09 Turner 5 Spot Refurb - Piccies
I never did like the blue it came as (but it was cheap), so after 2 years decided that a re-fresh was called for, so here it is, both front and rear triangle painted and lacquered satin Black, a great job and a ‘big up’ for Fastline coatings in Preston Lancashire, England, super work.
Decided that 1 x 10 was not for me and so have bitten the bullet and gone 2 x 10. New XTR front Mech , New Arch EX rims on pro2 evo hubs and a new 2 x MRP chain device and a XT Chainset
Just needs some ‘5 spot’ decals for the TT and we are sorted for the next 2 years. (or until another upgrade is purchased, which will probably be before the months out)
P1040761 by eastham_david, on Flickr
P1040765 by eastham_david, on Flickr
P1040763 by eastham_david, on Flickr
P1040764 by eastham_david, on Flickr
P1040762 by eastham_david, on Flickr
thanks for looking
Dave
Great looking ride and a nice build you got there. Looks speedy
Mrp?
Looks great, I've got almost the same project with an '09 5-Spot (a blue one!). Just had a question on how the 2x10 setup is working out and specifically the MRP. I'm always a little nervous about bottom bracket/friction mounted guides. Would like to know how it's working for you.
looks good, can I ask how much $ with shipping it cost you.
that shock doesn't hit the frame at full compression? the piggyback is huge and i was under the impression that the pre '10 frames could only take a very limited amount of piggyback shocks. i have a van rc and the piggyback is smaller but it doesn't look there's room for much more.
RIP Adam Yauch
"M.C. for what I AM and do, the A is for Adam and the lyrics; true"
I'm on a Medium 09/10 Spot and have used a DHX 5 Coil (with the BO knob removed) and now using a Monarch RC3. The fit is tight but I've yet to experience the piggyback hitting the downtube.
right, but it appears that the monarch piggyback is much bigger and that is a small frame.
RIP Adam Yauch
The friction BB mounted chain device works a treat. I had a Gamut with my 2 x 9 set up and that was great as well.
It cost £70, no shipping costs as the Powder coater is local.
The shock dos not hit the downtube, neither did my Van R one either. I have tried both shocks with no air in the RS and no spring in the van R and they are close but they do not touch.
very nice, going to put a pushed plus on my 11 spot soon. while your at the refurbish you may want to replace the seat stay rocker clevis bolts. Turner has updated those with a newer more stout version.
"Live dangerously and you live right."
Johann Wolfgang von Goethe
Did they include a new bushing kit with the refresh? Seems that they would need to take them our for the sand blasting and repaint. Can't imagine they would put the old ones back in.
I removed the bushes before i took it to the powder coaters. They masked all of the bush areas of and then coated it.
I then re-installed all the bushes when they had caoted it. The bushes were perfect so no need to replace.
Really nice looking ride!
sweet ride i have an 09 5 spot and was wondering how much was the new powder coat as i might do mine .
Does anyone know where to get custom Turner decals?
- You may not post replies
- You may not edit your posts
Forum Rules
