend so much time granny/granny I can't imagine EVER going single up front. There are a couple of super short/steep climbs on my regular routes (Green Mountain - haha) that even in granny/granny I still only make the climbs < 50% of the time.
    You guys are animals.
    MTB B'dos
    Reputation: LyNx's Avatar
    At your weight Zilla, I'd have to agree with those who suggested putting the granny back on and getting a new clutch RD to help minimize the chain slap. I only weigh about 180lbs geared to ride, but have long legs and my granny/granny of 24/32 makes me suffer on super steep climbs and makes my knees hurt a bit, can't imagine going to a 1x setup unless I went to a 30t front and 36-11 outback. FYI I'm on a 29er though, so bit harder ratios, my 24-32=21.8 gear inches.
    Reputation: nybike1971's Avatar
    Zilla! Nice to have you back.
    Another option for 11 speed gearing at 10 speed price is this cluster made by an Italian (of course!) company - Leonardi racing:
    SRAM
    Shimano
    XX1 cranks are the cheapest option for light cranks with the possibility of using a chainring with 28t (if you are going to invest in new cranks), or switch between 1x and 2x setups (all you need to do is replace the spider with one of the X0 2x spiders).
    Lay off the Levers
    Quote Originally Posted by rmac View Post
    ...and rmac, and NYCB, and Wilks and, and and...
    it's like a college reunion, without the beer and the underwear.
    I used to be a granny grinder too. Then all my fast friends went to 1x, so I figured I'd give it a go.
    I learned while I'm strong enough to ride pretty much anything I'd granny, it steadily ground me down. Maybe I'm getting stronger, maybe my endurance is increasing, it's hard to tell when after the first 20 mins all I can see is my front wheel and flat-line EKG .
    For the moment I'm between jobs so I'm taking the cheapest route to something pedaly. I'd like to avoid going back to the granny, but holy cow looking at the gear-inches I used to spin at 22/34 compared to what I mash now at 32/34... I can see why I'm burning down like a candle under a blowtorch.
    Today I'll put on the 12x36 cogset. I suppose I'll have to add some links to my chain.
    If the benefit is only incremental, then I'll look for a 30t chain ring I can put on my XT HT-II crankset. If that still isn't enough, then I'll sell some spares and look at the new funky stuff.
    Lay off the Levers
    It's not the chainslap that is so much an issue. I had pretty good results with a short der, 2xchainguide and a granny. I could live with that.
    But I've grown to like the clean simple setup of a 1x. And now I'm a fiend for flat pedals... no matter how technical the terrain I simply do not miss clipless.
    BUT at nearly 250lbs, (yes you read it right) I need a few more teeth out back and a few less up front. Put me on rolling terrain, or a decent and I can hang with almost anyone but hauling an extra 100 lbs my partners don't have up a hard hill is one heck of a disadvantage regardless of my fitness level.
    Lay off the Levers
    Quote Originally Posted by nybike1971 View Post
    SRAM
    Shimano
    That's some interesting stuff there. Basically I'd have to build my own cassette right?
    Dec 2004
    Makes every gear in back easier and looses weight up front. I use it along with a 12-36 in rear on same type of terrain as you in WV. Unbelievable difference.
    Product Info | Andersen Machine's Blog
    Lay off the Levers
    Quote Originally Posted by WV_XCE View Post
    That would certainly help. $90 bucks for an alu chain ring though... wow.
    I can easily burn one out in a season.
    Dec 2004
    Picked mine up on classifieds here for $45. Got the non ramped version and when one side wears out I can reverse it.
    Yes, that's correct. That's why they match the SRAM and Shimano clusters. I have been tempted to order one of those for my full suspension 29er which I am in the process of converting to 1x10.
    Good to see you back in the forum 'zilla and getting some good discussion going.
    I hadn't given the single front ring much thought until I started riding the dw and bigger wheels, don't know if it's both or one or the other but I am certainly climbing faster and my worst fitness ever. I need to wait for a 9 tooth rear cog though or I'd be casing lots of landings as 32x11 spins out too easy for me. Also the optimum ring size for the suspension design is something to consider. And when the cost of an all new drive train, especially 1x11, equals the cost of a vacation....
    Reputation: mtbnutty's Avatar
    SMOKEY!!!!!! Good times............
    Zilla, just slap a 36 cassette on and be done with it.
    not so super...
    Reputation: SSINGA's Avatar
    For us older and less fit MTBR'ers the 36t cassette and a 28t or 30t front ring works well.
    Nothing to see here.
    Outcast
    I bought one of these when I had the spitfire, in an effort to keep me out of the little front ring. It did do just that, but it wasn't a monumental incremental change. I still had to reach for the granny gear. Yea, 90 bucks is steep, I think it's cheaper to get a 34 or 36T cassette.
