Results 1 to 6 of 6
    Sooz
    Reputation: sooza's Avatar
    Feb 2012
    Trek TopFuel seat post keeps slipping
    I have a 2011 Trek Top Fuel 9.9ssl mountain bike with a Race XXX Lite seatpost that keeps slipping. When I got the bike, the post was too long and would not allow me to lower it to achieve the seat height I wanted (bottom of post would impact being in frame sea tube bend), so I arranged for my bike dealer to cut the seat post a small amount. After the cut, the seatpost still has 100mm of length inside the frame seat tube. I have tightened the Bontrager seat clamp to 5.5lbs (recommended limit). After normal cross country type riding, the seat post keeps slipping into the frame. I would greatly appreciate some help on how to fix this. Should I be using some carbon non-slip paste?
    Seatpost diameter is 34mm, seat post clamp has a 39 stamped on it.
    I would greatly appreciate suggestions.
    Sooz
    Feb 2012
    Correction, seat post collar tightening torque is 5.5Nm, not lbs as originally stated.
    Sep 2012
    It will not hurt anything to try Finishline carbon grip in your seat tube. Your lbs should have it around and install it for you.
    Sooz
    Feb 2012
    Thank-you. Thats what I did and it has worked. I tested it on a 2 hour trail ride and then a 50km race and there was no slippage. I was also advised separately to also try a seat post collar like a Salsa or Thompson, but the carbon grip has worked to I have kept the Bontrager collar on.
    Sep 2012
    Great to hear. If you have any further issues, spring for the Salsa Liplock clamp. They just work. Enjoy your ride.
    Sooz
    Feb 2012
    thank-you
  1. My seat post keeps slipping......
    By honkylipz in forum Specialized
    Last Post: 09-07-2013, 03:58 PM
  2. 429 Seat Post Slipping
    By edbraunbeck in forum Pivot Cycles
    Last Post: 10-28-2012, 09:45 AM
  3. Seat Post Slipping
    By aroundoz in forum Motobecane
    Last Post: 09-20-2011, 01:33 PM
  4. EMD9 seat post slipping
    By pstaff15 in forum Niner Bikes
    Last Post: 08-02-2011, 01:17 PM
  5. Slipping seat post - WTB Phoenix
    By wv_bob in forum Vintage, Retro, Classic
    Last Post: 02-02-2011, 03:23 PM
