Results 1 to 7 of 7
    Reputation: CaRaBeeN's Avatar
    Mar 2012
    Trek Fuel EX 9.8 -> 2013/26"/130mm or 2015/27.5"/120mm
    2013:
    Trek Fuel EX 9.8 -> 2013/26"/130mm or 2015/27.5"/120mm-al_bike_magic_2161325.jpg
    2015:
    Trek Fuel EX 9.8 -> 2013/26"/130mm or 2015/27.5"/120mm-1642228-ru7q9n26n7u7-large.jpg
    I still don't get the hype with 650b's yet. Although they promise the fun factor of riding, I stick with 26" as I don't need climb faster nor descent over obstacles with ease...
    Which one would you pick?
    2012 Trek Slash 9
    Wheel size aside, I'd go with the 15 for the fancy reactive valving in the rear shock. A very noticeably improvement.
    The drive towards achievement and success is the motive power of civilization.
    Quote Originally Posted by kosmo View Post
    This.
    I've ridden both Re:aktiv and non DRCV shocks, and the new Re:aktiv ones are so far above the old ones that there's not even a comparison. You can ride "wide-open" on a supple air-pressure and still pedal like a demon.
    Granted, the climb setting is almost TOO stiff and I never use it except on roads.
    Mar 2012
    Maybe the shock I could have been upgraded for 2013 FuelEX? Than travel will be 120mm and geo will be affected...
    2012 Trek Slash 9
    Unless you can find a match for the 2013 shock in terms of length and shock travel, I wouldn't mess with it.
    I like the 27.5" a lot. Give it a try.
    Mar 2012
    But the price different is double in between
    2012 Trek Slash 9
    Should have mentioned that in the first post! Heh.
    The 2015 is better. Is it double the price better? That's not for me to decide. Go ride both. If the 2013 is used, see if you can take it for a trail ride and see what you think.
    Have fun!
  1. Replies: 11
    Last Post: 1 Week Ago, 01:04 AM
  2. Replies: 0
    Last Post: 1 Week Ago, 01:55 PM
  3. Replies: 4
    Last Post: 05-20-2014, 11:02 AM
  4. Replies: 9
    Last Post: 05-12-2014, 01:18 PM
  5. 2013 26" 130mm to 29"?
    By Sean Allan in forum Cannondale
    Last Post: 11-19-2012, 03:47 PM
