Trek 29er's roll call
Printable View
  • 03-23-2014
    Forster
    Originally Posted by ncruz408 View Post
    Sweet bikes everyone. Limey Johnson, that marlin looks sharp in that color. I was skeptical at first when I first saw it but yours looks sweet! Are those stock handlebars? I am thinking about swapping mine out but not sure what to get. It feels to wide for me and I notice my forearms hurt after a ride. I know I can cut it but wanted to know if it would be better to swap it out for more comfort and also to shed some weight. Any recommendations anyone?
    ncruz, I've got a '11 Paragon (Stealth Grey Paint Job) that came with the somewhat maligned 17 degree big sweep bars. I cut mine to fit my perception of what works and would recommend you consider cutting yours before buying replacements (even if you are buying replacements anyway) to see what you like (width wise). If you cut your stock bars too narrow, you can fix that with the planned replacement, if you cut your replacement bars too narrow you're buying a third set. I'm a big believer in my bars supporting a "neutral wrist" position where the wrist is neither turned inward or outward and where the wrist is not bent with fingers on the controls (in your primary riding position you should be able to lay a flat edge (ruler) along the forearm and back of the hand and approximate a straight line. I've used risers and non-risers, always with at least 10 degrees of sweep.
  • 03-23-2014
    Tim2103
    A little late to reply to this, but when I switched from my 3x10 to XX1, my bike dropped a little over 800 grams.
    Originally Posted by HawkGX View Post
    What do you figure your weight savings was with your 1x10 conversion? I still have the stock triple and cogset on my 2013 Mamba, but I'm never in the small ring. Was considering a switch to either a double or single ring crank.
  • 03-23-2014
    DethWshBkr
    3 Attachment(s)
    Attachment 879221
    Attachment 879223
    Attachment 879222
    All changes are to make it more my style, not for a performance upgrade necessarily, although the brakes are major upgrades.
    X9 rear derailleur
    X0 gripshift
    Hope Tech3 E4 front brake, Tech 3 X2 rear brake
    203mm rotors front and rear
    XR4 front tire
    I did dump the large ring, since I am not nearly strong enough to need it. Added a RaceFace bash guard.
    Otherwise stock. I tried the triggers, just could not get used to them, so I had to go with a Sram rear derailleur. I have always liked gripshift. The shifters are 3x10, even though I did remove the large ring. If I find I eventually need the large ring, I will toss it on, and can still use the shifters!
    After that, the Shimano brakes would NOT fit in a safe manner (I figured they woulnd't) so I was going to get a set of Hayes Prime experts, but instead decided to splurge on the brakes with large rotors.
    I LOVE the XR4 tire on my 26" Fuel EX9, so I knew I wanted that tire up front.
  • 03-25-2014
    trey_sd
    2013 Superfly 100 AL Elite
    It's stock except tubeless tires and Shimano MD's
  • 03-25-2014
    trey_sd
    :thumbsup::thumbsup::thumbsup:Nice rig man. Very clean looking
  • 04-10-2014
    akaBrowntown
    New commuter/rehab bike - broke my leg a month ago trail riding. Scored it rediculous cheap and have a rigid fork and super moto tires on the way. Dont dig road bikes, and a 29er will be way cooler.
    Potato pic of stock Wahoo.
  • 04-11-2014
    pilo98
    trek wahoo from belgium
    Attachment 884497Attachment 884498
    hello
    this is my wahoo
    fork reba
    xt-slx
    ztr crest
    seatpost vannicholas titanium
  • 04-14-2014
    akaBrowntown
    Funny you posted the second pic haha, we will have similar builds. Are they Big Apples? Looks like it - I have some Super Motos on the way and a carbon fork. With slx crank, narrow wide and xtr rear mech.
    Here is the best phone pic - its without BB now. All the parts are trickling in this week. Really stoked.
  • 04-30-2014
    Bryan1113
    Looking to put beefier tires on my 13 Superfly AL! Kind of curious what everyone else running on their bikes? Thanks
  • 04-30-2014
    trey_sd
    I'm using conti xkings. They aren't s beefy as maxxis ardents, or bontrager tr's, but they are like Velcro on the trail. Anything is better than the tires that came on my SF elite. Garbage !!!
