Page 4 of 6 FirstFirst 123456 LastLast
Results 301 to 400 of 572
  1. #301
    Quote Originally Posted by downhiller900sl View Post
    why would I? I dont have any time to make some childish couple stop e-fighting, I want to mind in my own business. I think that when I, and all of the people subscribed to this thread; receive an alert of new Reply is to see some amazing and drool-making build of a DW-Link DHR, or at least some interesting chat regarding the after-mentioned bike. Stop it, NOW.
    and BTW, thanks in advance for your comprehension and agreement.
    You should ask him how to use the ignore feature, he's pretty good!
  2. #302
    injured reserve list
    Reputation: Scrub's Avatar
    Thanks Kidwoo for posting, PM sent.
    Oh and my bike has some parts too,
    Boxxer r2d2
    Code brakes
    Gamut guide and ring 36t
    Sram 10spd X9 drivetrain
    ODI stem, bars, grips
    WTB Devo seat
    Truvativ Descendant cranks 165mm
    Azonic Outlaw wheels
    HT mag pedals
    and some other stuff too
    You're not entitled to anything until you work hard and earn it. CMQ
  3. #303
    biking is fun
    Reputation: climbingbubba's Avatar
    Ok, Finally got pics of mine and got it about where I want it
    Large turner dhr with ano rear and raw front
    RC4 with Progressive ti coil
    Boxxer R2C2
    Industry 9 classic hubs laced to EX500 hoops with Sapim CX-ray spokes
    Specialized Butcher 2.3 tires set up tubeless
    Gravity lite 7050 cranks
    Canfield Crampon pedals
    Shimano Saint brakes (have formula one's i'll try later)
    Shimano Saint shifter/rear der
    Sram 990 cassette
    e13 lg1+ guide
    WTB devo saddle
    FSA headset
    Deity black label bars
    Straitline drop stem
    ESI Chunky Grips
    Thomson seatpost
    Weight: 37.5 lbs
    and the pics
  4. #304
    Sunshine & Slippery Trail
    Reputation: andyb721's Avatar
    Quote Originally Posted by climbingbubba View Post
    Boxxer R2C2
    Sram 990 cassette
    e13 lg1+ guide
    WTB devo saddle
    FSA headset
    ESI Chunky Grips
    Thomson seatpost
    Weight: 37.5 lbs
    and the pics
    Looking pretty pimp! Love the raw!
    Should have some shots of mine up this weekend
  5. #305
    Bike setup:
    * Frame Size & Color: 2012 Blem DHR - Powder coat Granny Green front and Black Ano rear (IMO the rep-owder coated blemished frame looks even sexier!)
    * Rear Shock: Elka Stage 5, 350lb spring
    * Fork: 2011 Boxxer Team
    * Brakes: Hope V2 203mm front, 183mm rear
    * Shifter: Shimano Saint M810
    * Cranks: 2011 RaceFace Atlas FR (Ano Purple)
    * Chainguide: Gamut P-30
    * Rear Derailleur: Shimano Saint M810
    * Pedals: NC17 Sudpin III (Green)
    * Stem: Sixpack Splitz Direct Mount 45-55mm, currently set at 48mm (Ano Green)
    * Handlebar: Chromag Fubar OSX cut to 760mm (Ano Purple)
    * Seatpost: Sixpack (Purple)
    * Saddle: Spank Starblast
    * Bottom Bracket: RaceFace DH
    * Chainring: Gamut 36T
    * Cassette: Shimano XT M770 9 Speed 11-32
    * Headset: Cane Creek XX II
    * Grips: ODI/TroyLee Designs lock-ons
    * Front Tire: Maxxis Minion 2.0 DHF UST
    * Rear Tire: Maxxis Minion 2.0 DHF UST
    * Wheelset: 2011 Mavic Deemax
    Future changes:
    My Elka Stage 5 is currently leaking oil from the low speed compression knob as the knob is being turned. Seems like it had lost some nitrogen charge too. Will change to a Ti spring once the shock is serviced (local dealer is still waiting for parts from Elka). Just need to make sure I have the spring rate correct once I have the shock properly setup after servicing before ordering the Ti spring. Will also post my shock settings once it is serviced.
    Rider Setup
    *Weight: 175lb, 180-185lb geared
    *Height: 173cm (5"8')
    Pictures to follow next week.