    Dec 2004
    Rene is right. I got about half my gains from the 30 ring. The rest from the 12-36 cassette. I was running 11-34 9 speed prior. I really like the ratios of he 10 speed too. BTW - I still run a granny but only need it for the really steep stuff now.
    Outcast
    Quote Originally Posted by SSINGA View Post
    For us older and less fit MTBR'ers......
    I prefer to refer to myself as "Semi Retired". Seems a bit more dignified, which I can always use more of if I can get it.
    I say go back to a double in front. I am close to your weight and while I can climb many things in a 32x34, for the hardest climbs and/or a change in cadence when I start getting tired, that small chainring is a godsend. I would suggest considering running 24-36 or 24-38 front chainrings. I did this on my hardtail going from 3x8 to 2x10 and used Wickerworks 24-36 chainrings on my old crankset and a 11-36 rear cassette. This gives a bit more top end as well as the low gears for climbing when needed.
    Remember, as big boys, we will never climb like the skinny guys.
    Riding slowly since 1977.
    Large member
    Reputation: Tidybeard's Avatar
    Feb 2005
    I prefer to refer to myself as "Semi Retarded". Seems a bit more dignified
    Good to see you being honest with yourself these days Renny.
    To the newbie OP - has Sir considered being less old, fat and slow? That would be one way to solve the problem, before needing the Goreduke cassette.
    Edit - I feel well qualified to comment on all of the above.
    Reputation: jncarpenter's Avatar
    Zilla, I have a newish Anderson Machine 30T I'll give you if interested. I am running a 1x10 with a 28T up front (Middleburn cranks) & 36T out back, and it is sufficient for our local stuff (similar to what you have locally...think Pisgah ).
    Reputation: miles e's Avatar
    Quote Originally Posted by jncarpenter View Post
    Ahhh, Pisgah!
    Can't beat free, but Wolf Tooth Cycling also makes a 30t ring that has the XX1 style wide/narrow profile, which almost justifies the high price ($75 shipped) IMO. Just got my 30t for the 5 Spot and haven't installed it yet, but the 32t I've been running on my hardtail works great- even when I left the clutch in "off" on my rear derailleur the chain didn't drop.
    I think 30t (or maybe 28t on a FS 29"er) with an 11-36 cassette gives a very usable range for most East Coast riding. Most of our climbs that are steep enough to warrant a granny are also techy enough that you can't simply spin up them either- you have to keep the speed up so you can level/ratchet the pedals momentarily over obstacles, then be able to put down a few good power strokes quickly without spinning out.
    ''It seems like a bit of a trend, everyone trying to make things longer over the last couple of years" Sam Hill
    not so super...
    Quote Originally Posted by miles e View Post
    Ahhh, Pisgah!
    Headed there in June. Can't wait!!
    Lay off the Levers
    Thanks JNC PM forthcoming. I'm sure I can make you an offer...you take quarters?
    Hopefully 30/36 will do.
    Pisgah... Kickass riding... IIRC Not like up here though are climbs are much shorter, steeper and way rockier. But DAYAM was it f-u-n!
    Lay off the Levers
    If you like I'll mail you some rocks.
    Man I remember that super slick stream crossing and Dupont waterfall. And that monster swoopy downhill run in Pisgah Forrest. Holla!!!
    I still got Bart the lizard on my workstand.
    Lay off the Levers
    Cool-blue Rhythm
    Quote Originally Posted by Tidybeard View Post
    Now we can get the party started properly.
    Can't have a reunion without a sheep shagger.
    Lay off the Levers
    Ahhh, Pisgah!
    Exactamundo.
    Lay off the Levers
    11T spins out too easily? Maaaaaannn, I can't go more than 50' w/o a RT angle turn into a climb.
    LOL.
    Outcast
    Sir, I protest. I have always held myself out there as semi-retarded. Only now am I coming out with being semi-retired from... of all pursuits, shagging sheep, and other wildlife, whatever stands still long enough... it's amazing the older you get, the things that look....shagg-able, if you know what I mean, and I think you do.
    To the O.P.. I hear bowling is an endearing pastime to folks of you age, physical stature, and fitness level [ cough ]. And your whole family can enjoy it with you. Check it out yo!
    Te mortuo heres tibi sim?
    Zilla: rocking the 30t ring with 11-36 cassette (10spd) on all three bikes. Kicks ass around here, and I'm riding pretty much the same trails. For trail riding around here, no problems. Even took a trip last fall into NH/VT/ME with much longer sustained climbing and the 30x36 gave enough low range.
    Caveat: I am a much smaller mammal than you.
    XTR crank with 30t on two bikes, SRAM crank with spiderless North shore Billet ring on the other. Working great on both counts!
    IMO, if buying new and budget is not crazy flush, the SRAM/spiderless setup is the shit!