  • 04-30-2014
    KevinShoes
    I have the same bike and immediately upgraded to the bontrager's 29-3 team issue tires (the shop I go to only carries Trek stuff so I'm not familiar with other brands so much). But I love the 3s (I think they've been renamed XR3 now). I live in New England so rocky, rooty trails but these tires are still great in wet and dry conditions and absolutely rail turns. But as always, I recommend talking to your LBS and seeing what they feel is best.
  • 04-30-2014
    CannondaleF9
    I am using Schwalbe Hans Dampf 2.35s on my Cobia.
  • 04-30-2014
    trey_sd
    It's all about where you live and trail conditions. I'm in AL and it's humid and the trails are super dry. So the contis are perfect for me. So like Kevin said, hit up your LBS
  • 04-30-2014
    J79
    3 Attachment(s)
    I'm running Michelin Wildgripper 29x2.25 on mine...
    Had a good test with them in Austria last week...
  • 04-30-2014
    RaceTripper
    My LBS sells a lot of Maxxis Ignitors, so I have taken their advice and run them on my Superfly FS 9. I'm no expert, but I like them for leafy, rooty, rocky terrain. It came with Bontrager XR1 Team Issue, which work well for me with dry, packed dirt and gravel.
  • 04-30-2014
    coling
    Mine aren't really beefier but I love them for my XC Pacific NW riding. I run Specialized S-Works Ground Control 2.1 front and back.
    Although this season I'm thinking of swapping the rear for a Maxxis but I can't decide which.
  • 04-30-2014
    Bryan1113
    I live in So Cal desert area! Dry, rocky conditions...LBS steering me into Trail King direction so just checking to see what everyone else rolling with! Thanks for feedback
  • 04-30-2014
    dlafleur
    I'm riding a completely stock 2011 Marlin, got it and love it! Now, thanks to all of ya'll on mtbr, I have the upgrade bug. Any ideas for some "must" upgrades? Btw I live in New Orleans and ride muddy trails since it rains constantly.
  • 04-30-2014
    trey_sd
    Wheels and tubeless setup
  • 04-30-2014
    trey_sd
    A fork
  • 04-30-2014
    dlafleur
    Any suggestions on wheels and tires? I've heard a lot of good things about hope hubs but have no idea about tires at all.
  • 04-30-2014
    andylaiphoto
    Just picked up an X-Caliber 6. Haven't been on a bike since 2007 and haven't been on a hard tail since 2009. Have about 40miles on it so far and it's been interesting. Wasn't sure what to expect from it being low spec, I've never owned such a low spec bike but finances right now won't allow anything nicer. Let's see how long I can keep this one for.
  • 05-01-2014
    Sickmak90
    Just picked up this 2013 x-cal. Liking it so far!Attachment 890000
  • 05-01-2014
    trey_sd
    Conti's alllll day
  • 05-01-2014
    trey_sd
    Anything Stan's is good. You can find them on eBay with tires and ready to roll for around $400. That's what I did on my other bike before I sold it.
  • 05-01-2014
    trey_sd
    Where did you get that jersey ?
  • 05-02-2014
    J79
  • 05-04-2014
    Tomahawk3Niner
    Re: Trek 29er's roll call
    X Cal 7 out playing in the rocks.
  • 05-06-2014
    Biocoug1
    Chris
    Seattle, Wa
    First 29er, Trek X-caliber 8
    I really enjoy the ride. Handles terrain really nice. Changed the saddle, specialized white pedals, added some fenders and Lizard skin grips (not seen).
    Mainly use it for XC, some downhill and moderate jumps.
    I like it
  • 05-06-2014
    coling
    Biocoug? When did you graduate? I was '09 and I'm in Renton. Is that silkworm behind you?
  • 05-06-2014
    Biocoug1
    Ha! small world man! I graduated in 07. That is Paradise Valley in Mill Creek/Woodinville. I just got my Trek couple months ago so I'm looking to get out to different spots. My normals are Des Moines Creek park, Paradise and Duthie. :)
    Go Cougs/Go Hawks my brother.
  • 05-06-2014
    coling
    A few of us are riding duchies this Saturday, be there around lunchtime if you want to ride. I'll be on a navy Rumblefish, buddy with a black remedy and other buddy on a red Yeti.
  • 05-06-2014
    coling
    **Duthie
  • 05-07-2014
    trey_sd
    I've already posted here, but put an upgrade or two on my superfly. Conti xkings, and raceface 1x10 32t conversion. New pedals in the mail because I've destroyed my shimano md's.
