Results 1 to 5 of 5
    Mar 2013
    Trek Stache 130mm - 140mm fork ?
    Thinking about upgrading the fork on my 2013 Stache 7. I was thinking about a 2014 Rock shock revelation or Pike. Looks like the pike is only a 140mm. Does anyone have any experience with a longer travel fork on the Stache. Thanks in advance.
    Jan 2014
    Bump, did you find anything out about this or decide on a fork?
    Mar 2013
    Quote Originally Posted by wbrougier View Post
    Nope. Nothing yet
    Reputation: 722ish's Avatar
    Don't forget to consider the axle to crown length as well, some 140mm lengths are very similar to other 120mm forks and it may not affect the hta/bb so much in the end and you gain travel. The g2 offset may be gone, and while some forks are 51mm offset, I can't speak for the revelation or the pike. I know some companies have started to offset all 29er forks 51mm, but it is a detail to keep in mind when and if you do decide to change it up and don't wish to lose the offset. I think if you are concerned with height and travel, I would go with the revelation, as you can always knock the travel down from 140 to 120 or even less if need be, which I doubt based on you wanting more anyway, and I believe the only way to get a 120mm capable damper in a pike is through the specialized s works business in one of the newer evo bikes they have, maybe the camber evo which may make that difficult if the need ever did arise based on a warranty issue or something of that nature.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    10 Gary Fisher Cobia - 13 Trek Madone 5.2 - 14 Trek Fuel Ex8
    I just saw this in another thread regarding the pike, it should be available soon in 120mm. I am not sure if that is of any concern, but would allow you to change the travel accordingly for any warranty work etc.
    X-Post - Has anyone reduced a 2014 Pike 29er down to 120mm yet?
  1. Trek EX 29er 9 140mm fork?
    By soulcraft29er in forum Trek
    Last Post: 11-07-2013, 07:01 PM
  2. 140mm to 130mm fork conversion?
    By Drew44x in forum General Discussion
    Last Post: 08-27-2013, 12:39 PM
  3. Fox Float RL 130mm-140mm Travel Change
    By CaseyDC in forum Shocks and Suspension
    Last Post: 12-20-2011, 05:21 PM
  4. Slapping a 140mm fork on my trek fuel ex 6 2010
    By toothfairy320 in forum Trek
    Last Post: 06-01-2011, 02:20 PM
  5. 2010 stumpjumper fsr float 130mm rl to 140mm
    By paddy73 in forum Specialized
    Last Post: 05-09-2011, 06:46 AM
Members who have read this thread: 7
