Results 1 to 8 of 8
    KDK
    KDK is offline
    Reputation: KDK's Avatar
    5-spot essential sizes
    I wish to build a 5-spot. What are its essential sizes such as BB length, seatpost diameter, seatpost clamp, headtube size (Any others I missed).
    Thanks !!
    Reputation: CrashTheDOG's Avatar
    5 Spot Specs
    Edit: Sorry, I figured this page would have the info you need and it doesn't, other than the HT size. The only one I can give you is the seatpost size and that's 27.2 x 410. Perform a search for the others seeing as how this has been discussed before. Good luck.
    KDK
    KDK is offline
    Ok I now have the seat tube and head tube sizes. We are now missing seat clamp size (I guess it is 32.0) and the BB size.
    Help anyone !
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    BB: 73mm shell, 113mm spindle (for '03 XT, for instance)
    Seatpost: 27.2mm
    Seat collar: 32.0mm (it comes with one, but if you want a Salsa QR instead)
    F derailleur : 34.9mm, top pull, bottom swing
    Headset: 1 1/8"
    My video techniques can be found in this thread.
    KDK
    KDK is offline
    Thanks a lot.
    Two more questions.
    What is the maximum tire size (the back as the front will depend on the fork), and what is the maximum size rotor (back again) that the frame can handle.
    The chainstay yoke is 3 1/16" at its widest point. The seat stay bridge is even wider. I have some "true" 2.5s mounted right now (they measure exactly 2.5" outer knob to outer knob). A wider tire would fit (say, a "true" 2.6 or 2.7), but you would have to run a wider bb spindle otherwise the chain will rub on the tire's side knobs in the lowest gears. The frame also clears very tall tires like Geax Sturdy 2.25s.
    I think you can run an 8" (203mm) rotor in the back. I have no idea why you would want one that big though, unless you run really weak brakes.
    Reputation: jedoaks's Avatar
    I have some of the Geax Sturdy's 2.25 coming
    [QUOTE=tscheezy]The chainstay yoke is 3 1/16" at its widest point. The seat stay bridge is even wider. I have some "true" 2.5s mounted right now (they measure exactly 2.5" outer knob to outer knob). A wider tire would fit (say, a "true" 2.6 or 2.7), but you would have to run a wider bb spindle otherwise the chain will rub on the tire's side knobs in the lowest gears. The frame also clears very tall tires like Geax Sturdy 2.25s.
    I'm in So. Cal. mostly dry, rocky, and loose. Does the height of the tire feel any different in the handling dept. Thanks, rich
    Quote Originally Posted by jedoaks
    Not that I noticed.
  1. Owned 5 Spot and Maverick? If so, I have questions.
    By Count Zero in forum Maverick
    Last Post: 05-15-2004, 09:14 AM
  2. Ben's Blue Bike (BBB) - Turner 5 Spot
    By blippo_uk in forum Turner
    Last Post: 03-30-2004, 05:56 AM
  3. Another New 5 Spot Story
    By Surfer in forum Turner
    Last Post: 03-22-2004, 01:57 AM
  4. 5 Spot - first ride, some thoughts
    By cooldaddy in forum Turner
    Last Post: 03-09-2004, 12:09 PM
  5. finally appreciating the 5 Spot
    By Duncan in forum Turner
    Last Post: 03-01-2004, 06:47 PM
