Results 1 to 3 of 3
    Reputation: pixelninja's Avatar
    Upgrading fork on Cali?
    My wife has a Trek Cali 29er, which came with a heavy 100mm coil Suntour fork. I'd like to upgrade her to a lighter, more adjustable air fork. I'm interested in the X-Fusion Slide, but I'm concerned about how a different fork that doesn't have the "G2" geometry offset will affect the handling. Will putting a 100mm that doesn't have as much fork offset change the handling? What about putting on a 120mm fork?
    Any and all feedback would be greatly appreciated!
    "If you suck, that means I'm better. The more you suck, the better I am. So. Let me count the ways you suck." - Scribb
    Sep 2004
    Quote Originally Posted by pixelninja View Post
    It's best to get a G2 (51mm offset) fork as that's how the frame is designed. If you aren't happy with the handling as is, then maybe consider a non-G2 fork.
    Changing travel is changing your HT angle, which will drastically change your handling. I think doing the 120mm change will have a greater impact on handling than just going non-G2. The 120mm fork will slow your bike handling down, which is often the inherent problem with 29ers anyways so I'd assume this is a bad idea.
    Quote Originally Posted by notenoughtime View Post
    Thanks for the info. it's not that she's unhappy with the handling. It's just that the stock fork is super heavy and really harsh. It has preload adjustment, but it's minimal.
  1. Upgrading fork......
    By Bryan1113 in forum 29er Bikes
    Last Post: 04-16-2013, 04:51 PM
  2. Upgrading my fork.
    By EmbraceTheHate in forum Shocks and Suspension
    Last Post: 09-24-2012, 06:46 PM
  3. Upgrading fork to 20mm+ over OEM fork acceptable?
    By aedubber in forum Specialized
    Last Post: 10-16-2011, 11:26 PM
  4. Need some help with upgrading to a new fork please
    By aedubber in forum Shocks and Suspension
    Last Post: 07-16-2011, 05:53 PM
  5. Upgrading Fork
    By hang10jeff in forum Trek
    Last Post: 03-17-2011, 09:44 AM
