Results 1 to 3 of 3
    Will 156mm Q SRAM XX Crankset fit on Supefly 100 Carbon?
    I'm looking for a new 29" Carbon FS bike and the Superfly 100 is near the top of my list. However, due to past knee problems, I prefer a narrow q factor crank. I'm currently running the 156mm XX crankset on my Titus Racer X. Does anyone know if this crank will fit on a Superfly 100 Carbon frame? For those with a wider 168mm crank, is there much clearance between the crankarms and chainstays?
    Thanks,
    Mike
    I just put XX1 168Q on my 2012 SF100 and have a 1/2 between the crank and swing arm on each side.
    I hate that name.
    Reputation: blunderbuss's Avatar
    The 156 XX is what comes on the 2013 SF100 SL (carbon) Pro. So if you're looking at a 2013 frame, no worries.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
  1. SRAM XX Crankset Q Factor for SJ 29 Comp Carbon?
    By mminfl in forum Specialized
    Last Post: 08-02-2013, 03:43 PM
  2. Replies: 14
    Last Post: 01-14-2012, 07:01 AM
  3. FS 29er that will fit Sram XX 156mm crank?
    By cocheese in forum 29er Bikes
    Last Post: 12-04-2011, 10:11 AM
  4. SRAM Carbon Crankset conversion to 1x10 help
    By anthonyi in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-21-2011, 06:25 PM
  5. Replies: 7
    Last Post: 03-02-2011, 02:29 AM
