Page 3 of 6 FirstFirst 123456 LastLast
Results 201 to 300 of 572
  1. #201
    fork upgrade
  2. #202
    Reputation: backshift's Avatar
    Nov 2008
    My build was a privateer kit from Turner that I plan on upgrading as time goes on.
    39.15lbs
    Bike setup:
    * Frame Size & Color: Med Raw
    * Rear Shock: RC4 w/350
    * Fork: 11' Fox 40
    * Brakes: Formula the one
    * Shifter: SRAM
    * Cranks: saint 165mm
    * Chainguide: E13
    * Rear Derailleur: SRAM
    * Pedals: twenty6
    * Stem: holzfeller
    * Handlebar: boo bar
    * Seatpost: Thompson
    * Saddle: turner
    * Chainring: saint
    * Headset: cane creek
    * Grips: odi
    * Front Tire: nevagrip 2.5
    * Front Rim: dt Swiss
    * Rear Tire: nevagrip 2.5
    * Rear Rim: dt Swiss
    * Future changes: Ti spring, maxxis meats, bling
    *Rider Setup: still dialing it in
    *Weight: 150
    *Height: 5'8"
  3. #203
    Slap happy crappiness
    Reputation: DHgnaR's Avatar
    Anyone wanna post a link to DW's advice on setting up a CCDB on the DHR?
    I'd rather have a bottle in front of me than a frontal lobotomy.
  4. #204
    Reputation: J-Ha's Avatar
    * Frame Size & Color: Small Raw
    * Rear Shock: DHX RC4
    * Fork: 2011 Fox 40
    * Brakes: Avid
    * Shifter: Saint
    * Cranks: Saint
    * Chainguide: E13
    * Rear Derailleur: Saint
    * Stem: Funn
    * Handlebar: Sunline 745
    * Saddle: an old BMX one
    * Wheelset: I-9 DH
  5. #205
    Reputation: trap121's Avatar
    Mar 2011
  6. #206
    Nice one! What bottom brake disc size are you running?
  7. #207
    Reputation: ridewithjo's Avatar
    Nov 2007
    Wow! Loving the black/silver combination.
  8. #208
    wow
  9. #209
    Sunshine & Slippery Trail
    Reputation: andyb721's Avatar
    Hey guys a couple of questions? I am 6'3" and am unsure whether to go the L or the XL. I currently ride a Cove Shocker in a L and am very happy with the reach. I measured it myself and got 16.5" but am in no way positive that is completely accurate?
    I noticed that there are people on here that are very happy with the L at 6'2" and people that are stoked with the XL at 6'4". Any help would be fantastic!
    Also, I weigh between 145 and 155lbs (I know, featherweight for height…). Am noticing some variance in spring weights. Any confirmation if I should be running a 350lbs spring?
    THanks. I am stoked to get this frame!!
  10. #210
    Elka Spring
    Quote Originally Posted by andyb721 View Post
    I weigh 155lbs and I'm running an Elka with a 300lbs spring. You can download the Elka MTB Application List (.pdf file) on their website which mentions that for Turner DHR spring M300x6.25x3.0 falls under 150-175lbs rider weight and M250x7.25x3.5 for 100-155lbs rider weight.
  11. #211
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    6'2" and wondering the same thing.
    Rolling on 29", 650b, 8.3" and 23mm
  12. #212
    my build
    Here's mine:
    Yay me but I'm still adjusting from an all mountain bike (2008 Giant Reign X1). For the most part this new bike, straight from the shop has been really awesome, I'm really happy. However, I'm noticing a handling issue when leaving the ground and going airborne. I used to feel this way too when I first got my Giant. We eventually fixed this handling issue by rolling the handle bars back and moving some of the chips on the headset from top to bottom for more height. However, for the lack of better terms, there is too much room still in the cockpit and it causes me to drop an elbow and fly off in the wrong direction.
    Here's what I've done so far with the DHR:
    moved 2 chips from the top of the stem to the bottom (only one left on top now)
    rolled the handle bars back as far as they'd go without losing height
    scooted the seat as far forward as possible, without exceeding max.
    So I still feel like maybe I'm missing a tad bit of height. I'm curious about the following:
    the handlebars are way wider than the giant's, should I swap/ride see how it feels? trim the bars i'm running on the dhr?
    can i add more chips? im worried about about putting too much leverage on the fork if I scoot the chips around too much.
    are there other stems that would bring the bars closer than the easton havoc direct mount does?
    i guess the bottom line is I'm convinced I want more height due to past experience. more height, not a lot but more but I dont want to damage my bike and I want to stay safe too. sorry to post this here but I'm a new member and I cant start my own thread yet....