  6. #306
    Reputation: saruti's Avatar
    hi guys
    what do you think about installing a thicker bottom headset ?
    and raising the front by half an inch?
    thanks
  7. #307
    Yeah it will work, but with a dual crown fork, can't you just extend the stanchions further down from the crowns to raise the front?
  8. #308
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    Quote Originally Posted by saruti View Post
    hi guys
    thanks
    Quote Originally Posted by turnerbikes
    The frame was designed around an external bearing, is this not a cheaper solution than Risse lower clamp? Not wanting to take anything away from Risse of course, and wtf is up with Fox having this issue forever and not flipping their bolt locations. With the vast adjustability available with the short head tube you can run external on the bottom and still slide the forks up and down to fine tune your ride.
    DT
    2011 DHR & Fox 40 Frame Contact
  9. #309
    thanks Marshall
    mgv101, the boxxer has a minimum of 154 mm from the bottom crown to the top of the stansions, so I want it to stay that way.
  10. #310
    biking is fun
    thanks Marshall
    if you check out the picture of mine a few posts you can see how it will look.
    I just built it up and already want to upgrade it ha ha. I have some formula one's laying around and would like to swap my boxxer r2c2 for a WC. Winter project I guess.
  11. #311
    Apr 2005
    on a related note, the XL DHR has no bolt clearance issue w/ ZS headset and stock fox 40 crown.
    Originally posted by bucksaw87
    I still fail to see how mustaches, fixies, and PBR are ironic.
  12. #312
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Quote Originally Posted by frorider View Post
    You get one of this years 40s on there?
    How you like it?
    I'm probably headed that way next spring.
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
  13. #313
    Quote Originally Posted by mgv101 View Post
    Bike setup:
    Future changes:
    Rider Setup
    Photos as promised:
  14. #314
    Kiwi that Flew
    Reputation: deanopatoni's Avatar
    Photos as promised:
    Looking sweet MGV101!
    Nice to see the sun out too.....
    --- deanopatoni ---
  15. #315
    I got this frame on warranty for my cracked 09 frame a few months ago. I've finally got some decent images of it, so here goes.
    Bike setup:
    * Frame Size & Color: Large, Raw front/Ano rear
    * Rear Shock: Fox RC4, 350lbs steel spring
    * Fork: RockShox Boxxer WC
    * Brakes: Hope Tech V2
    * Shifter: Shimano XT
    * Cranks: Shimano Saint
    * Chainguide: Gamut P30
    * Pedals: Superstar NanoTech
    * Stem: Hope direct mount stem
    * Handlebar: Renthal FatBar, cut to 760mm
    * Seatpost: Thomson Elite
    * Saddle: Nukeproof Plasma
    * Bottom Bracket: Shimano Saint
    * Chainring: E Thirteen G-ring 36t
    * Cassette: Shimano XT 11-32t
    * Headset: Hope 1.5" zero-stack
    * Grips: Odi Rogue
    * Front Tire: Schwalbe Dirty Dan 2.35
    * Front Rim: Sun Singletrack, sprayed red
    * Front Hub: Hope Pro2
    * Rear Tire: Schwalbe Dirty Dan 2.35
    * Rear Rim: WTB Dual Duty, sprayed red
    * Rear Hub: Hope pro 2
    * Future changes: K9 325lbs spring, Pro2/Stans Flow wheelset and some new cranks would be nice.
    *Rider Setup
    *Weight: 10.5st
    *Height: 6'
    Cheers.
  16. #316
    Apr 2005
    Quote Originally Posted by kidwoo View Post
    How you like it?
    nope, using the 40 from my previous build.
  17. #317
    what a beauty!
  18. #318
    graham888.
    where can you find a 325X3 Ti spring?
    i'm 72 kg. and think that the 350 is too firm for me...
    any other riders in my weight ride 350? ar 300?
    thanks
  19. #319
    Cheers, I'm so pleased on how this one rides over my drilled 09 DHR. Im hooked.
    K9industries here in the UK do all their springs in 25lbs increments. Apparently I need 10 posts to be able to show you a link, but a quick search on google should lead you to them fairly easilly.
  20. #320
    thanks
  21. #321
    Broken but on the mend
    Reputation: mzorich's Avatar
    Mar 2011
    where are you guys getting the raw with the black rear triangle from. i am about to buy a dhr from fanatic and hoping they do it. has anyone gotten one like that from them? also does it cost anything extra?
