Results 1 to 3 of 3
    Reputation: Tkul's Avatar
    TREK FUEL 7 - Rear shock eye-to-eye dimensions
    Could anyone help finding eye-to-eye shock dimension?
    Trek Fuel 7 - (2005 I think - bike not mine!)
    Shock Up-grade - DT SSD225 - Has anyone try it? Is it worth it?
    occupation : Foole
    Reputation: Fuelish's Avatar
    Quote Originally Posted by Tkul
    Can't comment as to the shock choice, but, unless Trek changed their specs over the years, the i2i should be 6.5" w/ 1.5" stroke. Mine's an older Fuel, and as I said, dunno if they changed much over the years...fwiw. Good luck.
    Bushs
    Ok, thanks a lot! I am helping a friend with this shock up-grade, and I don`t have access to the bike. So i ask him to do some measurements.
    Do you know about bush-dimension?
    At the LBS they have for the DT SWISS 225, bushs in:
    - 22,2 x 8
    - 50,0 x 8
    (all the values in mm)
    I have seen in a recent topic (Fuel 98) that it uses 22,2 x 6 - 6 being the hole diameter to pass the bolt? right?
