Results 1 to 29 of 29
    Air Shock and Fork for 2011 Spot
    Thinking of having an alternative setup for those those areas with no lift access, currently running Fox VAN 36 / CCDB but want to shed some weight but retain the plush feel for the downs. The RS Pike and Monarch Plus are high on the list, but what else should I consider?
    Reputation: kreater's Avatar
    I had a float 36 and Push built Monarch Plus on my 11 spot, now on my Burner. the float, now fully broken in is smooth, and the Monarch is outstanding on the DW bikes.
    Product designer @RSDBikes.com
    "Live dangerously and you live right."
    Johann Wolfgang von Goethe
    "Furruccio....Bite Me!"
    Reputation: Zeke's Avatar
    Quote Originally Posted by kreater View Post
    +1 for the Monarch Plus. And if you go with the 2014 Monarch Plus RC3, you won't need any Push treatment as it will outperform the Push version. (ask me how I know)
    Order the Low Rebound and Low Compression tune and you will be good to go on you DW spot. (Archaic as it is)
    good to know, i would like to get one for my 12 sultan
    Reputation: jjkitt's Avatar
    Quote Originally Posted by Zeke View Post
    Ok, I'll bite...how do you know?? I have a Push version on my Spot...and its pretty good but not as good as the CCDBA IMHO. I always looking for something better...so let me know.
    Cheers,
    "I Like the Cut of His Jib"
    Reputation: kameraguy's Avatar
    I'm not going to be much help, but I am running a push'd kashima RP23 HV (big-hit tune) and Lyrik Air on my '11 Spot. I like it, really plush for me, but sounds like you are looking for a more DH air setup.
    The CCDB Air sounds like it'd be amazing on the '11 spot. I have a CCDB Air on my Canfield One and love it on that bike.
    So I have to ask...the CCDB fits on a '11 spot? I had the impression the downtube didn't have enough clearance for piggy-back shocks. If it is OK for a '11, then damn I just might go that route myself.
    I have a medium frame and it is tight, but I've not impacted the downtube yet. The CCDB Air won't fit the medium frame, although I am lead to believe it will fit the large.
    Just to clarify, my Spot is a 2012...no issues with fitting the CCDB air.
    Cheers,
    John
    Quote Originally Posted by jjkitt View Post
    Cheers,
    "Ask me how I know" is a euphemism for I've had the opportunity to try most of the shocks out there.
    I rank a stock 2014 Monarch Plus RC3 as the best, edging out the CCDB Air. (But the CCDB had more increments for tuning, which I didn't find necessary, but nice to have.) Followed by a 2013 Monarch Plus then the Monarch RT3. I was not impressed with the Pushed RP3, I thought it was no different than stock RP3. I also did a little experiment by switching a Pushed RP3 for my 06 Spot and the same shock from my 12 DW Spot. I found virtually no difference in performance. They should have been drastically different, the damping and compression should have sucked switching them as the suspensions are completely different, especially considering that these shocks were "customized" for the frames. So I'm not a big Push fan after this experience.
    The newer Fox stuff I've not tried (Kashima CTD) so I can't speak to them. Maybe someone else has experience with them.
    Jan 2009
    I run a BOS Deville and Vip'r and love it. Even thru the rough stuff it's super plush. The Deville feels like a coil. I was surprised at how light it is too.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Anyone have a line on where to get a Monarch + with the low tune?
    quick search and these guys came up........
    RockShox Monarch Plus RC3 Low Tune - Fanatik Bike Co. - Bellingham Wa
    Reputation: trailbrah's Avatar
    ebay
    Reputation: jet fixer's Avatar
    Feb 2006
    Quote Originally Posted by whodaphuck View Post
    Email these guys:
    http://www.mtbsuspensionexperts.com/
    Just purchased a mid/mid for my 08 RFX this was the only place I could get one at the time after searching for months.
    Too fat for XC, and not skilled enough for FR
    My 2011 5 spot now has a set of 150mm pikes fitted and they are by far the best upgrade i have fitted on to the bike. I have also got a 2014 Monarch Plus RC3 on order but Loco wont get that until late jan / early feb. I have not tried the shock but i have constantly tried to improve the stock RP23, along with having it PUSH'ed and so far i have never liked the feel. So i am basing the new shock choice squarely on umpteen positive reviews :-)
    Yes, that's fonetic
    Feb 2005
    Thanks for the suggestions...Fanatik only has the 2013 in the low tune but they're looking into it and will be getting back to me.
    mac, you got two forks??
    2 forks?? you have lost me buddy. But it is early morning here and i have not had my coffee yet :-)
    Quote Originally Posted by macthekife View Post
    I have 6 rides in now. And I can only say I am more impressed with the 2014 Monarch Plus RC3. Mine is the Low/Low tune. Your patience will be rewarded.
    I think Push is now irrelevant (well they can still do a rebuild/service when needed quickly). I've always wondered why they don't to RS shocks anymore, I think I know why now after having ridden this shock.
    Your comments about the new Pike indicate that this may also be the case for the new RS forks as well. That's my next purchase, a new Pike.
    Cheers!
    Yes, that's fonetic
    Feb 2005
    Just poking a little fun at how you guys across the pond pluralize your fork(s). I'd put a Pike fork on my bike while you install "a set of 150mm pikes".
    Ahhhh getcha now :-)
    GAME ON!
    will the 2014 monarch plus fit on a 2010 5 spot or am i out of luck with any of the cool shocks?
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    if you have a large frame i would say yes it will fit. i ran one on my large 11, the 12 spot had the curved down tube for bigger reservoir shocks.
    Quote Originally Posted by saturnine View Post
    There is absolutely no reason why the monarch plus will not fit. The only shock that wont is the CCDB Air which is why Turner changed the downtube for 2012 onwards.
    After a quick scan on the web I can't seem to find any lo/lo Monach Plus - can anyone point me at the correct option?
    Reputation: airwreck's Avatar
    Quote Originally Posted by UK-FLATLANDER View Post
    After a qui scan on the web I can't seem to find any lo/lo Monach Plus - can anyone point me at the correct option?
    At this point in time it would require buying a medium tune and replacing the parts with low tune ones. There is hope that SRAM will be building up some low tunes in the near future.
    You might want to check out Bicycle Suspension - TF Tuned Shox
    They are in the UK...and I think they offer custom tunes.
    I just got mine from http://www.mtbsuspensionexperts.com/ here is the US. They did a great job tuning it...feels nice!
    Hope this helps.
    Cheers,
    Loco Tuning is doing mine when he gets it. Apparently its easy if you have the know how to change the shock from medium to low/low.
    GAME ON!
    theoretical physics is easy if you have the know how
    RIP Adam Yauch
    That is true :-) but my point was. For the same price as most online shops i am getting a custom tuned shock for my 5 spot. So its actually worth dealing with TF Tuned and the like as they can sort your shock out to your specs on initial purchase. Don't just buy blind from the cheapest retailer and then find you have to send it off for a retune.
  1. Lower Shock Mount Bolt Broke on 2011 5.Spot
    By Falldog in forum Turner
    Last Post: 05-09-2013, 09:06 PM
  2. cableguide spot 2011 with coil shock
    By eiri in forum Turner
    Last Post: 02-26-2013, 03:01 PM
  3. Replies: 15
    Last Post: 12-04-2012, 01:27 PM
  4. 2011 DW 5 Spot fork set-up?
    By Cucucachu in forum Turner
    Last Post: 05-10-2011, 05:56 AM
  5. Replies: 12
    Last Post: 04-11-2011, 08:04 AM