  13. #213
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    How tall are you and what size is the frame? I'd be careful about raising the bars too much. The DHR is noticeably slacker than your previous Giant and when the bars get too high it will make it harder to keep the front weighted in turns. Of course, the wider bars also bring your weight forward a bit.
    I understand you have past experience with the issue of cockpit size, but I'm not understanding the relationship of bar height to dropping an elbow and jumping crooked. Without knowing more it sounds like a technique issue rather than an equipment problem.
    FWIW, I'm 5'10", I've got about 18mm of spacers under my top crown, a 45mm stem, and 29.5" wide bars. Feels pretty good now, but I'm still playing with bar height a bit. Thinking about moving them a little lower. To me, the key is the relationship between feet and hands, so a lower BB, like the DHR, needs lower hands to keep me feeling balanced.
    Don't worry too much about the number of spacers under the crown. Peaty doesn't skimp on his:
  14. #214
    I'm 5'9" and its a medium. I realize it may be technique but because I have to fight to accomplish what used to be 2nd nature is frustrating...i then get less aggressive and more reluctant because I'm basically out of control, haha. My attack position then feels over exaggerated in order to compensate for this cockpit setup. So you'll see me practically kissing the handle bars to be in attack position. From take off to landing as well, its also like my center of gravity shifts too far front to back and lacks control because my arms are often too straight, making upper body strength not as effective as it could be. Make sense? I know I'm just a small adjustment from comfort and control...then back to shredding i go...
  15. #215
    also that pic you posted, is that a dual crown? if so, that was kind of what I was wondering (purchase some more spacers and try a couple more type thing) unless there was somethign I could purchase that goes directly under the DM stem....?
  16. #216
    This bike is just sex on wheels! So nice.
    What is the chain protection that you are using? I am looking at moving away from the ol' tube setup. Are you running cleartape under this to make it easier to remove when time to replace. Does the bike run nice and quiet with this setup?
    Quote Originally Posted by charvey9 View Post
    Sick builds/pics so far!
    I'm eagerly awaiting my frame arrival, but most of the components have landed this week and I'm just waiting for the next Medium Black to make its way back home to Portland.
    Here is my build specs:
    Bike setup:
    * Frame Size & Color: Medium Ano Black (couldn't wait until March for the Ano Green)
    * Fork: 2011 Fox 40
    * Brakes: Shimano Saint
    * Shifter: Shimano Saint
    * Cranks: Shimano Saint
    * Chainguide: e*thirteen LG1+
    * Rear Derailleur: Shimano Saint
    * Pedals: Point 1 Podium
    * Stem: Answer "The One" direct mount
    * Handlebar: Answer Pro Taper
    * Seatpost: Thomson Elite
    * Saddle: Tioga Spyder
    * Bottom Bracket: Shimano Saint
    * Chainring: Shimano Saint 36T
    * Cassette: Dura Ace 12-23 (race wheels) Ultegra 12-23 (FR wheels)
    * Headset: Cane Creek Angleset
    * Grips: Answer Fall Line DH
    * Front Tire: Maxxis Minion DHF 3C (race wheels) Maxxis Minion Swamp Thing (FR wheels)
    * Front Rim: Stans Flow ZTR (race wheels) Azonic Outlaw (FR wheels)
    * Front Hub: Hope Pro II (race wheels) Azonic (FR wheels)
    * Rear Tire: Maxxis Minion DHF 3C (race wheels) Maxxis Minion Swamp Thing (FR wheels)
    * Rear Rim: Stans Flow ZTR (race wheels) Azonic Outlaw (FR wheels)
    * Rear Hub: Hope Pro II (race wheels) Azonic (FR wheels)
    * Future changes: Nuke Proof Ti spring, swap out some DHF's for my FR wheels when the trails dry up.
    *Rider Setup
    *Weight: 170
    *Height: 5'10"
    I'm hoping to have pics of the complete bike by the end of the month, for now here is a link to the pics I've taken of my components.
    2011 Turner DHR Build
    Hey Charvey. I noticed you are running an Angleset. I plan on running one as well. Is there a specific model that is needed for the DHR? What model are you running? Thanks.
  18. #218
    Quote Originally Posted by dropdeadfed View Post
    That's a Boxxer in that pic. I don't know of anything commercially available that would go directly under the DM stem.
    Thanks! Here are the answers to your questions: Chain Slap Solutions | Anybody's Bike Blog
  19. #219
    Quote Originally Posted by Marshall Willanholly View Post
    Thanks a bunch! I love that there are others out there as hell bent on a quiet and good looking bike, as much as riding it!! Great blog post!
