Results 1 to 5 of 5
    steep fast and loose :)
    2006 6 Pack (Large) - Frame Weight ?
    any idea how much my 06 Large 6 Pack weighs in (grammes preferred) ?
    I also run a CCDB (190 x 50) inc 650# Ti spring, which I can weigh separately.
    TIA
    Simon.
    Reputation: wilks's Avatar
    about 8.7 lbs with coil shock - you can convert it yourself!
    thanks wilks. i'd like the weight without shock if someone has it, thanks
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Interestingly enough, Turner still has the page up with the old 6Pack specs:
    http://www.turnerbikes.com/Specs6Pak.html
    6Pack with RP3 is 7.7lbs.
    7.5x2.0 RP3 is about 210g.
    That's 3283g (for a medium frame)
    http://www.google.com/search?q=7.7lb...ient=firefox-a
    _MK
    Reputation: serhij's Avatar
    Apr 2005
    Frame without the shock, but with shock mounting bolts:
    M-size 3045g (~6.71 lbs)
    L-size 3150g (~6.95 lbs)
