Results 1 to 11 of 11
    aka DJ Papi
    Reputation: emrs0414's Avatar
    Apr 2005
    Another HIGHLINE...
    Acually a re-post from the Manila Highline...
    The build spec:
    Frame: Turner Highline, 2006 Medium RAW Color
    Rear Shock: DHX 5.0, 8.5 i2i x 2.5 stroke with RCS Ti Spring; 7.2” rear travel
    Fork: 2006 Marzocchi 66SL 7”
    Brakes: Avid Juicy 7 with Galfer 185mm Rotors / Pads; Goodridge SS fittings and lines.
    Wheelset: Mavic EX721–32 Holes; Hadley 150mm x 12mm rear; Hadley 20mm front; DT Comp spokes
    Crankset: Shimano Saint 2 Ring
    Bash: e-thirteen DRS
    Bottom Bracket: Integrated with Saint cranks
    Cassette: Shimano XTR 11-34
    Shifters: Shimano XT triggers
    Rear Derailleur: Shimano XTR.
    Fr. Derailleur: Shimano XT M761
    Seatpost: Thomson 27.2mm x 330mm
    Seat: Specialized BG Telluride Ti
    Headset: FSA Orbit Extreme Pro R
    Stem: Thomson X4 50mm X 31.8mm
    Handlebar: RaceFace Diabolous 31.8mm
    Grips: Trico GELs
    Pedals: Sun Ringle MAG platforms
    Tubes: Panaracer
    Front Tire: Intense 2.25
    Rear Tire: Intense 2.25
    Weight: 37.2 lbs.
    Reputation: jncarpenter's Avatar
    WOW! You just made me tear up a little....very nice HL, very nice indeed!
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Fabu!!!
    It's killing me these HLs are building only half a pound heavier than my RFX!
    Faster is better, even when it's not.
    Quote Originally Posted by Bikezilla
    Fabu!!!
    ...5 pounds heavier than mine
    ...perhaps more after the upcoming mods
    Lay off the Levers
    Then your RFX weighs almost the same as my Spot...
    Either gravity is broken in my area, or CactusCorn Units have expanded into measurements of weight.
    I'll check again after I put the lighter wheelset back on the Spot.
    Outcast
    Reputation: Renegade's Avatar
    Quote Originally Posted by jncarpenter
    Geez, what a tease! C'mon Jay; do tell!
    ....32.4 per my ultimate digi.
    Quote Originally Posted by Renegade
    ...nothing to see here, keep it moving
    Jul 2003
    that's really nice!
    would you mind measuring the b.b. height?
    Looks like a ton of fun, lets see some riding shots!
    aka DJ Papi
    Apr 2005
    jncarpenter; Bikezilla Castle... THANK YOU for the kind words...
    Castle, just measured the BB height, a safe round off figure would be 14.3 inches based on the measuring tape I used -> floor to middle of Saint crank... I hope this helps...
    And YES, I will post some ride shots real soon... as soon as the skies over here in the Philippines clears... its been raining due to a typhoon storm...
    Flyin Canine
    Reputation: shanedawg's Avatar
    God man, these bikes are turning out awesome. I love the ti spring on the highlines. It looks so badass. The grey cables look good too.
    I took my highline out for it's first trail ride last night and I gotta say that the 888rc2x climbs like crap, but hey the dirt jumps were at the top of the hill so what are you gonna do? If I keep doing rides like that I may have to think about doing the 7/7 for most of my riding and going to the 8in modes for whistler trips only.
    What type of riding are you planning on doing on your Highline?
    aka DJ Papi
    Apr 2005
    Quote Originally Posted by shanedawg
    Hey shanedawg... the highline is not mine... but i do believe that the owner will be doing some freeriding and donwhill runs with this bike. its sort of a really nice "pedalable" and light 7" downhill bike...
