Results 1 to 48 of 48
    steel is real...heavy
    Trek 8000 Hayes 22mm Mount to IS
    Model Year 2000 Trek 8000
    Hey, did a search and none of the posts came to a conclusion so I will ask the question...
    Is there any good way to get today's modern Disc brakes (IS mount) onto an old hayes mount on the chainstay? I have the a2z red adaptor that will give you an IS mounting for 185 mm rotors, but it doesnt quite clear the seatstay. I've also heard the other a2z frame adaptor (the machined plate that bolts to the dropout) won't work on the trek 8000 because the dropout is not flat, but has a ridge cast into it.
    So is it time to banish the frame to back-up hell? I really want discs.
    Dec 2005
    To my knowledge, Hayes makes an adaptor to go from a 22mmDM caliper to IS but not the other way around. I think Hayes might still have 22mmDM calipers available. If not, PM me and we can work out a deal on a 22mm mount half. This will mate with any G1 caliper, and I think with a G2 as well. I also have the 22mm to IS adaptor--Mantra was replaced with Palomino.
    Richard
    Quote Originally Posted by rburke
    Richard
    Yes I'm interested, PM me. Thanks.
    Jul 2003
    rburke is correct, nobody makes an adaptor....
    to mount IS brakes on the old Trek chain stay type mount. I know I looked for a long time trying to find one for my 00 7000. NO GO! You either have to find the a set of older 22mm Hayes direct mounts or, if it's possible, as rburke says you could find a trashed set and salvage the outer half and install it on a G1 or G2 inner half. I haven't seen any Hayes rear DM's in a long time. I don't know if Hayes still offers them or not. You could give em a call and find out.
    In any case, good luck with your search, I never did find a set for my ride.
    Good Dirt
    Reputation: sungchang's Avatar
    I have an 01 Klein Attitude and I am planning to just go disc in the front and leave the rear with v-brakes for the same issue.
    Hayes does still make the 22 mm calipers for the older frames. Contact them for more information, but I know they do make them.
    Aug 2005
    Older Thread, but I just did the same and it works perfect, if you use star lock washers.
    I copied this post out of another Thread, so it's a little Klein-specific, but it works on a Trek or Fisher just as well I assume:
    Here's what you need:
    http://cgi.ebay.com/A2Z-Rear-Disc-Br...QQcmdZViewItem
    If you use a Standard IS rear brake Caliper you need to run 180 discs.
    What you can do is, you buy a Marta or Louise and order a front caliper with a rear right hand brake lever, offered from Magura as the Moto-style set, with that you can run 160 rear and front.
    http://www.beyondbikes.com/BB/ItemDe...DBRA%2D0721664
    If you mount the adapter, make sure you use a star washer, or otherwise it will become a pain in the ass, so use 2 star washers between the frame and the adapter.
    Further you can run the rear brake cable through the top tube, no need to drill holes, just pull out the sleeves out of the tube and if you want to go back to v-brakes you just push them back in.
    Here are a couple Pics, cause I just did it with my bike.
    Thanks for the info. Btw when you say star washer, which ones do you mean?
    Aug 2005
    Quote Originally Posted by sungchang
    If you look close in the third Pic from the bottom you can see them.
    Quote Originally Posted by yellowbook
    Where can I pick them up? Thanks.
    Aug 2005
    Any Hardware Store, ACE, Home Depot, Lowes......
    yeah i ended up using that a2z adaptor for a shimano deore 555 brake, like the one you hanve on your Klein it's direct IS mount, no adaptor. I tired to put a post-mount brake+adaptor brake back there and the adaptor hits the seat stay and will not mount.
    so...if you are going to do this then make sure the caliper will fit.
    also, looks like your rotors are the same size, what are they/ i had to use a 185mm rotor in back, and i stuck with a 160mm in front.
    Aug 2005
    Quote Originally Posted by jvp108
    Yeah, as I said above, they're both 160, the rear caliper is for a IS Front Brake, but I ordered it with a right hand brake lever (Moto-style...link is above).
    If you order a simple rear brake caliper and you're using the adapter you have to use a 180 disc and that's what I didn't want.
    Thanks to another guy from germany, I know about this moto-style trick.
    yellowbook, btw what is that black plastic thing that is holding the brake cable, and how is it attached? Where can I pick that up? Thanks.
    Aug 2005
    Eureka!
