    Reputation: justinboden's Avatar
    Trek Y Frame and Rear Disc brakes???
    Is it possible to convert the rear UTD of a Trek Y frame so that it will accept disc brakes?
    Does anyone have any good advice or aftermarket kits I can look at that for sure work with the rear, or has anyone used welding to get disc tabs on there Y Frame's rear triangle?
    Thanks a lot for the help!
    Lionel Hutz, Esq.
    Reputation: Thirdrawn's Avatar
    Brake Therapy has a conversion kit that attaches to the brake boss of a linear-pull system.
    http://www.therapycomponents.com/conversion.htm
    2007 Trek Fuel EX 8
    1999 Trek 7000 --- Dragonfly Green = Sexy
    2002 Trek 2100
    2008 Felt New Belgium Cruiser
    Thanks, I have heard about issues with brake alignment with these though? What about the A2Z adapter tabs?
    Razor
    Reputation: RazorHolt's Avatar
    Trek Y Frame Rear Disc Mod
    Recently updated my Trek Y frame to have rear disc brakes. Simple enough to do if you can tig weld or know of a tig welder. I just got a disc brake adaptor the 160 to 210 step up adaptor, cut it to suit and welded it to the rear triangle. I used a rear wheel with an old disc and caliper to set it up. Realy easy. What a difference it has made, not only does it look cool, but it has increased the stopping power too. See photo.
