Results 1 to 3 of 3
    2009 5 Spot DW Large - What length rear brake hose
    Hi,
    I am starting a build soon with a Large used frame, and can see that I might need to get a new brake hose. What length do you use please? I will be running a 660m handlebar, with 90mm stem if that alters things.
    Thanks Neil
    Do yourself a favor and ditch the hipster bars for something 710mm+.
    Hi, seems its around 140cm from my understanding from another forum, but what is the value of the wider handlebar? Would I also need a shorter stem?