  20. #220
    Bike setup:
    * Frame Size & Color: Lg Black Ano
    * Rear Shock: CCDB w/ 500lbs spring
    * Fork: '11/'12 Fox 40
    * Brakes: '11 Avid Code 203f 185r
    * Shifter: SRAM X.0
    * Cranks: E.13/Hive DH 165mm
    * Chainguide: E.13 SRS+
    * Rear Derailleur: SRAM X.0
    * Pedals: Point1 Podium
    * Stem: Point1 Split Second
    * Handlebar: Raceface Atlas FR
    * Seatpost: Thompson Elite
    * Saddle: WTB Silverado CroMo
    * Bottom Bracket: E.13/Hive
    * Chainring: E.13 Guidering 36t
    * Cassette: Shimano Dura-Ace 11-23t
    * Headset: Chris King InSet5 w/ 1"1/8 baseplate
    * Grips: ODI Ruffian
    * Front Tire: Maxxis Minion DHF Super Tacky 2.5
    * Front Rim: Mavic EX 823
    * Front Hub: Hadley
    * Rear Tire: Maxxis High Roller 2 3C 2.4
    * Rear Rim: Mavic EX 823
    * Rear Hub: Hadley
    * Future changes: Ti spring, possibly Formula The Ones but the Codes feel damn good so maybe not.
    *Rider Setup
    *Weight: 225
    *Height: 6'1
  21. #221
    Hubba hubba.
    I love the look of the these black DHR's and the new black 40.
  22. #222
    Trying to get some parts sorted out for mine (Cannot wait!!). How is everyone doing with the Anglesets. I noticed a few in this thread. Any of the popping and/or loosening issues that people seem to be having?
    Any thoughts on this as the other option if not the Zero Stack?
    Cane Creek Cycling Components :: Components :: Headsets
    I'd suggest getting one of these:
    Universal Cycles -- Chris King InSet 49mm Headset - 2011 Model 4
  24. #224
    Thanks Marshall. Any reason why you would recommend one of those? You have/had an Angleset? Was it a bad experience?
  25. #225
    Quick question: what's the DW DHR bearing code? I assume all 8 are the same kind, right?
    Are the bearings available @enduro?
    Reputation: 2w4s's Avatar
    Mar 2005
    Quick question for the shorties. I'm just a tad over 5'6" and have been running a small round tube DHR for a couple years am going to get a new DW frame. I'm thinking about getting a medium and am asking if anybody else who used to run a small round tube has some ride time on a medium, any comments would be great!
    nothing witty here...
  27. #227
    Now with flavor!!
    Reputation: kidwoo's Avatar
    The smalls are miniscule.
    See if you can get a ride in on a medium somewhere. Like I've said before, due to the slacker head angle and same wheelbase of the new ones (compared to the round tubes) the cockpit is actually a little smaller.
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
  28. #228
    Mar 2005
    Quote Originally Posted by kidwoo View Post
    yeah yeah i know, i've ridden 2 mediums but i haven't ridden a small. the medium felt really similar to my small so as long as I can keep the bar height close to the same Im sure it will be great, cant wait to get it built and ridden.
  29. #229
    Mar 2005
    Quote Originally Posted by DHgnaR View Post
    Bike setup:
    * Shifter: SRAM X.0
    * Front Hub: Hadley
    * Rear Hub: Hadley
    *Rider Setup
    *Weight: 225
    *Height: 6'1
    That's the best looking DH bike I have ever seen. too bad mine will be baddererer.
  30. #230
    Bike setup:
    * Frame Size & Color: L Raw
    * Rear Shock: Fox RC4
    * Fork: Rock Shox Boxxer CR1 cartridge
    * Brakes: Hope Mono M4
    * Shifter: XT
    * Cranks: E-Thirteen 165mm
    * Chainguide: E-Thirteen
    * Rear Derailleur: Saint ss
    * Pedals: Straitline
    * Stem: E-Thirteen
    * Handlebar: Renthal
    * Seatpost: SDG
    * Saddle: SDG
    * Bottom Bracket: E-Thirteen
    * Chainring: Renthal 36t
    * Cassette: Sram PG970 12-26
    * Headset: Chris King Inset 5
    * Grips: Lizard Skins
    * Front Tire: Maxxis Minion Front
    * Front Rim: Mavic 721
    * Front Hub: Hope
    * Rear Tire: Maxxis Minion Front
    * Rear Rim: Mavic 721
    * Rear Hub: Hope
    * Future changes: Titaniun or K9 race steel spring with bearings, Ti shock mount bolts
    *Rider Setup
    *Weight:200 pounds
    *Height: 6”
    The only thing that makes a little worried about is the fact that with this headset which uses an outside lower cup I’ve made the bike headangle even slacker!
  31. #231
    looks damn quick stood still.