    I want to do exactly this on my 2000 model Trek 8000. Well, sort of... I want to keep my integrated XTR brake pulls -- can I use that with a mechanical 'front' caliper attached in the rear via the adapter?
    Thanks in advance,
    ~ Fred
    Nov 2006
    Cool-blue Rhythm Trek 8000 (2002) Disk Caliper mount Adaptor
    I spent ages looking for this so thought it might be of interest for your Trek(kies) out there.
    Trek do an adaptor (to IS mount) if you have what they call a Disc-O tab.
    I don't have a pic of my frame handy but if you look at the adaptor I think it will be clear if it will fit or not. My Trek (8000 2002) has a 'recessed' tab for the disc mount - note the smaller hole a third down from the top frame mounting hole which is the givaway.
    Here is a pic of the adaptor:http://www.evanscycles.com/product_images/B911.jpg
    (if the url changes the link to the pic is from http://www.evanscycles.com under brakes accessories)
    It costs 9.99 from Evans and is easily available.
    regards
    Chris.
    Reputation: Nater's Avatar
    Not for the same frames...
    Quote Originally Posted by hardtailman
    regards
    Chris.
    This adaptor is for the newer Trek/Klein/Fisher frames that do not have a disc mount cast into the dropout. This adaptor bolts on to the left side dropout giving you 51mm IS mounts for just about any disc brake on the market.
    The bikes pictures above have a 22mm Hayes mount on the left chainstay and were designed to be used with a specific Hayes caliper. This is a solution to a different problem than the thread asks about.
    I know it's an old thread, but does this work? Two front brakes to run 160 on the rear of an older Trek with the chainstay Hayes mount and the adapter?
    Quote Originally Posted by jhovak
    Yes, this works. It's a shame the pictures have gone as that's what I used to fit magura brakes to my Trek frame which has the same Hayes 22mm chainstay mount. Follow the instructions above precisely and it works.
    Pete
    Feeling a little taller
    Reputation: Dan'ger's Avatar
    I recently came across this: http://www.beyondbikes.com/BB/ItemDesc.asp?IC=QBR3958
    And this: http://stores.channeladvisor.com/Bik...R%20%23HBRMH42
    To try to bring a Hannebrink fork I have back to life.
    There are no stupid questions but there are A LOT of inquisitive idiots.
    Bicycle Trails Council of the East Bay
    Reputation: Sigfod's Avatar
    Quote Originally Posted by Dan'ger
    Do we have any idea if this works on late 90s trek 8000 series bikes? I have been looking for a solution for quite some time.
    '94 Trek 830 XT/LX/Gripshift/SRAM (Commuter)
    '98/2000 Trek 8300/8500 XTR/XT/LX/SRAM (XC Rig)
    Quote Originally Posted by Sigfod
    Is the mount on the chain stay or the seat stay? I got one of the A2Z units off of eBay. Also available here: http://www.jerseycycles.com/Product-...ZProducts.html
    I used it on a Hannebrink fork that has the Hayes 22mm mount to mate it with a Magura Julie and a 185mm rotor.
    Mine is on the chainstay
    I'd say that most of the question is whether there will be enough clearance between the chainstay and the seat stay for the adapter and caliper. It will likely work and may be worth the $27 investment in the adapter if you've already got a caliper around. Worst case scenario, you re-sell the adapter on eBay.
    I can tell you that the A2Z unit did not work.
    Because of caliper clearance?
    Yes the caliper kept hitting the frame. I even tried "clearancing" the caliper, same thing I had to do to get those Brembos on my Sentra, no dice.
    The first unit that I linked from Beyond Bikes (above) is apparently for using a Hayes 22mm caliper on a frame that has the 51mm IS - so reverse from what you want.
    I also found another adapter that is different from the a2z and after a few emails with the vendor, it's more expensive but seems a viable alternative.
    Here is one that I found that will work with 22mm mount and Shimano 51mm calipers. There is no picture to go with this one: http://stores.channeladvisor.com/Bik...T/HAYES%2022MM at $60, I don't think I would buy without at least an image.
    The second image and link I gave above are apparently the same idea only for Hope brakes.
    Dec 2008
    Did anyone try this?
    I am having the same problem with my TREK 8000 year 2000. The a2z adapter didn't work for me either, due to the clearance problem.
    Jan 2009
    hi guys,
    sorry that I recur, but I'm getting confused by this thread (since also most of the pics are gone). Could anyone pls tell me, if it's possible to mount a Magura Louis 160 to an old Trek 8500 SL with Hayes 22mm mount (chainstay). Which parts do I need?