  • 05-07-2014
    jfaust97
    https://www.facebook.com/MountainBikesLeaningOnThings
    hahaha!!!
  • 05-07-2014
    trey_sd
    Lol^^
  • 05-10-2014
    Robg68
    I got a killer deal on this new 2013 Trek Superfly 100AL 29er. Bought it for my wife for our Anniversary.
    My current bike--2014 Trek Fuel EX 8 29er.
  • 05-12-2014
    KillBillVelo
    New Pony!
    2014 9.8 Superfly - 20.9lbs
    The only thing not stock are the Bars, Seatpost and Saddle.
    Swapped out to XXX and a Fizik Tundra w/carbon rails…
    Crankbros Pedals.
  • 05-17-2014
    Fsrbikr98
    Trek Superfly 5!
  • 05-17-2014
    Robg68
    My Trek Fuel 8 29er and my wife's 2013 Trek Superfly AL 100. Took a nice ride today.
  • 05-24-2014
    akaBrowntown
    Training rig.
  • 05-24-2014
    scottvt
    Got this 2013 Rumblefish late last year. First time on a 29er and I like it. Already have a few upgrades and I am waiting for more in the mail.
    Already installed are XT shifters, ENVE bar and seatpost, WTB Silverado saddle XTR cassette with Wolftooth 42tooth cog and ODI XTrainer grips, and I converted to tubeless.
    Waiting for I9/Stans Arch wheels, Race Face 30tooth NW ring, XTR crank and XTR rear derailleur.
    Attachment 895920
    My fork was part of the recall, and I have a few rides on the new damper, and I must say it is a world of difference. CTD actually does something, and I get just about full travel, still dialing the pressure.
  • 05-25-2014
    Wisconsinite762
    2013 Trek Marlin
    Owner: Cody
    Bike/Setup: 2013 Trek Marlin - Stock except for the pedals and gel seat cover
    How long have you owned it: 2 Days
    Thoughts so far: Haven't taken it to a trail yet, so I am not sure how it will ride. But I took it for a 30 mile road cruise today and it performed better than expected!
    Cons so far: The brakes suck, definitely need to upgrade.
    Attachment 896112
  • 06-06-2014
    Over50rider
    My hard tail is a 2011 Cobia, my full suspension is a 2013 Super Fly AL 100. Have only took the SF on 2 rides but I am well pleased with it. At my age the suspension sure does make a big difference, I'm almost 56 years young.
  • 06-15-2014
    Inamik75
    Trek Stache 7, all stock except. Bontrager Tublees tires Team issue. For the price, this is one heck of a bike!
  • 06-15-2014
    bfowler6
    4 Attachment(s)
    Finally done upgrading my Stache, love the way this thing rides, now all that's left is for me to continue to get faster
    Attachment 901398Attachment 901396Attachment 901397Attachment 901395
    -Spank Oozy Trail295 Bead Bite Wheelset
    -KS Lev 150 routed through my old fd internal routing
    -Ice Tech rotors and pads
    -70mm Rhythm Pro stem and 750mm Rhythm Pro carbon bar
    -XT chain and cassette
    -Saint rd and shifter
    -Race Face 30t narrow wide chainring
    Just under 26 lbs
  • 06-23-2014
    Scishfottman
    New X-Cal 8 in the house.
  • 06-23-2014
    Mapcinq
    What pedals are those? Thanks-
  • 06-23-2014
    Scishfottman
    Deity Decoy. Purple makes you go faster.
  • 06-24-2014
    Mapcinq
    Thanks.. I just bought the same bike, really like the purple you put on it.
  • 06-24-2014
    sl1_matt
    Boom. Sawyer decked out.
  • 08-23-2014
    Frydguy
    I haven't rode in a dozen years or so ..my old Trek wore out and I lost the urge ..till a few weeks ago.. I picked up a 14 Xcal 7 in orange....oh the pain...
  • 09-24-2014
    Islandkilo
    BEFORE: 26er 3700
    CURRENTLY: 29er X-Cal 8
    only thing I've changed so far is adding Shimano SPD-M530 pedals
  • 09-24-2014
    Yankees24
    xcal 6 2014
    xcal 6 2014 - all stock parts for now
  • 12-29-2014
    EOS_
    4 Attachment(s)
    My fully upgraded TREK Paragon 29" 2011
    Greetings, I should have found this thread earlier, so here is my TREK 29", : Paragon 2011 29" frame.
