Results 1 to 10 of 10
    Reputation: shanem's Avatar
    2x10 on the Burner
    Just curious what others are running up front on their Burners?
    I'm building mine up and have XTR trail cranks. Swapped out the the stock 38 for a 36 and I'm concerned I might not be able to mount my derailleur low enough to not have it contact the link during full compression. Using an XTR 2x front derailleur, top pull only as prescribed by Turner.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    SLX compact double
    Quote Originally Posted by jrm View Post
    SLX compact double
    Is this the dual pull model that needs to modified or is there a top pull only version? Are you running this with a 36?
    jrm
    jrm is offline
    Top pull only. The crank came off another bike so its 22/34 set for now
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    XTR 970's, big ring swapped for bash and never use the 22.
    Rolling on 29", 650b, 8.3" and 23mm
    MIA
    Feb 2005
    Hammerschmidt...
    Takes the front derailleur out of the equation.
    Reputation: freebiker's Avatar
    Mar 2006
    the der is a little high but it works fine. i have a similar setup and it works great. the fact that your running a lower drive gear means you'll have less chainring shifts down to granny in the first-place right. you can finish the deduction. have fun.
    SRAM X7. Nothing to cut or grind off, and seems to work great.
    Original SLX 36/22 double with built in delrin bash guard.
    Not that I bash much these days, but oh, it looks bada$$!
    Whining is not a strategy.
    Too Close To The Hill
    What are the rings and casettes on the XT 2x10 build kit?
    Lacerations through intact armor are a mark of talent... or stupid... or both...
    Quote Originally Posted by SummitAP View Post
    24/38 rings, 11-36 cassette.
  1. SRAM 2x10 crank with Shimano 2x10 system
    By Vhom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2013, 12:42 PM
  2. 2x10 SLX cranks on 2x10 SRAM set-up?
    By redstar1128 in forum General Discussion
    Last Post: 04-06-2013, 04:32 AM
  3. 2x10 FD-m785 work on 3x10 FC-m660 converted to 2x10?
    By govertime in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-03-2012, 07:17 AM
  4. XT 2x10 Crankset Compatible with SRAM 2x10 Drive Terrain??
    By sbchisholm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 07:30 PM
  5. Paid Spam - SLX 2x10 drivetrain w/FSA 2x10 crank
    By mwb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2011, 03:19 PM