  32. #232
    Quote Originally Posted by nickhart View Post
    It’s quite fast, totally quiet and unbelievably stiff!
  33. #233
    Stray Bullet
    Reputation: Nagaredama's Avatar
    2w4s lets see pics!
  34. #234
  35. #235
    Working on my Drops
    Reputation: MTBAlex's Avatar
    Mar 2006
    The more I ride my DHR the more I love it. It is super stable when it is steep and super plush. It's like falling on a pillow every time.
  36. #236
    Hi there,
    Are you happy with the XO brakes?
  37. #237
    Reputation: Artin Aga's Avatar
    Quote Originally Posted by chauzie View Post
    well putting the DHR next to a Demo makes the DHR look like a hack.
    Demo = super model
    DHR = catalog model
    why so many homers need to defend a catalog model anyway?
    just my 02
    God get this Taiwan .....p o s......... out of here or are they China now ?
  38. #238
    Quote Originally Posted by Artin Aga View Post
    Does that mean Turners will be P.O.S when they are manufactured in Taiwan?
  39. #239
    Mar 2005
    A dhr from France
    Here's mine
    Bike setup:
    * Frame Size & Color: M Black Ano
    * Rear Shock: CCDB w/ 400lbs spring
    * Fork: 2011 Marzo 888 evo Rc3 Ti
    * Brakes: Hope Tech 4 full black version with goodridge braided hose 203mm
    * Shifter: xtr
    * Cranks: Saint 165mm
    * Chainguide: E.13 LG1+
    * Pedals: twenty6
    * Stem: Hope DM integrated stem
    * Handlebar: Easton Havoc Carbon
    * Saddle: Turner
    * Bottom Bracket: C King
    * Chainring: DnUp 36
    * Headset: Chris King Devolution
    * Front Tire: Michelin Comp16 2.5
    * Front Hub: C King
    * Rear Tire: Michelin Comp24 2.5
    * Rear Hub: C King
    * Future changes: another headset ( to reduce the slacker angle)
    Here are the pics !
  40. #240
    Beauty. . . . .
    How much slacker headangle, have you measured it?
    How the Cane Creek feels on the Turner?
  41. #241
    Working on my Drops
    Mar 2006
    nice ride! I like the black for sure, but i'm biased too.
    But that looks super slack compared to everyone else.
  42. #242
    subscribed
    im ordering mine soon
  43. #243
    Mar 2005
    new headset... new position
    so new picture with a less super slack dhr !
    does it look more normal ?
  44. #244
    Batman called, he wants his bike back.
    Looks fantastic.
  45. #245
    Working on my Drops
    Mar 2006
    Nice!! Awesome bike! Super bling
  46. #246
    Reputation: bajaguy's Avatar
    Bike setup:
    * Frame Size & Color: Large Raw
    * Rear Shock: Fox RC4 350lb Spring
    * Fork: 2012 Fox 40 Kashima
    * Brakes: Saint w/ Ice Tech Rotors 203F/180R
    * Shifter: Sram XO 10sp
    * Chainguide: MRP G2 SL
    * Rear Derailleur: Sram X0 10sp
    * Pedals: Shimano M647
    * Stem: Easton Havoc
    * Chainring: 36T Renthal
    * Cassette: Dura Ace 11-27
    * Front Tire: Maxxis DHF UST
    * Front Rim: Crankbrothers Opium
    * Front Hub: Crankbrothers Opium
    * Rear Tire: Maxxis DHF UST
    * Rear Rim: Crankbrothers Opium
    * Rear Hub: Crankbrothers Opium
    * Future changes: TI Spring
    *Rider Setup
    *Weight: 155lbs
    *Height: 5'11
    The bike comes in at 38lbs 12oz.
  47. #247
    Reputation: eurospek's Avatar
    The Raw with the red and Kashima looks absolutely sick.
    konahonzo
  48. #248
    Bajaguy,that thing looks so SICK. I just received my frame last night. Will post pics once it's built up. Actually here is a question. I weigh 150lbs. Any recommendations on spring weight? I'm thinking 300, it came with a 450, which obviously wont do...
  49. #249
    Indonesian Biker
    Reputation: setan13's Avatar
    dear all DHR lover,
    im planning to build a DH bike and DHR is one of my option...however, i hardly find anyone in my town who got DHR...
    therefore, kindly need your help to describe any advantage / disadvantage of DHR frame..
    im 68 kg 170 cm and ride quite agressive with my santa cruz bullit..
    thanks in advance for your help
  50. #250
    Apr 2005
    benniturner, what settings are you using on your CCDB? I just built my DHR this week, and rode it yesterday. based on inputs from Malcolm at CC, and my own general experience w/ setting up the CCDB, i started off with the following settings: LSC = 14 clicks in, LSR = 16 clicks in, HSC = 1.0 turns in, HSR = 1.5 turns in. THe bike felt pretty good on that first ride, but on my next ride I'm going to decrease the HSC to 0.8 turns in, and reduce the LSR to 15 clicks in.