    Lay off the Levers
    Quote Originally Posted by scrublover View Post
    Scrubby, from what I remember from the times I rode with you, You were climbing things on a full rigid, MX riders avoided.
    You got a bad case of A.G.E., 'Zilla. What you need is a 20t up front. Remember, Granny loves you.
    So it seems to me to be, this thing that I think I see.
    Lay off the Levers
    Okay I bolted up a 36T cassette.
    Verdict: An incremental improvement.
    While I still got shagged out on some climbs at my local asswhooper I feel a bit less flogged post ride. I was able to sit and pedal-climb in some places where I couldn't with the 34T.
    I spoke with a few light and fit hammer breakers on a social ride yesterday and pretty much all of them said they tried ditching the granny on these trails and it burned them down as well.
    I'll definitely need to go to 30T up front, and probably put the 22T granny back on as well, and hopefully the 30/36 will help me use it less.
    Lay off the Levers
    Quote Originally Posted by xcguy View Post
    Deny till I die.
    Last time I figured out how old I was, I almost gave up riding.
    Never again.
    A good looking option for the 30T here:
    104 BCD Chainrings | wolftoothcycling.com
    Lay off the Levers
    Nice lead thanks.
    Nice lead thanks.
    Jump on that, man.
    I'm waiting for when they get the XTR 88mm BCD and SRAM direct mounts in 30T to replace my stock rings, otherwise would just go for those myself.
    Going from 32x34 --->32x36 isn't too much, but it was much more noticable going to the 30x36. Get pretty good low end, but without losing too much top end with the 30x11/12. At least for the way our trails are around here. About the only times I'm in those cogs anyhow is if pedaling to the trails.
    Poor man's XX1
    Have you considered adding a larger cog? These things on eBay look viable:
    41 Tooth Cog for Mountain Bike Cassette 41T Sprocket | eBay
    (or just search "41 tooth cog" on eBay if the URL isn't working)
    Stacked behind a 11-36 10sp cassette, and losing the 11T first cog for a 13T, gives you a 13-41, which is a pretty good spread. No funky steps either, you just lose the 11T.
    I'm seriously contemplating the Wolf Tooth 30T ring + Zee rear der + 11-36 XT cassette modified to 13-41 via the mtbtools cog.
    There must already be a thread on this on mtbr . . . I didn't look.
    Lay off the Levers
    Quote Originally Posted by InertiaMan View Post
    Very helpful link, thanks!
    Lay off the Levers
    Okay I swapped to a 30T chainring AND 36T cassette.
    incremental improvement, I still need more sit and spin. Next up is the 41T cog above.
    After that it's back to the granny or maybe one of these:
    Dec 2004
    That 41 looks like it would weigh as much as the rest of the cassesst. Go X-9 cranks and a spiderless 28 up front. Loose weight and gain sit and spin in every gear.
    Reputation: joshuagore's Avatar
    A few years back I went 1x9 and being a clyde myself I did notice on the sprinting short climbs that I was drained more so than usual, but the simplicity and self loathing kept me in 1x9 until 1x10 setups started offering 36 in the rear. When I jumped up to 36 in the rear the change was significant enough to keep me with 1x drive train for another season, and that leads me to now. Although I am floundering on a Burner build, it will definitely be some cobbed together 1x11 setup as the shop bikes with xx1 which I have ridden have completely satisfied my granny needs. Problem is you have another 8 months before we really see any 1x11 sram stuff in anything but xx1/xo.
    I would check to see what rear der will handle the 41t without issue. I remember back when I used to build cassettes 1 cog at a time I used to run a giant granny out back, and the biggest problem I had was getting my rear der top pully to not hit that giant granny.
    Josh
    p.s. Nice pics/gifs in the other thread.
    Dec 2004
    Here is a link the the MRP Bling Ring that I was referring to above.
    Mountain Racing Products home of MRP, White Brothers, Kreitler, Tamer, and Power Grips | MRP Bling Ring Chainrings
    Slap it on a cheap set of x-7 crank arms and loose 1.5 gear-in over the 30-36 setup you have now. That is 7.1% easier pedaling according to Sheldon Brown. Or 3.1 gear inches and 14.3% easier pedaling that what you started with (32-34)
  1. slipping gears after cassette and chain replacement
    By immetro in forum All Mountain
    Last Post: 07-07-2014, 03:10 PM
  2. Going from 2X9 to 1X ? Too many gears!
    By le_buzz in forum All Mountain
    Last Post: 02-12-2013, 08:35 PM
  3. How many gears does a 3x9 have?
    By ecub in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2012, 03:42 AM
  4. Where's your gears?
    By AaronK in forum Singlespeed
    Last Post: 10-02-2011, 10:33 AM
  5. SS cog Vs. Gears cog
    By jackspade in forum Singlespeed
    Last Post: 01-12-2011, 09:03 AM