    It a great bike. Fast, stable and excellent handling. G2 geometry really works! With upgrades it rides even better, especially wheels, ceramic bearings BB and brakes! I guess the only stock components are the head set and brake discs.
    My major upgrades:
    - normal bars and Ergon grips,
    - Specialized BG seat,
    - Shimano XT BR785 2012 brakes,
    - wheels: WTB Stryker TCS Cross Country 29” 2012 - most important upgrade
    - SRAM X9 3x10 GXP cranks with SRAM pressfit ceramic
    - fork: Rockshox SID XX 29" G2 100mm 15mm tapered, 2012
    - SRAM 1070 casset
    - SRAM X0 type 2 rear derailerur 2013
    - SRAM X0 shifters 2013
  • 12-31-2014
    Kishin
    Here's my 2015 X-Caliber 7 18.5 inch... only thing I've added so far are Shimano M530 pedals.
  • 01-02-2015
    avmech
    Soon to be in my possession: 17 1/2 inch 2015 X-Cal 8. Already have Shimano Saint pedals coming (already have Shimano SPDs), Ergon grips/bar ends I already have, along with another saddle if the stock one does not work for me.
  • 01-02-2015
    Boridian
    2015 X-Cal 9. Only update is Wellgo Mg flatsAttachment 952192
  • 01-02-2015
    SRRD-RacinG
    @ avmech. Can't wait for real pics. I, too, plan to get an Xcal 8, just not the black model.
  • 01-03-2015
    mcire88
    what are your thoughts on the x-cal 9. I was thinking of heading down to the trek store to make the plunge today.
  • 01-03-2015
    Boridian
    I love it. I've had it through about 30 miles and the only problem I've had was with some wheel truing. It's fast compared to what I had before. I'm a been though so don't know enough to describe it. Drive train is more than what I need and shifts fast and clean.
  • 01-14-2015
    lamar83
    My FIFTH GF Trek 29er HT.
    2011 Mamba
    FOX RL G2 fork 100mm
    Kenda Slant 6 and Nevegal
    Shimano Alfine brakes
    Full 2014 SLX 2x10 (sitting at home)
    Bontrager switchblade race X fork rigid (on its way)
  • 02-05-2015
    SRRD-RacinG
    A local bike shop has a 29er X Cal 9 2014 for $1,000. Before I heard of that deal, I was decided on the 2015 X cal 8 (same price). I do see that the X Cal 9 2014 has better brakes while also boasting an XC32, but air-based. Which would you guys go for?
  • 02-05-2015
    jeffj
    On that platform, I would take better brakes, and an air spring fork any day of the week.
  • 02-06-2015
    EOS_
    TREK X-call 2014 and 2015 frames are identical,so if the 2014 x-call 9 and 2015 x-call 8 are for the same price, then go for the 2014 x-call 9, simply better components for the same price. Fork is really important and brakes as well.
  • 02-06-2015
    SRRD-RacinG
    The biggest advantage I see from the X Cal 8 2015 is the tubeless ready rims and possibly the 2X drivetrain (though not really for me since I do like to get some speed on the roads).
  • 02-06-2015
    CannondaleF9
    I have a 3x system on my road bike, and it isn't as smooth or nice at high speeds going down hills. I prefer to either coast in the middle ring and the highest gear, or the big ring and half way down the cassette.
    Also, why do you ride road on your mountain bike? It isn't designed for that, therefore you don't need a big ring. A third ring also adds weight (its what the weight weenies say).
  • 02-06-2015
    KevinShoes
    The air based spring will be a much bigger upgrade over a coil spring in the fork. I'd go with 9.
  • 02-06-2015
    ConchoBill
    I am slumming with my Marlin 5, which is now absolutely stock. With the places I am riding it is super capable. I need to get it to some good trails. Actually I will be doing the best riding on my department store Schwinn because I am taking it to the ranch and there are some pretty interesting roads out there.
    I'll try to post a photo soon.
