Results 1 to 27 of 27
    Reputation: FueLEX8's Avatar
    Weight of the 2008 Fuel EX 8?
    anyone know Weight of the 2008 Fuel EX 8 frame? or where can I get it.
    Thanks.
    Rock Star!!!
    Reputation: byron's Avatar
    the frame is 4.7 lbs when my bike was stock it was 27.5lbs now I have it down to 25 lbs
    Collaborate,Ride
    fuel ex 8
    now I know how much it weights the components are 20lbs so the bike is 24.7
    Thanks.
    Reputation: antonio's Avatar
    Jan 2005
    Whoah! 4.7lbs is REALLY light, even without a shock.
    Are you sure?
    Reputation: shifturmind's Avatar
    Quote Originally Posted by byron
    What did you do to shave off the 2.5 lbs?
    2008 Trek Fuel EX 8
    2008 Trek 6500
    Yakima King Joe 2
    Softride Dura Rack
    Oct 2007
    Quote Originally Posted by antonio
    Are you sure?
    I don't think you can weigh a dual suspension frame without including the shock. It is a non-functional frame, especially on the EX suspension design. If the shock is .45 lbs, a weight I have seen listed for the RP2, that would mean the frame weight is really more like 5.15 lbs. That is still very light, but is at least in a realistic range of accuracy.
    I tend to think the only way to weigh the frame, without serious chance of some error in calculations, is to strip the bike down and just weigh the frame (and shock) without anything else on it. If you try to use published weights on components, and compare that to the overall bike weight, it just won't work because those weights vary in reality with the actual components. When you start factoring in the possible range of variation on all the different components on a bike, you could get a pretty wide variation from published weights compared to what a particular bike actually weighs.
    The published weight for a 2009 Fuel EX 9.9 frame, as set forth in a review, is 4.92 pounds. It is hard to believe the 2008 aluminum version would be lighter than the new carbon version designed specifically to be lighter.
    Jan 2005
    Quote Originally Posted by Gatorback
    I don't think you can weigh a dual suspension frame without including the shock. . .
    I agree. I'm more inclined to believe that the Fuel EX aluminum frame is in the 6lb range, but was curious to hear how Byron weighed his frame to get 4.7lbs.
    Antonio
    Rock Star!!!
    the striped down frame was was 4.7 no rear shock, no headset,no seat post clamp. that was the reading at my local bike shop digital scale. I just hope their scale was accurate, but just for the record carbon fiber frames are not always lighter the aluminum frames, there are other advantages other then weight on a carbon frame.
    how did I bring the weight down to 25lbs you ask? Chris king hubs, no tube rims, Titec pluto saddle,crosmark tires, eggbeaters pedals ,race face seat post and stem, Martha breaks and new rotors.
    Collaborate,Ride
    Oct 2007
    Quote Originally Posted by shifturmind
    I give you an example of how I did so on an '07 Fisher Hi-Fi Pro. It weighed about 27 pounds even with SPD pedals when I got it (I'm not sure which version of the SPDs). It now weighs a hair under 25 pounds. The changes are the following:
    New wheels (Stans ZTR 355 with WTB hubs)
    Lighter tires and tubeless (Maxxis Crossmark Exceptions w/ Stan's tubeless set-up)
    Thompson Masterpiece seatpost
    WTB Rocket V saddle with Ti rails
    Bontrager Carbon X-Lite riser bar
    Avid Juicy Ultimate brakes (switched out from Juicy 7s)
    X-9 trigger shifters (switched out from Shimano LX tigger shifters)
    X-0 derailleur (switched out with the XTR so I could go up the upgraded shifters)
    Eggbeater SL pedals, but with Ti spindles
    I shaved 2.8 lbs changing:
    Cassette: Shimano XT 11-34.
    Chain: Shimano XT.
    Fork: Rock Shox Sid Team 100.
    Grips: Sette Superlight Foam.
    Handlebar: Specialized S-Works Carbon Flat.
    Rotors: Alligator Serrated Ti.
    Saddle: Sette SLX carbon/ti.
    Seat Clamp: Woodmand Ti.
    Spacers: Sette Carbon.
    Stem: FSA O/S 115.