    I weigh 193 lbs / 88 kgs without helmet/pads/shoes. using 400 lb steel spring for now.
    Really like the 63 HA on anything steepish. I have the bar height pretty low, which helps keep that front tire carving on the flatter terrain.
    pics: too lazy right now. imagine something that is all black with gold and silver bits.
    Originally posted by bucksaw87
    I still fail to see how mustaches, fixies, and PBR are ironic.
  51. #251
    Anybody on a small 2011 have any seat buzz issues?
    I have an 08 DHR & I had to slide the seat forward & raise it a bit higher than I wanted. I even cut an arc in the seat to lower it a bit.
  52. #252
    Indonesian Biker
    Quote Originally Posted by setan13 View Post
    dear all DHR lover,
    can anyone help me on this..???
    or i should make separated thread..??
    i really need your opinion ^^
    thanks in advance
  53. #253
    Apr 2005
    this is a set-up thread, so try starting a new thread with some specific questions. the geometry + very low center of gravity + the DW link + Turner zerk-fitted pivots are some of the reasons this frame is different than a lot of other frames.
    Attached Thumbnails Attached Thumbnails 2011 DHR set-ups-turner-dw-dhr-1-compr.jpg
  54. #254
    Gold it's the new Pink!
    Reputation: Crimson's Avatar
    thanks in advance
    Starting a seperate thread would be best. However you can also check out this month's issue of Bike Magazine and last month's issue of Decline. In addition Mtb Action is currently testing the bike so keep your eyes out for an article. The article will answer all your questions and the rave reviews will seal the deal for you.
  55. #255
    Mar 2011
    Quote Originally Posted by Toddmac1 View Post
    I have 11 DHR and had a lot of buzz, i raised the seat more than I would like but it got rid of it
  56. #256
    thanks in advance
    Quote Originally Posted by Crimson View Post
    Some links to the reviews mentioned:
    decline magazine September 2011
    Bike | See Inside Page 106 | Sep-11 | Zinio Digital Magazines & Books
  57. #257
    Mar 2005
    Hello Frorider,
    my weight is around 88 too... i've got a 400 ti spring
    here are my settings for the CCDB
    Slow Compression 14 clicks
    slow rebound 16 clicks
    High compression, 0.5 turn from full open
    high rebound : 1.75 turn from full open
  58. #258
    Indonesian Biker
    Quote Originally Posted by frorider View Post
    thanks so much guys...and i will start the new thread
  59. #259
    Mar 2005
    Quote Originally Posted by trap121 View Post
    Instead of raising your seat more than you would like you can run a bmx seat. I ran a S&M thin seat on my small '08 and it got rid of the seat buzz and let me keep my seat height where i wanted it, it's about 3/4" shorter than the WTB on my trail bike.
    This is the seat on my '12 DHR.
  60. #260
    Reputation: airwreck's Avatar
    2w4s, did you go with a medium or small?
  61. #261
    Reputation: geosnow's Avatar
    Hi,
    Here is my setup
    Bike setup:
    * Frame Size & Color: Small 2011, Black ano
    * Rear Shock: CCDB, Ti 350
    * Fork: 888 RC3 LTD for Commencal with Ti Spring
    * Brakes: Magura MT6 203, 180
    * Shifter: XX
    * Cranks: Saint 165
    * Chainguide: MRP SL mini
    * Rear Derailleur: XX Medium
    * Pedals: Twenty6 old
    * Stem: Raceface Atlas Ti
    * Handlebar: Easton Carbon
    * Seatpost: Thomson Masterpiece
    * Saddle: WTB Devo Ti
    * Bottom Bracket: CK orange ceramic
    * Chainring: Raceface 36T
    * Cassette: SRAM Red 11-26
    * Headset: CK Inset
    * Grips: Odi Ruffian
    * Front Tire: Minion 2.5 3C EXO 1-Ply, Latex Tubes
    * Front Rim: ZTR Flow, DT Swiss Supercomp
    * Front Hub: CK, silver
    * Rear Tire: Minion 2.5 EXO 1-Ply, Latex Tubes
    * Rear Rim: ZTR Flow, DT Swiss Supercomp
    * Rear Hub: CK, silver
    * Future changes: Mango CK with ENVE AM and DT Aere. I may change for the X0 DH derailleur as well.
    *Rider Setup:
    LSC = 8 clicks in
    LSR = 10 clicks in
    HSC = 1.0 turns in, no big drops yet
    HSR = 2.0 turns in
    *Weight: 83kg or 183lbs
    *Height: 1.69m
  62. #262
    ... and if we just ...