  22. #322
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Probably warranty replacements.
    Rolling on 29", 650b, 8.3" and 23mm
  23. #323
    Quote Originally Posted by mzorich View Post
    Not sure where people are getting this set up, but they are not warranty replacements (at least not all of them). You should be able to ask Fanatik to mix up the rear end for ya. They're pretty dialed with stuff like that.
  24. #324
    Mar 2011
    Quote Originally Posted by andyb721 View Post
    that would be awesome if the would do so something like that. i looked at the pics on there website and none of the builds have the 2 tone but it never herts to ask
  25. #325
    There's one left here:
    Turner Bikes Online Store
  26. #326
    Quote Originally Posted by Marshall Willanholly View Post
    That's what I'm talking about. Who here bought the candy blue one?
  27. #327
    Mar 2011
    so i talked to fanatic and they said they shouldn't have a problem doing it and seeing as how those are both factory colors it shouldn't cost any more either
  28. #328
    Reputation: forceyoda's Avatar
    Here is my finished dhr came in at 36.53 pounds
  29. #329
    Mean as
  30. #330
    Murdered out! Love the de-stickered Dorado.
  31. #331
    number 10 post
    posting this just to upload my frames picture
  32. #332
    Yes sir!
    I just got this beauty today! Now is the time to claim having the first Ano Green 2012 DHR of the thread!
    Here you go:
  33. #333
    Looks sick. Can't wait to see it built up.
  34. #334
    neither do I! the problem is im lack of seat, cranks, derailleur, chain, Chain Guide and headset.
    Im deciding between gravity gaps (59$ killer deal) or descendants @ 182$, im very light so "flex" on the descendants wont be an issue, but having to pay only 59 for the cranks is really tempting. what do you guys think I should choose?
    im going cane creek 40 for headset
    straitline silentguide for chainguide
    SRAM X.9 for Mech
    SDG I-Fly for seat
    and KMC SL for chain
    hope you like the partial build i am yet to have
  35. #335
    my new DHR
    just got my frame last week
    ordered a Medium
    and found out it's abit too long for my taste
    I'm 170m
    so almost changed the order to a Small..
    but I like the look of the Medium better.
    made a headset that make it a 10 mm shorter
    and changed my stem to the stratline 28mm stem
    the cockpit is shorter by a full 1 inch now
  36. #336
    here are some pics of the headset I made
  37. #337
    the headset and stem on the bike
  38. #338
    ordered decals for my boxxer from slik graphics to match the frame
    here is the full bike
    hope to get it dirty soooon
  39. #339
    Nice SS setup, what gearing do you run?
  40. #340
    its 36 front, 14 rear
  41. #341
    That's some nice work. Did you ever consider running a standard headset and trying one of those 10mm stems?
    http://www.nutsbike.com/tag/centre-stem
    Reading that article and Cesar's thread on Ridemonkey make it sounds like something I'd like to try. Only problem is I'd need a new frame since I wouldn't want my cockpit any shorter than it is now.
  42. #342
    this 10 mm stem is too hige for my taste :-)
  43. #343
    any riders here my weight?
    I'm 72kg
    found that my 300TI spring gets me 33% of SAG with the RC4
    what spring# do you run on your DHR ?
    thanks
  44. #344
    Gold it's the new Pink!
    Reputation: Crimson's Avatar
    Green for the Money and Gold for the Honeys 2
  45. #345
    holy spacer stack batman!
  46. #346
    Did somebody tried a Cane Creek Double Barrel Air in the DHR?
    Does it fit?
  47. #347
  48. #348
    which is the stock post mount size on the DHR frame?
  49. #349
    Thanks for posting this up Marshall!
  50. #350
    Who rides a Vivid or Vivid Air in the DHR?
    What Tune is the best?
    Nearly finished
    INN.vertical RACING like us on Facebook
    https://www.facebook.com/pages/INNve...69330129778785
    Sponsored by Turner, Rox, Bikeshuttle Tirol, Sram Rock Shox, Avid, ART, Bikepark Tirol, K9, Twenty6 and Radstudio Innsbruck
    Brother:
    My one:
  52. #352
    Cool pics of those DHRs!!