  • 02-07-2015
    Ruckus99ss
  • 04-14-2015
    Mattyoooch
    Hi ConchoBill,
    Picked up a 2015 Marlin 5 last week. Hope you love yours as much as I love mine. All stock as well, Awesome on single track and gravel as that's all I've road so far. (I'm a noob to MTB) Hitting Bethpage State Park on Long Island NY this week and it should be a little more of a challenge, then what I road last week.
    Attachment 981174
  • 04-15-2015
    ConchoBill
    Matty, yours looks a lot like mine, except my Raidon fork is white, and I have a mirror, water bottle and frame pump, and more dirt and mud.
  • 04-15-2015
    Mattyoooch
    Lmao, yea definitely no dirt on mine or anything else because that pictures from the day it came home. I'm eventually going to upgrade to the Raidon fork, just don't have the funds atm. I now have a seat pack, frame pump and bottle holder. I'll take a new pic after this weekend because I'm going to hit the trails hard!
  • 04-15-2015
    ConchoBill
    Amazon tells me that I just received this saddle at my house:
    Amazon.com : Avenir Men's 100 Series Mountain Saddle (Black/Silver) : Bike Saddles And Seats : Sports & Outdoors
    So it will be added to my dirty Trek Marlin 29er.
  • 04-15-2015
    karlmaddock
    Hiya all, here is my 2013 trek mamba, all stock want to get new pedals and slx brakes.
  • 04-15-2015
    Mattyoooch
    ConchiBill, I'd like to see a pic with the Raidon fork on the bike. Can you put one up?
  • 04-20-2015
    pilo98
    "little evo " :p
  • 04-20-2015
    ConchoBill
    I never saw a bike that looked anything like that!
    Matty, being the tech idiot I am, I can't get my photos small enough in mbs to post, or I cannot understand how to post photos here. That is why no photo.
  • 11-18-2015
    marinemonkey
    what fender do you have on the front of your bike? and how do you like it?
  • 11-18-2015
    marinemonkey
    This is the fender I was talking about...
    Originally Posted by sl1_matt View Post
  • 11-18-2015
    marinemonkey
    I have a 2016 Trek Superfly 5 (stock at the moment)
  • 11-18-2015
    Cayenne_Pepa
    2012 Superfly 100 Pro - 24.0 pounds
    With the 115mm G2 fork - it preforms about 90% of what a 2015 Fuel EX9 does:
  • 11-28-2015
    Kickngas
    2014 Superfly 8
    Attachment 1031905
    2014 Superfly 8 Craigslist find. Totally stock for now, with the exception of saddle.
  • 03-13-2016
    andrewasmith
    2015 Fuel EX 5
    Upgraded:
    Fork to a Fox Float 32 120mm.
    Rear wheel Mavic Crossride
    Converted to tubeless.
    Reverb dropper post
    WTB Volt Race Seat
    Odyssey CIELENCKI pedals
    Continental Trail king 2.4 front, 2.2 rear.
    Hussefelt Bars and stem 40mm
    Also converted the rear axle to 142x12.
    It's right where I want it now.
    32#
  • 03-23-2016
    EOS_
    6 Attachment(s)
    My TREK Superfly 5, 2014 fully upgraded
    My TREK Superfly 5 2014 upgraded; I upgraded practically everything. I mainly wanted that frame.
    most important upgrades:
    wheelset: WTB Stryker TCS Cross Country Race 29″
    fork: Fox 32 Float 100mm Terralogic Kashima
    brakes: Shimano XT BR-M785
    shifters: X7 and X9 2x10 Type 2
    crankset: X9 28/42 GXP with SRAM press fit ceramic
    casset: SunRace MX3 CHAMPAGNE 10sp 11-40
    Now I am deciding how to convert to 12x142
    Attachment 1058820Attachment 1058821Attachment 1058822Attachment 1058823Attachment 1058824Attachment 1058825
  • 03-23-2016
    CannondaleF9
    Cool build! I love the frame. It is a similar concept to my Cobia.
  • 05-05-2016
    Matthew Woollum
    Mamba Gary Fisher Edition
    Has a few modifications:
    Bontrager Gel Cruiser seat
    Odyssey Triple Trap pedals
    Cats Eye bottle holders
    Attachment 1068326
  • 05-05-2016
    A-X
    My Procaliber 9.8 SL with a stealth reverb added.
  • 05-26-2016
    garman
    My Superfly!!! Love it!!
  • 02-20-2017
    Sickmak90
    I'm still riding this old girl.