    The funny thing is that more or less all Euro DH Bike producer will have a 63 angle on their bikes!
  63. #263
    Does anybody now if any rear fender for the DHR will ever come to production from Turner?
  64. #264
    Quote Originally Posted by geosnow View Post
  65. #265
    Mar 2005
    Quote Originally Posted by airwreck View Post
    airwreck i went with a medium. compared to my '08 small the cockpit is very similar, bar and seat height are identical but the DW is about 3/4" longer in front which is want i wanted. I only notice the extra length when seated, when i'm in riding position the bike feels nearly identical to the single pivot. I will have a more in-depth review after next weekend's 3 day trip to N* but after 2 quick laps on a local trail i have to say that the DW is a better all-round bike than the older version.
  66. #266
    [QUOTE=2w4s;8501837]Instead of raising your seat more than you would like you can run a bmx seat. I ran a S&M thin seat on my small '08 and it got rid of the seat buzz and let me keep my seat height where i wanted it, it's about 3/4" shorter than the WTB on my trail bike.
    I have the same seat, I had to push it forward on the rails & notch the back & it's still a bit high. While it's ok most of the time I would prefer the seat a bit lower, I have a long torso & short legs.
    I think I read somewhere this issue was addressed on the new DHR so the seat can be lowered a bit but I can’t find it so I thought I'd ask around.
    Anyhow I ordered a SM 2011 fro Go-Ride so I will get back on topic & post pics & specs when it's finished.
  67. #267
    Apr 2005
    Quote Originally Posted by Benniturner View Post
    Hello Frorider,
    Played around a lot with the CCDB settings and settled on:
    LSC = 16 clicks in
    LSR = 16 clicks in
    HSC = 1.0 turns in
    HSR = 1.5 turns in
    Like other DW bikes I've ridden, the DHR benefits from having relatively little HSC and LSC damping, but I found that going too low gave pedal strikes in unwarranted situations; OTOH, going too high made the rear end feel spiky (duh).
    Also found that a 15 mm spacer under crown (with Answer direct mount stem, which has no drop and is similar to many DM stems), with a ZS headset, gave a nice compromise between keeping the bars low enough for the turns, but (just) high enough to feel right coming into jumps etc.
  68. #268
    Bike setup:
    * Frame Size & Color: XL RAAAAAAAAAAAAAAWWWWW
    * Rear Shock: DHX RC4 400lb
    * Fork: Marzocchi 888 RC3 Ti EVO
    * Brakes: Hope Tech V2 203f+r
    * Shifter: X.9
    * Cranks: Saint 170
    * Chainguide: Straitline Silentguide
    * Rear Derailleur: X.9 short
    * Pedals: Wellgo MG-1
    * Stem: Marzocchi
    * Handlebar: Easton Havoc 750
    * Saddle: random
    * Bottom Bracket: Saint
    * Chainring: Saint 36T
    * Cassette: Saint 11-28T
    * Headset: Crankcreek 40
    * Grips: Oury
    * Front Tire: DHF UST
    * Front Wheel: Deemax
    * Rear Wheel: Deemax
    * Rear Tire: DHR UST
    * Future changes:
    Need to trim the seatpost slightly by about an inch, can't quite insert it as low as I want as the welding at the bottom opening stops the post extending through. Pedals might change to Spank Spikes
    *Rider Setup
    *Weight: 185 rtr
    *Height: 6'2"
    Shame it's got to act as a coat rack until next season due to rotator cuff injury, can't wait to enjoy it though.
  69. #269
    What bars are those?
    konahonzo
  70. #270
    Dec 2009
    Hi pround owners of the DHR,
    I was hoping I could join your ranks after buying a brand new frame off someone at pinkbike, and it was like Christmas came early when I pulled it out of the box after it just got delivered. The frame was truly beautiful, a raw, cnc-ed and wielded piece of art.
    But after dropping it off at my LBS to have it built up, the mechanic got back to me and said when the shock was removed, the rear-end wasn't free-moving at all - far from it. He said it might be a manufacturing defect, and the frame wasn't straight and true. I told him to try greasing the pivot bearings to see if it helped, because as far as I know the frame could have been sitting around for quite a bit, but it doesn't look good.
    Did anyone of you have the problem of a seizing rear-end when you received the frame? Mine is definitely a recalled and strengthened one as it has the extra gusset at the top-tube/head tube junction, but it still has the decals instead of being laser-etched, so it might be from an older batch.
    And now I'm worried sick, and it only makes matters worse when the mechanic/owner of shop tells you about the bad news with a glee - like it served me right for not buying a Mondraker or Transition frame from him instead.
