Results 1 to 7 of 7
    The turtle won the race!
    Reputation: sickpup120's Avatar
    Cool-blue Rhythm trek 990 and.... disc brakes?
    I have a full ridged 1995-1996 Trek 990. I was wandering if there were any conventional ways of using disc brakes with this frame and fork. In my opinion this bike rocks, except for stopping power. (There is none). It now has the original XT cantis that are fine for slowing down but God help me if I need to stop! Any suggestions would be helpful ....Thanks
    The front end should be fairly simple as you can simply install a different fork on the bike. Only catch would be if you have a 1" steerer - that would make it difficult to find one as 99.99% of ATB forks are 1-1/8".
    For the back end, you'd have to get ahold of a brake therapy system (google it). I believe you also need to modify a hub to use said system (I've never used one so don't know much about it-perhaps one with experience can chime in).
    Unless you know a [good] frame builder and are willing to forgo your warranty - they could weld in a disc dropout for you
    Steerer is 1-1/8" no problem there, and i was thinking of upgrading to an 80mm or 100mm fork sometime soon anyway. And i here 70% of your stopping power is on the front so maybe a good v brake on the rear will be cheaper and just what the doctor ordered . Thanks Zigg....................
    Lock stock and barrel baby! hook line and sinker, your freedom is your master, your liberty self labor....
    V brake on rear with brake booster
    I used to own a 970 from that era which used the same sweet frame as you've got (kicking myself I sold it really). I switched to V brakes on it in '98, but the seat stays flexed so much it was scary - bought a brake boooster (a U-shaped aluminium bit that connects the brakes - you can pick them up in ebay for next to nothing now) and it improved things a lot.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Stopping Power
    A well set up pair of cantilevers stops better than a set of v-brakes.
    Cantis also stop just as well as discs....actually all bicycle brakes provide more stopping power than you'll ever need to stop.
    That said you can get a Brake Therapy or similar adapter and a newer fork up front.
    The total cost of the upgrade will probably be more than what you paid for the 990 though since you'll need new wheels in addition to the fork, brakes, and rear adapter. Total outlay with some careful shopping will be in the $500 range.
    Banned
    Jan 2015
    I had all the parts from other bikes and finished my 990 build this weekend.
    Sep 2013
    Quote Originally Posted by ak-rider View Post
    That bike deserves at least 10 thumbs up. I love it!
    Quote Originally Posted by Shayne View Post
    As someone who was mountain biking for several years before V-brakes were introduced, I'd take some exception to that. It was a big improvement. After I got my first set of V-brakes, I knew I'd never go back to cantis. I know canti's can work just fine - I had several bikes with them, but they were finicky to set up and didn't have as much leverage as V-brakes - so v-brakes required less force on the lever to get the same amount of braking torque at the wheel. So they "feel" stronger, even if they're really not.
    All that said, disc brakes are really great - and I'd never go back to rim brakes ;-)
