Results 1 to 32 of 32
    Giant Robot
    Reputation: Dr Thunder's Avatar
    Advice on 36 Van Clearance issues on Medium Pack?
    Picked up and installed a Van Rc2 on my medium Pack. Excellent fork so far, but I've noticed that the rebound knob doesn't quite clear the downtube. I know Ventana makes a taller Chris King crown race, but this actually seems like it might be overkill given that it only needs 1 or 2 mms to clear. Anyone have any experience/suggestions here? I thought about Dremeling the top portion of the rebound knob. Thanks in advance.
    You're running a king headset?
    I have the same setup... medium pack with 36 van and I don't think I have the same problem.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Ventana makes both a 3 & 7mm CK race. If you only need 1-2mm then the 3mm would be perfect.
    Lookin for that extra can
    Quote Originally Posted by incubus
    No clearance problem here... CK headset, 36 Van RC2, 05 Medium Pack. Strange...
    --rip
    Maybe it depends on what color medium pack you have...mine's grey and the knob clears just fine.
    I've got a Stiffee
    Reputation: FXRob's Avatar
    I've also got a medium Pack with a 36 Van and have no clearance issues either
    Edit: that's with a CK headset also.
    I've got a Stiffee
    Quote Originally Posted by El_Chimichanga
    Granted mine is grey but I checked my clearance and it just BARELY clears the gussett welds on the downtube, maybe 1mm of clearance.
    Giant Robot
    Mine's also the powdercoat grey, and yes I'm running a CK headset
    The inconsistency with this is pretty weird.
    Just to be specific, the very top of the rebound knob contacts the welds of the downtube gusset. I think the problem may be with the rebound side top cap, as when I look closely it appears that the base of the cap is just slightly taller than the preload side.
    Where might I go about getting one of these 3mm King races? From Ventana directly? Or must I undertake an extensive trek, alone and on foot, to a distant land where these special crown races grow as the fruit of a rare plant that only resides in the lava fields of a certain volcano?
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Grab a file and give the knob a few passes.
    My video techniques can be found in this thread.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Dr Thunder
    That would definitely be more entertaining.
    Quote Originally Posted by tscheezy
    Why file it when you could just smash it down with a hammer?
    Bodhisattva
    Yes. And there you will have to answer these 3 questions:
    What is your name?
    What is your favorite color?
    What is the airspeed velocity of a swallow?
    Or just call Larry at Mtn High Cyclery.
    Giant Robot
    Wait...
    African or European?
    Bodhisattva
    I...I don't know that.
    Aieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
    Giant Robot
    Oooooooo, new question (still related)!
    To all you folks with the same set up who are not having clearance issues, where is your rebound set?
    I run my rebound very fast, but I noticed that if I slow it down (thus depressing the knob), the fork clears the gusset. Just curious if this whole clearance/no clearance thing is actually inconsistant or just a matter of different rebound settings.
    Either way, I'll soon be seeking the one they call "Larry," who can allegedly summon fire without flint or kindling.
    Negative Rep Points!!!!
    Reputation: Aquaholic's Avatar
    Your problem...
    ...originated when you reinvented yourself with that DUMBASS handle, Doc..
    PS I wonder if your headtube was faced a bit too agressively on the bottom?
    Either way, bring it by...lemmee have a look at it before you start buying stuff.
    What the EFF is "All MOUNTAIN"???
    ISO Gems...
    Reputation: Dirty D's Avatar
    Dr. Thundah,
    Vanilla, schwanilla, when are you gonna need that much turning radius anyway? Ya gotta fill the homers in with the real *411*
    THAT YOU ARE AND ALWAYS WILL BE THE ONLY JOHNNY WADD...
    P.S. always good ridin' with you Johnny...
    D
    Quote Originally Posted by Jayem
    Remind me exactly which shop you "work" at?
    I've got a Stiffee
    Nah, I only run my rebound 2 clicks in from full fast so it isn't that.
    J_B
    J_B is offline
    3056-BigGameHunter
    Reputation: J_B's Avatar
    Interesting. When I get mine built up, I'll have to look out for that. It's a small though. Wonder if the same issue will be there?
    You should call Fox, moan and groan to them, start a big ol flaming post here as to why you think you should have more clearance and that this is such a huge issue they must be in the wrong for not addressing it. Then vow to never use another Fox product again....or just get the 3mm crown race.
    PipeHittersUnion
    e.thirteen,EVOMO,IntenseCycles,Maxxis,ODI,SDG,661
    Reputation: Prof's Avatar
    This is 5 clicks in from full fast and it just clears, if I run it at full fast it doesn't clear, a file or the spacer as stated above is the way to go.
    This is with a FSA orbit headset.
    Looking a the pic, I'm not sure what you would file. Looks like the knob's bolt is the first thing that would hit, and you can't very well file that down. Looks like you should send it to Jm and he can do the hammer thing on it.
    I'm wondering how the clearance goes under dynamic conditions. I'm thinking a 1-2 mm gap is tiny and surely under dynamic conditions that gap can close.
    beer is good
    Reputation: Nels's Avatar
    I think there is enough material on the red knob, so one could
    countersink the hole a bit more with a drill bit or dremel, then the
    screw would sit lower, and file the top of the knob to get more clearance.
    Steve
    "looking California, feeling Minnesota"
    Bodhisattva
    If it makes you feel any better.....
    I have no clearance issues with a Pike on my Pack but Darren's slighlty rubs the underside of the downtube as well. Mine is a white medium & his is gray.
    Conclusion: White 6-Pack frames are far superior to the gray ones. But we knew that already
    Jul 2003
    I would think running your rebound wide open like that would have your tire bouncing all over the trail.
    Give it a ride with a few clicks slower see if you like it......
    If not, I'd be hesitant to grind, I'd opt for the taller crown race like mentioned above.
    if you don't like the crown race idea.....
    cane creek makes a little taller lower cupped headset that would also solve this problem.
    http://www.canecreek.com/s3_plus_5.html
    hope you get it worked out, good luck.
    Sean
    "Conclusion: White 6-Pack frames are far superior to the gray ones. But we knew that already"
    And they go so well with the current conditions
    Quote Originally Posted by Dirty D
    And what happens in a case of crash? argh...
    Ok, look away if you are squeamish
    This is the Rebound shaft before
    Mark up approx 1.5 mm
    Prep for surgery
    Top cap before
    Top cap after,this is to allow it to bottom on the seat of the shaft which is now higher
    This is the clearence available after
    I have lost 3 clicks of adjustment out of an original 13 clicks at the far end of the range (Max rebound) this is not a problem for me as that was way too slow, this is reversible by simply fitting small washers back onto the end of the rebound shaft under the top cap.
    Nice work, Doctor! What hammer did you use, if I may ask?
    Giant Robot
    Man, Steve...
    [QUOTE=Aquaholic]...originated when you reinvented yourself with that DUMBASS handle, Doc..
    You simply won't let me try to escape my past as a hugely hung coke addict who died of AIDS in 1988...
    ISO Gems...
    BWAHAHAHA... Sounds like you did your research. Yea, he's like a pitbull when it comes to nicknames...he won't let go. Did you get your Van problem solved yet?
    D