    Sorry for the long post, but I hope you guys can give me some advice - would be best if someone from Turner can help out for a bit too?
    Thanks a lot.
    Kenneth
  71. #271
    Nov 2007
    No worries at all with mine.
    It's normal to have decals on a raw DHR, laser etching only comes with the ano finish.
    Send an email to Greg and you'll know why you are not riding a Mondraker or Transition!
    Good luck.
  72. #272
    Reputation: forceyoda's Avatar
    Quote Originally Posted by yt.kenneth View Post
    Thanks a lot.
    Kenneth
    Have you verified this yourself?
    If the shop only wants to work on stuff they sell i would take it somewhere else, or even better start doing your own work.
    My DHR has a point beyond full extension where it feels like it binds but it is only when moved past what full shock extension would be. Lubing the bearings yourself is also supper easy.
  73. #273
    Are you sure it was "NEW", any signs it was built up?
    Mine was ok out of the box, no problems cycling the swing arm W/O shock.
    Turner's warranty should cover a second owner, give them a call.
  74. #274
    Thanks a lot.
    Kenneth
    Are the pivots properly torqued? See DHR overhaul guide here:
    http://www.turnerbikes.com/011/tech/...R_overhaul.pdf
    Did the box appear damaged during shipping?
    If your frame has that gusset between the top/ down tube, then it was not a part of the first batch which was recalled. Additionally, the gusset at the down/ head tube should be convex. This gusset on the recalled frames was concave. I had one of the first batch frames and it did crack... the warrantied replacement was not a modified frame, it was brand new.
    +1 for decals on raw frames, etched for ano frames
    Like the other guys said... just get in touch with the warranty department at Turner, they won't waste any time getting you some answers. Good luck!
  75. #275
    Dec 2009
    The mechanic concluded that it might be the o-rings that are causing the friction, and after contacting Turner about it, this is what I got back from Greg:
    "Hi Kenneth,
    You will feel resistance in the suspension and it is caused by the O-rings.
    There is a break in period. Ride and enjoy.
    Have a great weekend.
    Greg"
    So now I have the bike built up, it seems normal enough when I sit and bounce on it for a bit, but I have to back out the rebound damping completely to have it return to full travel in a moderate (slightly slow) speed.
    I haven't tried it out in a trail yet, but the adjustability of the shock rebound seems to be compromised.
    Do your DHRs loosen up after a few runs, and is there a discernible "break-in" period for you guys?
    Even so, I love how my ride's looking now. Will post some pics soon.
  76. #276
    biking is fun
    Reputation: climbingbubba's Avatar
    Just paid for my large DHR with raw front and black ano rear. couldn't afford a new one so I picked up a used one of pinkbike. Should be here by next week. Going to be a slow build though since its snowing here and i want to save for new wheels and such over the winter so might not be done til january or so. might be hard to look at it for that long unbuilt.
    So if anyone has some tuning advice for someone who is 190 lbs with a RC4 who likes a lively bike then feel free to post them.
  77. #277
    Hi there folks, I'm just really close to ordering my new DHR. I have a M Sunday and I'm 6'1" tall, i was wondering which way i had to go, M size or L size, so if any of you ever had a Sunday (or not) and has the same issue deciding which size to get, please help me, I have also owned a Mongoose Boot'r L and I liked how that cockpit felt, the problem is that geometry charts for each of the bikes mentioned before are not compatible t each other (some use effective top tube and others use stack and reach) and i don't know how to make the comparison myself with those numbers. Also I'm the first in my country to get a 2012 DW DHR so can't test no bike. Thanks, any help is appreciated. proud of your builds BTW. Cheers.
  78. #278
    100% large. Will fit perfectly.
    Quote Originally Posted by downhiller900sl View Post
  79. #279
    Quote Originally Posted by bliz2z View Post
    Second this! Large for sure mate. I'm 6'3" and went the XL and don't regret it one little bit! Perfect!
  80. #280
    biking is fun
    Third that, I am just under 6'1 and tried a medium around a parking lot and it felt way too cramped. I like smaller bikes but this one would have not even been fun to ride. My knees hit the handle bars and such.
    I just bought a large so I am hoping it fits.
    Also, according to the turner site. the range for the large is 5'10 - 6'1 so you should be asking if you should go L or XL
  81. #281
    Apr 2005
    Quote Originally Posted by eurospek View Post
    785 mm race face atlas. see the white logo?
  82. #282
    Apr 2005
    Had some wet riding in October, so I made a flexible fender from the cover of a 3 ring binder. the natural curve of the plastic keeps it pointing toward the seatpost, so it doesn't ever flop down and buzz on the tire. very low profile, so no change in mud clearance. works well.
