Results 1 to 2 of 2
    Jan 2013
    Trek Fuel EX 9 2011
    Hello all.
    I have a Trek Fuel EX 9 from 2011 that I would like to go sram xx1 with.
    2011 Fuel EX 9 - Bike Archive - Trek Bicycle
    Is it possible to use an adapter like this one and use my existing wheels?:
    DT, Sram XD 11s body för Sram XX1 kassett, 142x12 mm Thru Axle
    What about the bottom bracket? I know Trek has their special version.
    Oct 2007
    Yes, you should be able to use an XD driver adaptor to make your DT swiss hubs compatible with the XX1 cassette. I'm not 100 percent sure, since I don't have dt swiss hubs myself and am not sure if there are different versions of them, but you'll be able to find out by calling a bike shop and letting them know what model hubs you have. I do know however, that they make an adaptor for DT hubs currently. I just set up a 2012 EX 9.9 with 1x11 and had to convert my American Classic hubs as well. The EX frame required a Madone bottom bracket kit to work with the GXP XX1 crankset that I purchased. I am not sure if the bottom bracket for your 2011 aluminum framed EX is the same as my bike, however. I hope some of this helps, but it may have just created more questions for you.
  1. 2011 Trek Top Fuel 9.7 vs 2013 Fuel EX 8
    By Shutter in forum All Mountain
    Last Post: 10-03-2012, 06:17 AM
  2. 2012 Trek Remedy vs 2011 Trek Fuel
    By StaySolitude in forum All Mountain
    Last Post: 04-13-2012, 05:15 AM
  3. Replies: 3
    Last Post: 02-29-2012, 03:21 PM
  4. 2011 Trek Fuel EX5 or 2008 Trek Fuel EX9
    By tavorh1 in forum Trek
    Last Post: 11-08-2011, 07:07 PM
  5. 2010 Trek Top Fuel 8 vs 2011 Trek Fuel EX 8
    By David S - Sydney in forum Trek
    Last Post: 01-12-2011, 07:08 PM