  53. #353
    biking is fun
    Here is the latest pic of mine. Recently added 2012 fox 40 and a sweet custom mud gaurd
    I also put the black DHR sticker set on recently but it was after these pics and I am way to lazy to upload more pics to just show the new stickers
  54. #354
    Reputation: eurospek's Avatar
    That looks wicked!!!!
    konahonzo
  55. #355
    Can finally post some pics of my DHR. So pumped on this bike, it is a machine!
    Here is my spec:
    Bike setup:
    * Frame Size & Color: xl anodized black
    * Rear Shock: Fox RC4 with 350lb spring
    * Fork: Rockshox Boxxer
    * Brakes: Avid Codes (2012)
    * Shifter: SRAM XO
    * Cranks: Truvativ Descendents, 165mm
    * Chainguide: e13 SRS+
    * Rear Derailleur: SRAM X9
    * Pedals: Easton Flats
    * Stem: Chromag
    * Handlebar: Chromag OSX
    * Seatpost: SDG I-Beam
    * Saddle: SDG I-Beam Storms
    * Bottom Bracket: Truvativ
    * Chainring: ?
    * Cassette: SRAM PG Dh thing
    * Headset: Cane Creek Angleset
    * Grips: ODI Ruffian
    * Front Tire: Minion DHF 3C
    * Front Rim: Sun Ringle MTX
    * Front Hub: Cove something of old Shocker build
    * Rear Tire: Minion DHF 3C
    * Rear Rim: Mavic 729
    * Rear Hub: Sun Ringle Abbah Lawwil
    *Rider Setup
    *Weight: 150lb
    *Height: 6'3"
    Check out the full DHR gallery and the article on the frame design, if you haven't already.
  56. #356
    Jan 2009
    Bike setup:
    * Frame Size & Color: Med Sangria Front/ Ano Black Rear
    * Rear Shock: DHX RC4 350lb Spring
    * Fork: Fox 40
    * Brakes: Hope V2 203/183
    * Shifter: X9
    * Cranks: Truvativ Descendant 170mm
    * Chainguide: MRP G2 SL
    * Rear Derailleur: X9
    * Pedals: Shimano DX
    * Stem: Hope
    * Seatpost: Thomson
    * Saddle: Chromag
    * Bottom Bracket: Truvativ GXP
    * Chainring: Truvativ 36T
    * Cassette: Sram XO 11-32 (yes, a 32...I stand and climb this beast)
    * Headset: Cane Creek Forty
    * Grips: ODI TLD
    * Front Tire: Minion DHF UST 2.5
    * Front Rim: Azonic Outlaw Ano Red
    * Front Hub: Azonic
    * Rear Tire: Minion DHF UST 2.5
    * Rear Rim: Azonic Outlaw Ano Red
    * Rear Hub: Azonic
    * Future changes: Schwalbe Hans Dampf DH
    *Rider Setup
    *Weight: 165 Geared Up
    *Height: 5'7"
    *Bike Weight: 40.52 lbs
  57. #357
    SICK DHR! Loving the red and black!
  58. #358
    Jan 2009
    Thanks! I do too!
  59. #359
    Elka
    any ELKA users in here?
    what are your settings?
    thanks
  60. #360
    thanks
  61. #361
    thanks
    Me! But I like RC4 more on the DHR.
    Here are the baseline settings that I have received from DT and Elka.
    Their suggestions were VERY different from each other.
    DT:
    I talked to a rider that has a DHR with Elka and is about your size. This is what he suggests as a baseline for Elka shock set up. Of course he has never ridden with you so use this as a starting point!
    400# spring at 180 lb rider....
    15/32 clicks of low speed comp
    3/15 clicks of high speed comp
    16/30 clicks of rebound
    Elka:
    Start with the following hydraulic adjustment on the shock and fine tune from there to your licking.
    High speed compression: full hard minus 8 clics
    Low speed compression: full hard minus 10 clics
    Rebound: full in minus 10-11 clics
    350# spring was also suggested for a 180 lb rider on the Elka site instead of 400 as suggested by DT.
    And here are my own settings:
    HS: 10
    LS: 15
    RB: 13
  62. #362
    my weight is 72 kg... (160lbs?)
    so I need a 300# spring?
  63. #363
    Maybe. Either a 300 or 350, I can't be sure.
    Guess it would depend on personal preference too.
