    May 2013
    Trek Mamba Fork Upgrade?
    Hey everyone. Perspective Mamba buyer here.
    as a bigger guy i'm having concerns that the spring suspension might not be ideal for me. I was wondering if the mamba is easily upgradeable to something using air suspension. I read some concerns that the Mamba wasn't able to accept different forks for some reason. Is this true?
    Thanks everyone!
    Yes the Mamba is easy to upgrade.
    1-1/8 non-taper steer tube 100mm
    I just upgraded to a Tower Pro 100mm, I am 221 down from 238 the tower is night day difference.
    You can also run a taper steer tube but you would need to change your headset.
    Jim Roberts
    JBI Armory
    FFL 07 / SOT
    469-236-9507
    Reputation: hankscorpio's Avatar
    Jun 2012
    The Mamba has G2 geometry so technically if you alter to a non G2 fork you will alter the bike's geometry. I have had a hard time finding G2 forks my self. At least forks under 800 bucks.
    The G2 offset is 51mm and I believe the standard offset is 46. Everything I've read is that by going to a 46 you will lose some of the agility in handling. If i'm not mistaken the tower has a 48mm offset so that will effect the bike's handling less then a regular 46.
    Did you notice any difference Jim?
    Reputation: riotactor10's Avatar
    Quote Originally Posted by hankscorpio View Post
    Jim - I'm also curious about this - how are liking the Manitou - that fork seems to come up quite a bit when upgrading the G2 frame forks....any big differences. Thanks!
  1. Replies: 0
    Last Post: 12-27-2012, 08:21 PM
  2. Looking for a rigid fork for my 29Žer 2012 Trek Mamba.
    By Eirikur in forum 29er Components
    Last Post: 08-14-2012, 10:35 AM
  3. Replies: 1
    Last Post: 06-11-2012, 07:03 PM
  4. Trek HT fork upgrade..
    By jbev88 in forum Shocks and Suspension
    Last Post: 12-11-2011, 12:43 PM
  5. Trek Marlin & Mamba Fork Question
    By pitbull30 in forum Trek
    Last Post: 11-02-2011, 05:57 PM
