Results 1 to 2 of 2
    Reputation: zonoskar's Avatar
    5 Spot vs. Slayer
    I have a Rocky Mountain Element TO and am looking for a new frame, because I want more travel. The Slayer is a nice option that will probably ride similar to the Element, but how does the 5 Spot compare?
    Quote Originally Posted by zonoskar
    The 5 spot is a little lighter if you run it with an air shock, or a little heavier, if you use the Romic. Not a big difference.
    They're both 4-bar suspensions. The 5 Spot is a Horst lInk, the Slayer is a seat stay link. I prefer the Horst.....your mileage may vary.
    Depending on the size, the head angles may or may not be the same. The slayer HA varies from 69 to 70 depending on frame size. The Spot is 69*
    The 5 Spot is a superior bike, but it's also more expensive. The zirc/bushing setup on the Turner is better than the bushings on the Rocky.
  1. Romic or Swinger 4way coil for 5 Spot
    By Alpenglow in forum Turner
    Last Post: 05-19-2004, 06:20 PM
  2. How much drop can a 5 Spot take?
    By Rollin'in'Zona in forum Turner
    Last Post: 04-05-2004, 06:57 PM
  3. Another New 5 Spot Story
    By Surfer in forum Turner
    Last Post: 03-22-2004, 01:57 AM
  4. 5 Spot - first ride, some thoughts
    By cooldaddy in forum Turner
    Last Post: 03-09-2004, 12:09 PM
  5. finally appreciating the 5 Spot
    By Duncan in forum Turner
    Last Post: 03-01-2004, 06:47 PM
