Results 1 to 2 of 2
Thread: 100mm on a 02
    100mm on a 02
    Anu body useing a 100mm fork on a 02?If so how do you like it and did you do anything to the rear?Such as using XCE rockers?If so which ones?
    Reputation: jennasdad's Avatar
    I purchased a used 02 that had a 105mm Marathon S. After learning the bike was built for an 80mm fork I purchased a Fox RLC 100 (Larry, at Mtn High Cycles was a great help). Turns out the Fox has a much shorter axle to crown distance then the S (think about 10mm). I left the Fox at 100mm (Larry's recommendation) knowing 80mm travel was available. I also put on a set of XCE rockers (not the Romic version). These changes transformed the bike and I attribute most of the change to the fork. The bike feels much better balanced. With the Marathon S the front wheel would get light, sometimes lift off the ground, on tight uphill sections. Now, the front is frimly planted. I don't have any experience with 80mm fork on the bike but hope this is of some help. My guess is you could use a 100mm fork with even the stock rockers successfully. Take an axle to crown measurement of your current setup and compare to 100mm forks you are considering. I am amazed how bike characteristics can change so dramatically with changes of a few millimeters. Good luck.
  1. Trying to decide between: 80mm or 100mm RX?
    By 1speed_Mike in forum Titus
    Last Post: 04-03-2004, 04:43 PM
  2. Matathon S ('02 100mm) oil height recomendations
    By mitchp in forum Shocks and Suspension
    Last Post: 02-26-2004, 10:42 AM
  3. Weight of the 100mm Noleen Mega Air....
    By KMan in forum Weight Weenies
    Last Post: 02-08-2004, 01:38 PM
  4. 100mm Float RLC on an Id?
    By sperky in forum Ellsworth
    Last Post: 01-22-2004, 02:57 PM
  5. 2001 RX SID XC.....80 or 100mm travel?
    By KMan in forum Shocks and Suspension
    Last Post: 01-22-2004, 12:00 PM