  64. #364
    rode it yesterday with a 350# still spring (on my RC4 I have 300# TI ) I wanted the bike to be firmer, but still eat up everything...
    and from the first run it felt great.
    ELKA guys told me the basic settings
    after a few runs I open the HS, 2 clicks more and I love it
    I wonder if a 350# TI spring will make it even better
  65. #365
    Reputation: trap121's Avatar
    Mar 2011
    Is everyone sticking to the Turner recommended settings for their RC4? I'm running a #325 ti, and apprx 162-165lb with all my gear. I thinking the recommended 140 psi may not be enough.
    Any thoughts on psi or other settings?
  66. #366
    Now with flavor!!
    Quote Originally Posted by trap121 View Post
    Pressure in the piggy back causes more ramp up. The frame and the shock at baseline settings are already pretty progressive.
    Run it at the minimum. Unless you're doing something bender style and riding off roof tops for some reason, I think you'll find it works well.
  67. #367
    Aug 2010
    Anyone know if the DHR shock bolt is a standard bolt that can be find in hardware store?
    The shock bolt I found for sale on turner website really doesn't seem to be the rigth one for DHR.
  68. #368
    Now with flavor!!
    Quote Originally Posted by Zeta View Post
    You can find a shoulder bolt that will work.
    But yeah I don't see the dhr specific bolt kit on their website either.
    I don't think those bolts are used on other frames.......I might be wrong.
  69. #369
    Reputation: kreater's Avatar
    zeta i see that you are in canada. give brafasco a try. they have had bolts for my turners in the past, spot and sultan shock bolts. make sure the shoulder on the bolt is the same length as stock, you don't want any of the threads making contact on the shock reducers. but you prob already know that.
    Product designer @RSDBikes.com
    "Live dangerously and you live right."
    Johann Wolfgang von Goethe
  70. #370
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Currently sitting at 34.7lbs with the oh-so-righteous custom Vector Air HLR
    Ground Steeze. @iggy_strbac
  71. #371
    The orange looks sick!
    konahonzo
  72. #372
    Mar 2011
    What base settings are you guys starting with on your Fox 40's? I'm having trouble getting mine right.
  73. #373
    Jan 2009
    Start with the Fox website and go from there. Mine only needed a couple clicks here and there and it feels perfect.
  74. #374
    have a question for you guys, i bought a straitline silent guide for my DHR build but stupidly got the ISCG-old instead of the 05' one, i live in venezuela so having it returned would cost me the same as buying another guide again, so the question is, can i buy a BB to ISCG-old adapter and use this guide and not spend precious money on another guide? thanks!
  75. #375
    Buy another guide and get a Gamut. The adapter will cause chainline problems that'll piss you off for not getting the correct guide in the first place.
  76. #376
    My DHR frame was delivered from Turner last October, a week after I'd broken my shoulder.
    Finally got it dirty today at the new Mountain Creek Bike Park. Had a crap XC race in the morning, but a great afternoon riding DH on the "new" bike
  77. #377
    May 2012
    Quote Originally Posted by Iggz View Post
    Damn! Been a while since I've seen such a nice bike!
  78. #378
    Locs on Spokez
    Nov 2006
    Here's another one bru
    Quote Originally Posted by Johan_Eickmeyer View Post
    Thanks dude! It's a great feeling opening the garage every morning and seeing her waiting for me
    34.2 lbs
  79. #379
    Locs on Spokez
    Nov 2006
    Your BB is going to be reallllllly low but it will ride really fun-like
  80. #380
    May 2012
    Awesome rigs guys!
    I've just started my new build, got Turner DHR 2011 frame size L and Lyric RC2DH 170mm fork. Question is, will it blend? I mean, is it really insane to put these two together? I've been riding with 170mm forks on the front all my life (Junior T, other single crown forks etc.) UK DH trails and a bit of a freeride, and I never felt that I need anything more that. I'm not concerned about the head angle. 63 is damn slack so one degree stepper is not an issue for me. Weight wise, we're talking 2140 grams vs 2,689 grams for RockShox BoXXer WC Keronite which is the lightest 200mm fork, so that's a big plus. Any thoughts?
  81. #381
    Loving my DHR after having it act as an expensive coat rack for 7 months.
  82. #382
    Reputation: SylentK's Avatar
    Lookin good!
    Hey, how did you do your rear fender?
    Biker? I don't even know her.
