Results 1 to 6 of 6
    7.875 x 2 coil shock on 2013 5 spot
    I have a 7.875 x 2 Fox DHX coil from a previous bike and was curious if it would work on my 2013 5 spot. What would it change? Is it worth trying?
    Thanks!!!
    Dont think it will fit without hitting the underside of rockers, but it's just turning the bolts 4x and you can tell us how is changes things.
    DT
    Thanks DT. After thinking about it, why even even consider changing anything? Thanks for making such amazing bikes!!! I have dreamed of being a Turner owner since I started riding, and I am so glad it's now a reality
    Outcast
    Reputation: Renegade's Avatar
    What DT didn't say is it will phuck up your geometry, shock stroke, shock tune, and every other reason why you bought the bike you did with the stock shock. Take this from someone who has plenty of experience sticking other than OEM spec'ed shocks in his bike.
    Thanks Renegade!!! Much appreciated
    Reputation: airwreck's Avatar
    Yes the reservoir and rockers will contact, the bottom bracket will rise a couple inches and the head angle will steepen significantly. Pretty radical changes.
  1. 2013 giant reign 2, with coil shock
    By bigred543 in forum Giant
    Last Post: 04-23-2013, 02:26 AM
  2. cableguide spot 2011 with coil shock
    By eiri in forum Turner
    Last Post: 02-26-2013, 03:01 PM
  3. 2009 5 spot coil shock options
    By gregmazo in forum Turner
    Last Post: 02-24-2012, 10:20 PM
  4. Turner 5 spot with coil shock
    By www.tizianophoto.com in forum Turner
    Last Post: 04-01-2011, 05:53 PM
  5. Coil shock for small 2009 spot??
    By uni in forum Turner
    Last Post: 01-17-2011, 07:03 AM