  83. #283
    Now with flavor!!
    Give me your man card right now. I'm clipping the corner.
    Three more clips and we confiscate the bike.
  84. #284
    Apr 2005
    dude, you're prominently thanked on a review of a 29er tire. so check yo self.
  85. #285
    Now with flavor!!
    Never forget the difference between author and consultant.
    You authored that fender.
  86. #286
    biking is fun
    Is there a reason turner specs the DHR with a 34t front? is the suspension optimized for a 34t?
    Just curious because I will be buying a new chainring for my build anyway so I was curious which size to get.
  87. #287
    Apr 2005
    srsly though, i saw the various posts on this thread and others painting a picture in which a DHR fender was some sort of difficult-to-achieve goal, so on a whim I made one in 5 mins that works perfectly well and has no clearance issues or mud build up.
    i don't need a fender but was just curious where all the concerns were coming from.
    i'm curious like that.
  88. #288
    Now with flavor!!
    You know this is the internet right? Where downhillers are not men with upper body strength willing to take chances with conviction, but rather delicate flowers who cringe not only in the sunlight of reality but also at the mere sound of a dremel......
  89. #289
    Apr 2005
    you are waxing poetic.
    have you bought a 29er yet? looks like a snow free winter for us, so add to the quiver yo.
  90. #290
    @frorider and kidwoo, would both of you take your e-fight somewhere else, please?
    Reputation: Samumalaga's Avatar
    increible
  92. #292
    Now with flavor!!
    Tell him to quit making goofy fenders.
  93. #293
    Reputation: Bullit_cn's Avatar
    epic...
    When trails gets tougher, Just stand up and deliver.
  94. #294
    Now with flavor!!
    Transubstantiation........
  95. #295
    why would I? I dont have any time to make some childish couple stop e-fighting, I want to mind in my own business. I think that when I, and all of the people subscribed to this thread; receive an alert of new Reply is to see some amazing and drool-making build of a DW-Link DHR, or at least some interesting chat regarding the after-mentioned bike. Stop it, NOW.
    and BTW, thanks in advance for your comprehension and agreement.
  96. #296
    Dec 2009
    The mystery unravels. After going for a few rides hoping the suspension would run-in (which the binding did disappear), I found the rear shock bolt coming loose when I got home from the trail today, and tightening it re-introduced the binding.
    Puzzled, I removed the shock and measured the width of the shock eyelets (as Greg of Turner Bikes suggested if the binding continues), and I discovered that they measured 21.8mm instead of the correct width of 22.2mm. So the reason my brand new DHR binds in its travel is because Turner fitted the wrong shock eyelets to the shock.
    And now the inner face of the shock mounts of BOTH the front triangle and the upper DW link/shock cradle is scored so bad that feeling the deep ruts in the aluminum with my fingers make me cringe. My new frame had no more than 3 rides on it. Guys check the width of your bushings if your DHR is having a slight binding.
    I've emailed Greg about this, and I don't know what he's going to do for warranty.
    Since I'll be needing new eyelets/bushings anyway, I'm thinking the needle bearings from RWC. Has anyone tried them before, and do them need any proprietary tools to install?
  97. #297
    Now with flavor!!
    Dear downhiller900sl: Kidwoo has posted a reply to the thread: 2011 DHR set-ups
    I'm supposed to care what a supposedly grown man throws a tantrum over when it's not a picture of a pretty bicycle and ONLY a picture of a pretty bicycle........on an INTERNET FORUM? Quit your whining you little baby. Frorider and have both shared more setup advice on these bikes than you possibly could have in your massive 8 post history. And newsflash: We know each other. You can also unsubscribe to a thread and just check back periodically. You have internet access?
  98. #298
    Now with flavor!!
    That honestly shouldn't make that much of a difference. Something DT told me to do before I even got my frame was to remove the reducer hardware, and sand out that orange coating on the inside of the DU bushing. It allows it to pivot a little easier without backing out or tightening the bolt. Try that first just because it's something that's easy to do. Bearings are obviously a superior setup but this is something you can try first.
    I wouldn't even worry about the front triangle mount. The shock barely moves at all there.
    0.4mm difference is way less than the gap left with the correctly sized spacers on lots of frames I've had. You should see the gap on my specialized sx frame. I actually grabbed another set of spacers to put in the shock it's so bad.
  99. #299
    injured reserve list
    Reputation: Scrub's Avatar
    Here you go whiners
    This is what I have, its a medium
    You're not entitled to anything until you work hard and earn it. CMQ
  100. #300
    Now with flavor!!
    Good thing you can't hear creaks over the internet.
    I never sent you any those photos from the GRT. Here's a good one since john's head is right under your butt.
