Results 1 to 5 of 5
    Dont Rep me
    Reputation: Strafer.2's Avatar
    2013 5-Spot Float CTD volume reducer not enough?
    Running recommended sag of 15 mm, I use up all the travel on mild trail rides. Tried running 13 mm and still uses up all the travel and seems to blow through mid stroke.
    There is a spacer already installed inside, but is a bigger one needed for someone at 185 pounds geared up?
    I don't think the home made shim mod won't work on this shock from what I read.
    Reputation: Vespasianus's Avatar
    Quote Originally Posted by Strafer.2 View Post
    You may need one. I have a 2011 spot that came with a reducer installed but I found I needed to "shim the can" as well. What size is in there now?
    On MTBR, the reputation is infamous.
    When I checked with Turner about the same in my 2012 I was told they ship with the 0.60" spacer. Which is denoted as the most linear curve for the 7.5 x 2 shock with LV can. I've been considering 0.80".
    Dont Rep me
    Quote Originally Posted by dhzion View Post
    Wish we had the option of the spacer when ordering.
    The kit has 5 spacers, of which 3 are useless.
    Length Travel Eyelet No Spacer 0.20"^3 0.40"^3 0.60"^3 0.80"^3 0.92"^3
    7.500 2.000 LV 2.4 2.5 2.7 2.9 3.1 3.3
    I think what they chose is likely a generalized best fit to the masses, but I asked the same question, "most linear for who?". I'm ~225 lbs. ready to ride. The bike still pedals really well due to the nature of the DW but once it gets to midstroke it blows through kinda fast.
  1. Volume Reducer Kits
    By dustyduke22 in forum All Mountain
    Last Post: 12-06-2013, 08:43 AM
  2. 29er conversion: spacer AND air volume reducer?
    By CactusJackSlade in forum Cannondale
    Last Post: 02-02-2013, 01:39 AM
  3. Where to buy RP23 volume reducer kit and seal kit?
    By veryavgwhtguy in forum Shocks and Suspension
    Last Post: 06-27-2012, 09:14 AM
  4. Volume reducer on Blue Sky Spots
    By Vespasianus in forum Turner
    Last Post: 11-24-2011, 01:45 PM
  5. fox float volume spacer kit ?
    By keen in forum Shocks and Suspension
    Last Post: 11-21-2011, 09:26 AM