    Thanks,
    Mario
    Dec 2008
    You need an adapter, like the AD-PMR from here: http://www.a2zcomponents.com/Adapter/Others.asp . But this didn't work for my TREK (Model 8000, year 2000, frame size 17.5''), because there isn't enough space between the chain stay and seat stay for the adapter & brake caliper. If you have a larger frame, it might work though.
    Cheers, Frank
    22mm chain stay disc brake adapter
    Hi I work with a laser and fabrication shop in Denver, CO and we just designed and made an adapter that works with the 22mm chain stay disc brake mount pattern for Trek, Klein and Schwinn. I am attaching photos for you to see how it gets the calliper above the seat stay (which is the problem with the other adapters). Drat the picture sizes are too large. If you would like to e-mail me I can send you pictures.
    nanoseth@yahoo.com
    Jan 2009
    Hi, thanks a lot for the information, but I decided not to mount a discbrake. I'll go for the new HS33... Mario
    in da house CREW
    posting this up for whoever is looking for one of these its ugly as sh!t imo.
    http://www.torontocycles.com/Selling/Adapters.html
    How do you like this adapter?
    Obviously the previous gentleman does not like the looks of the adapter. We have made a couple of revisions to the adapter to accomodate the 8500 Trek frame and the Schwinn home grown bent seat stay but it still looks the same. We were going for functionality in making it but if you have any suggestions on how to improve it I would be more than happy to listen. I have had nothing but good feed back from people that are happy to get rear disc brakes on their beloved bikes again.
    in da house CREW
    nano dont get me wrong, im happy to see theres something out there for these old frames. but it just looks out of place maybe making it smaller or a little more tubular.
    Would this fit?
    Attached Thumbnails Attached Thumbnails Trek 8000 Hayes 22mm Mount to IS-bilde0002.jpg
    22mm Trek 8000 to IS
    I would be interested but I doubt it would fit. The 8000 series has a depression in the chain stay thay would not allow that style to sit flat. Also, I believe there would be a clearance issue with the seat stay unless another adapter is used to get the caliper above it, in which case that additional adapter would need to "squeak" by seat stay. I won't say no but I find it doubtful. Good luck!
    How much further ???
    Reputation: Douger-1's Avatar
    Quote Originally Posted by nanoseth
    Would this adaptor work on a 1999 Psycle Werks Wild Hare? Im running into a similar issue.
    22mm chain stay adapter
    Hi I believe it will work for you but pictures will tell the tale.
    nanoseth@yahoo.com
    Quote Originally Posted by mtbmaniac
    Would this fit?
    That looks like an adaptor from a '98-'01 Marzocchi fork.
    nanoseth@yahoo.com
    This adaptor doesnt work. No matter how I position the caliper, only half of the pads contact the rotor. Its a 6" Hayes rotor with a Hayes Stroker caliper. The bracket positions the caliper too high. Also do to the angle the bracket puts the caliper at, braking forces put an extremely large amount of force on all the mounting bolts. The caliper/bracket eventually moved on me after testing heavy braking just on my street. I do not feel comfortable with this setup on my AM bike. I wasted $27 and will be trying the next idea.
    Hey there, sorry that model did not work the way you wanted it to. I understand your problem. We have actualy made a recent adjustment to the adapter to bring the calliper down into more contact surface with the rotor. We have also beefed it up a bit but it will still transfer just as much force down into the 22mm mounts. I would be happy to send you the new one if you are interested. I am surprised the adapter shifted at the 22mm mount position. Did you use star, lock washers or anything else to deter this from happening?
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Aug 2005
    New question here.
    Hi, I'm looking at a 16" serotta with the 22mm chainstay hayes mount, pictured here:
    http://by136w.bay136.mail.live.com/att/GetAttachment.aspx?tnail=0&messageId=f1ac7b18-253d-11df-9dd2-00215ad9dfd2&Aux=0|0|8CC8761DA385660||
    and wondering if this adapter you're making would work with it? Or if not, would an a2z similar, compact (ie non-Brake-Therapy) adapter work?
    Thanks for any advice
    22mm hayes calliper mount
    I had some trouble openning your pics. Could you send them to my nanoseth@yahoo.com account? We have made a couple of revisions to account for the different bike models. I am pretty sure our current adapter works for all 22mm direct mount bike makes and models. Close-up pictures are preferred.
    Thanks,
    Seth
    B&S Fabrication