  83. #383
    Quote Originally Posted by SylentK View Post
    Lookin good!
    Looks like a Mucky Nutz Bender Fender. Bender Fender 2.1
  84. #384
    Very similar, but I made it myself extending it down to completely block the gap between wheel and shock in the rear triangle.
  85. #385
    Can you post some pics? What did you make it from? I've been looking at doing something like this for a while now.
  86. #386
    Seconded. Would also be interested to hear if you're able to keep mud from slinging over the top of it, as most appear to have this happen with similar setups to yours.
  87. #387
    It's far from perfect, but from the mud stuck to it on the wheelside it definitely helps.
    It was made from a document binder cover, just the thin plastic. I'll try to remember to take some close-up photos.
  88. #388
    May 2012
    Bike setup:
    * Frame Size & Color: Medium, Black ano
    * Rear Shock: Fox RC4, 325lbs K9 steel spring
    * Fork: BOS Idylle
    * Brakes: XTR Levers, Saint Calipers
    * Shifter: Saint
    * Chainguide: E13 LG1+
    * Pedals: HT Pedals
    * Stem: RF ATLAS SL
    * Handlebar: RF ATLAS Stealth
    * Saddle: SDG I-Fly
    * Bottom Bracket: Reset HollowLite
    * Chainring: Chromag 36t
    * Cassette: SRAM PG-970 DH
    * Headset: Reset WAN.5 Shorty
    * Grips: Sunline
    * Front Tire: Maxxis HighRoller II 2.4 ST
    * Front Rim: EX721
    * Front Hub: ChrisKing
    * Rear Tire: Maxxis HighRoller II 2.4 3C
    * Rear Rim: EX721
    * Rear Hub: ChrisKing
    * Future changes: Rims-> ZTR Flow, Spokes-> Sapim CX-Ray
    *Rider Setup
    *Weight: 75kg
    *Height: 175cm
    Sadly i can't post a pic or a link, i will do later.
  89. #389
    In action.
  90. #390
    May 2012
    Quote Originally Posted by Allemalle View Post
    Bike setup:
    * Fork: BOS Idylle
    * Shifter: Saint
    * Pedals: HT Pedals
    * Stem: RF ATLAS SL
    * Saddle: SDG I-Fly
    * Grips: Sunline
    * Front Rim: EX721
    * Rear Rim: EX721
    *Rider Setup
    *Weight: 75kg
    *Height: 175cm
  91. #391
    damn that looks fast.
  92. #392
    Are this 2.4 new maxxis tires?
    How do they compare to the old 2.5 maxxis tires?
    Is there more mud clearance at the rear of the bike?
    May 2012
    Hi,
    yes, this are the new 2.4 maxxis, but there is no more mud clearance.
    I think maxxis only changed the labeling of the new tires.
  94. #394
    thanks
  95. #395
    Bike setup:
    * Fork: BOS Idylle
    * Shifter: Saint
    * Pedals: HT Pedals
    * Stem: RF ATLAS SL
    * Saddle: SDG I-Fly
    * Grips: Sunline
    * Front Rim: EX721
    * Rear Rim: EX721
    *Rider Setup
    *Weight: 75kg
    *Height: 175cm
    Hi Allemalle,
    I see that you have a k9 spring. Is it the race steel model ?
    I'm interested by a k9 race spring but the free lenght is 140 mm and on my actual fox spring it's 162 mm !! Is it compatible ?
    Mslide
  96. #396
    Locs on Spokez
    Nov 2006
    Keepin' the thread going hah
    10spd XO shifter/derailleur. 10spd Dura-Ace. 10spd KMC DLC chain - Murdered out my drivetrain
  97. #397
    May 2012
    K9 Spring
    Hi Mslide,
    yes, this is a K9 Race steel spring.
    It fits for shocks with 2,5", 2,75" and 3" stroke.
    For a Fox shock you will need an adapter or a shock trust bearing.
  98. #398
    Reputation: airwreck's Avatar
    nice custom paint job on the fire hydrant.
  99. #399
    May 2012
    Quote Originally Posted by Mslide View Post
    Hi Allemalle,
    Mslide
    weight chart for K9 springs
    http://viroproducts.ch/images/k9/Spring%20Weight.pdf
  100. #400
    Hi Allemalle,
    Thanks for all.
Members who have read this thread: 4
