Best Waterproof grease?
Hey guys,
I continue to get a creak from the DW link where it mates up to the pivot shaft. I need to disassemble it after nearly every wash otherwise creak comes back. What is the best waterproof grease to use? I have used Park, Paul's, Turner offered grease with no luck.
Seth
Are you referring to the Hexloc interface between the shafts and the DW links? If so, that junction should fit really tight. I mean really tight. If yours are loose, that sounds like your problem. I had the same problem. Turner hooked me up with new pivot shafts that fit tight to the DW link and are dead silent.
Krytox--> Fluoropolymer
Viperlube --> PAO
Amazing wet performance. Read up!
By NC-Biker in forum Wheels and Tires
Last Post: 10-11-2013, 06:51 PM
By TechniKal in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 10-08-2013, 08:51 AM
By B-Line in forum Santa Cruz
Last Post: 10-28-2012, 05:06 PM
By wonny in forum Intense
Last Post: 10-17-2012, 11:35 PM
By ChrisJ in forum Commuting
Last Post: 03-23-2011, 06:11 PM
- You may not post replies
- You may not edit your posts
Forum Rules
