Results 1 to 16 of 16
    Reputation: BoomerBrian's Avatar
    What stem length you running on your Trek?
    Just curious what everyone is running. I feel like the 105 stock Cobia stem is a bit long. Was wanting to try a new stem and wondering what everyone else is running?
    Jan 2013
    90mm. On my 2012 Fuel Ex. Factory stem. Debating wether to switch to a shorter one though, 50ish mm.
    Reputation: SpeedStarr's Avatar
    I had a 90mm on my EX8 and went to 70mm. I like the improvement in body position and quicker reaction to steering input.
    I replaced my OEM 105mm stem with a 70mm on my 2010 Rumble 1. Also swapped out the OEM bar with a Chromag Fubar OSX 780mm. Same comment that SpeedStarr said but also way easier to bring the front up over objects or just for fun.
    Thanks for the input everyone. May try 70. It seems to be what people are happy with.
    Jan 2009
    Stem length is totally dependent on rider size, frame size and riding style.
    I run a 100 on my Superfly XL. I'm 6'3" and normally proportioned. 700mm low rise bar.
    Also length changes with height, check out this calculator to see how your stem change could effect your position. Stem Comparison Tool | yojimg.net
    Agreed Zippin. I will check out the calculator.
    Andrew
    Reputation: drizzoh's Avatar
    70mm here with 685mm bars on my 2012 Superfly; much nicer for me than the 105mm stem and ~740mm bars it came with.
    Andrew || Trek Superfly 100 Carbon || Santa Cruz 5010 Carbon C
    620mm origin 8 all mountain pro riser bars and bontrager race 65mm stem on my ex9
    660 mm raceface next SL carbons and 50mm Dirty dog reaper stem on my trek marlin 29er single speed.
    I think they both came with 90mm or 100mm but I have short lil T-Rex arms and had to swap em out.
    Jan 2013
    Something just hit me. My Fuel 7 has a 9 cm stem now with 7 degree angle. Should I change to a 5 cm instead, the bar would also come DOWN abit, not just closer. Maybe I should compensate that by getting a 17 degree 5 cm stem instead of a 7 degree. So that basically the handlebars will only come closer to me, and not further down in the process.
    How did you guys do when you switched to shorter stems? Did you go with a higher angle aswell?
    Sep 2012
    90mm stem down from 105mm on a L frame Mamba. Perfect for me helped some on descending with a 700mm bar.
    I run the stem inverted.
    Reputation: ky_savage's Avatar
    I've wanted to get a new stem as well but wasn't quite sure on the length I needed. I'll use the calculator. I have my OEM stem inverted right now on my Marlin.
    '12 Trek Marlin Signature Green
    Avid Speed Dial 7 levers
    Avid BB7's w/HS1 rotors
    ODI Rouge grips
    Sigma BC1009 computer
    Oct 2011
    On my 2012 EX8 I have switched to a 50 mm stem and a 750 low rise bar. It's been comfortable and has increased my handling on my rides. However, everyone is different, but I like this set up for me. I have the same set up on my Slash 9.
    Jun 2010
    Stock 90mm on my '10 EX8. I just switched from a white to black stem.
    Reputation: danmtchl's Avatar
    Sep 2004
    120 on my Elite 9.8 HT.
    Reputation: Rock Surf's Avatar
    Aug 2010
    Went from stock 80mm, 7deg rise stem, to 70mm, 0deg rise.