    Tires: Continental Race King Supersonic 2.2
    Wheelset: American Classic Disc MTB 26.
    I'm also considering changing the seatpost and to convert it tubeless.
    if the frame weight 4.7 without the Fox RP2, 4.7+205 grams.
    So the frame with shock weight 5.14 pounds
    Oct 2007
    Quote Originally Posted by FueLEX8
    Chain: Shimano XT.
    Stem: FSA O/S 115.
    I'm assuming that Fork swap was a big weight saver--is that right?
    yes it was, i saved almost 1 pound with the new fork, what else can I change to drop more weight? with less money of course, i have invested like $1.2k in upgrades so i dont want to spend a lot
    gas money for epic trips.
    edit: just weighed an 09 Fuel EX 8 about 2 and a half hours ago in the shop. Full build + stock pedals (crank bro candys) was 29.4. Those pedals are heavy as fyck though, so I expect it is probably pretty similar w/out pedals
    Oct 2007
    Quote Originally Posted by William42
    Good answer.
    Jan 2005
    Here's an ad from an eBay store that lists a medium frame weight at 5.84lbs.
    http://cgi.ebay.com/TREK-FUEL-EX8-w-...d=p3286.c0.m14
    Reputation: leathernuts's Avatar
    My 08 EX9 weighed 27.4 at two different LBS's. Different than stock is 2.1 crossmarks exception series tires, stans tubeless, specialized phenom saddle, easton monkey xc bars, pg990 sram rear cassette, bottle cage and candy SL pedals.
    Sure would like to get mine closer to the 25's. I guess wheels would make the bid difference.
    I'll have to check my notes when I go home, but if I remember right my 2008 EX 8 w/ RP2 was 6.2 lbs for a Large (19.5") frame only.
    my fuel ex 8
    here are some pics of my trek
    i dont know the total weight but i think its gonna be in the 23-24 lbs range
    Reputation: pagey's Avatar
    What size SID is that?
    cheers
    Pagey
    Jan 2005
    Nice build, but I can't help but wonder if you bought the wrong bike.
    Nothing wrong with making a trail-bike raceable, but the flipped stem, narrow bars, short fork (which significantly alters the geometry), all seem to contradict the original purpose of the frame.
    Ant
    I have been running a F100RLC on my EX8 and the handling is good. It makes a more XC head angle (70.65*) and does not take away form the rear suspension working like it should. It does make the fork feel a bit short on travel; this is due to a bit of added front weight bias. I'll be going to a Float 140 RLC (HT will be slacked to 68.5*) this weekend so I will have a back to back comparison from short to longer. If I lived where the trails are not so rocky (Chico - Bidwell Park), I would stay with the 100mm.
    the handling is good, and confortable, and the fork size is 100mm. i think it dont afect the geometry, the ex 9 come with a talas and can be down to 100mm
    actually the talas is 90-110-130 on the ex9
    Lionel Hutz, Esq.
    Reputation: Thirdrawn's Avatar
    It does affect the geometry. Forks with adjustable travel are nice because you can wind down the travel for climbs shifting your weight forward so it's more centered on the bike. Alternatively, you can wind up the travel and shift your weight rearward for descents. I doubt that the bike was made with the intent that it would be ridden with the lower-end of the travel always in use.
    I'm not saying that you broke some law and we have to confiscate your bike. But, you have altered the bike to the point where I doubt it handles anything like it used to. I'd say the modification colors your opinion of the bike to the point where you shouldn't offer up your experience as an accurate portrayal of how the bike naturally handles.
    It's your bike, though. Do what you want with it. I put red grips on mine and I like the Jones XRs. I'm sure someone here would nail me to a cross for that. I also replaced the seat and cranks and I lower the stem when I ride in certain conditions so I'll get better cornering traction. It's my bike, damnit, and I like it that way.
    2007 Trek Fuel EX 8
    1999 Trek 7000 --- Dragonfly Green = Sexy
    2002 Trek 2100
    2008 Felt New Belgium Cruiser
    Jan 2005
    If the frame is designed around a 130mm fork, the geometry is going to get steeper by about a degree and a half when using a 100mm fork. The change should quicken up the steering, lengthen the top tube, and drop the bb height a bit when compared to the measurements posted on Treks website.
