Results 1 to 19 of 19
Thread: 5-Spot Crack?
    Reputation: Seagrave's Avatar
    5-Spot Crack?
    Just found this on my bike. I sent an email to Turner but of course they are not back in the office until next week b/c of Interbike.
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Quote Originally Posted by Seagrave
    Did you take the rear wheel out of the frame and look at it closely or is just a dirt line? Clean it up really well and run a fingernail over it. If you are asking if that is a crack (the question mark in your message), I'm not sure how we would be able to tell that better than you. It looks more like a small ridge of material left behind after machining which is a dirt trap. It would be an EXTREMELY weird place for a crack to form. Like, nearly impossible.
    My video techniques can be found in this thread.
    Thanks Tscheezy, actually I cleaned this off yesterday when I first saw it thinking it was just a perfect dirt line. Yesterday I also re-gresed the zerk on the opposite side. I went for a ride last night and this morning the crack re-appeared. Its almost as if the lube is coming thru the crack and the dirt is sticking to the lube. Therefore, I think it is a crack, but I agree very odd place for a crack.
    Rather then asking the board if anyone else thinks this is a crack, has anyone seen or experienced anything in the same area?
    Now with flavor!!
    Reputation: kidwoo's Avatar
    No.....never on a yolk like that.
    I very very seriously doubt it's a crack. I believe those pieces are one piece machined, not two pressed together that would allow grease from a zerk port to seep through. I'm going with big T's guess that it's a machining ridge that's just collecting dirt.
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    You shouldn't say "poke holes" near the word "crack"...
    oly
    oly is offline
    Reputation: oly's Avatar
    maybe clean it all off real good again, then put a piece of clear packing tape over it. If you see any grease under it, then maybe there is something, but im with the other 2 in that would pretty much be an impossible place to have a crack leaking grease from the pivot.
    ...master of none
    Reputation: bock's Avatar
    What if...
    Quote Originally Posted by kidwoo
    Hmm...I agree that it's not your typical crack that appears due to frame stresses. That would be an extremely odd place for that type of crack to form. Plus, it appears very linear, which is also not typical for cracks.
    I'm going to guess that the bushing shell was machined a little too close to that edge. In other words, the "hole" that was machined for the bushing was placed in the wrong spot, leaving some very thin metal where the "crack" appears. Since the metal was so thin in that spot, slight forces on it caused it to fail, but only where it was thinnest. This allows grease to leak through and collect dirt, which then becomes visually apparent.
    Should be a straightforward warranty issue if I'm right. Anyone else care to poke holes in my theory?
    bock
    singletrack lush
    Reputation: marzz's Avatar
    Quote Originally Posted by bock
    bock
    I had a BB shell crack on me length-wise in a perfectly straight line, it looked more like a seam then a typical crack.
    So the question is...
    ...if it's a crack and needs to be replaced under warranty...will you get the horst link rear end or the TNT rear end???
    Quote Originally Posted by Dutch
    Great question. I guess I will find out next week.
    jra
    Reputation: seasick's Avatar
    It's amazing the things people are willing to do in order to rid themselves of that old outdated ICT stuff and upgrade to the new and improved TNT...Dy - No - Mite!!
    Not a surprise, Turners great customer services quickly responded. Greg from Turner emailed me this morning and they are sending me out a new Seat Stay.......My 5-spot will remain a Horst Link rear.
    Now with flavor!!
    Any info on what that line actually is? I'm guessing they feel it's justifiably a problem if they're sending you a new part?
    No info. I'm sure Turner wants to get the piece back and investigate it themselves.
    Greg
    Greg@turnerbikes.com
    Get an RA and we will send another out right away.
    That looks like a crack from here. The parts can cross in shipping. A horst of course will be shipped.
    David Turner
    Quote Originally Posted by turnerbikes
    David Turner
    Thanks DT, Greg is already all over it. I didn't expect to hear from you guys until next week after Interbike but Greg responded this morning. You guys are top notch! Can't say how happy I have been with my 5-spot. Thanks again!
    I think I need to Upgrade
    Reputation: AzSpeedfreek's Avatar
    Quote Originally Posted by jigbalot
    R u sure its a cracked?
    That is not a crack, it is a new way to lube the pivot bushing .
    Reputation: Pain Freak's Avatar
    Just
    another way to see if you've got enough lube in there.
    I may not be as good as I once was.
    But I'm as good once, as I ever was.
    Toby Keith
