Results 1 to 5 of 5
    2006 5 spot shock?
    Hi
    so I got a 2nd hand 06 spot frame which came with a vanilla shock, I wanted an air and got a used rp2 but I have a couple of questions,
    the van is 200mm eye to eye but I thought they took 190mm eye to eye so which one is correct?{as the rp2 is 190mm}
    and the hardware when fitted to the new shock seems slightly narrow for the rockers but when I search its hardware for a fox shock so should all fox shocks take the same hardware for the same frames?
    thanks peeps
    190mm x 50mm is the correct shock length, & shock mounting hardware is the same for all fox shocks - should be 6mm x 22mm (12.7mm eyelet bushes)
    any ideas how/why it ended up with a 200mm shock on it?
    Previous owner probably didn't understand the importance of proper shock length, effect on geometry and how the bike rides so just whacked on a shock that he got cheap. You've done the right thing.
    felt a lot nicer after putting the new shock on, I wondered why the rear end felt so harsh before
  1. 2006 5 spot shock hardware
    By lee p in forum Turner
    Last Post: 07-23-2011, 02:08 PM
  2. Spot 2006 shock length/stroke
    By Deano in forum Turner
    Last Post: 06-16-2011, 01:11 PM
  3. 5.5 rockers on 2006 spot
    By shureimage in forum Turner
    Last Post: 07-25-2010, 06:37 PM
  4. 5 Spot 2006. Should I get M or L ??
    By srullik in forum Turner
    Last Post: 01-29-2007, 04:27 AM
  5. 2006 5 Spot colors
    By Mr Pink in forum Turner
    Last Post: 11-22-2005, 03:18 PM
